Old 01-26-2009, 11:00 PM   #1
ottamania
ottamania is an unknown quantity at this point
SR Greddy Intake Manifold install on SR20
I did a search on this but couldnt find any useful information. I ve been tryin to install it but I dont wanna connect something wrong. I already took out the stock manifold, fuel rail and the throttle bodynd all the hoses. Just need a good referance for the install. I would luv to find a good write up with pics... btw i got a rhd s13.
thnx
ottamania is offline   Reply With Quote
Old 01-30-2009, 11:19 AM   #2
ByeByeSti
Banned from the Marketplace
ByeByeSti has a brilliant futureByeByeSti has a brilliant futureByeByeSti has a brilliant futureByeByeSti has a brilliant futureByeByeSti has a brilliant futureByeByeSti has a brilliant futureByeByeSti has a brilliant futureByeByeSti has a brilliant futureByeByeSti has a brilliant futureByeByeSti has a brilliant futureByeByeSti has a brilliant future
im also with you on this one, im installing mine today
ByeByeSti is offline   Reply With Quote
Old 02-16-2009, 11:46 PM   #3
jdm styles
jdm styles will become famous soon enoughjdm styles will become famous soon enoughjdm styles will become famous soon enoughjdm styles will become famous soon enoughjdm styles will become famous soon enough
any luck with your installs
jdm styles is offline   Reply With Quote
Old 03-31-2009, 08:01 AM   #4
alfredos13
alfredos13 is an unknown quantity at this point
That makes three of us. If you guys find any instructions please post
alfredos13 is offline   Reply With Quote
Old 03-31-2009, 10:42 AM   #5
brian m
brian m's Avatar
brian m has a reputation beyond reputebrian m has a reputation beyond reputebrian m has a reputation beyond reputebrian m has a reputation beyond reputebrian m has a reputation beyond reputebrian m has a reputation beyond reputebrian m has a reputation beyond reputebrian m has a reputation beyond reputebrian m has a reputation beyond reputebrian m has a reputation beyond reputebrian m has a reputation beyond repute
http://zilvia.net/f/tech-talk/211615...-write-up.html
Originally Posted by Dousan_PG View Post
dont ask if you wont take the advice
god...... some of you guys suck some serious testicallage
brian m is offline   Reply With Quote
Old 03-31-2009, 08:38 PM   #6
V8slayr
V8slayr is on the path to ruinV8slayr is on the path to ruin
I just installed my ISIS manifold and it was alot easier than I thought. I did it w/ the motor on a stand but it may be a bit tougher while the engine is in the car. If you already have everything disconnected it's pretty straight forward. Obviously swap the throttle body and IACV over to the new manifold. The only things that you need to re-route are the coolant lines to the IACV which is easily done w/ longer hoses. The other coolant lines that bolt to the block and head go back on as normal. You may also need to extend the coolant lines to the throttle body, but I chose to leave them off and bypass the coolant to the throttle body. As far as fuel lines to the rail, I haven't gotten there yet. But will just use longer fuel hose and route it as necessary. There should be some vacuum fittings also that go on the manifold under the throttle body and one or two on the back of the manifold. You will need to install the necessary fittings, the one on the back that runs to that line againts the firewall, and my ISIS manifold had plugs to block the holes that I didn't use. Hope this is of some help. If you have any more questions feel free to ask.
V8slayr is offline   Reply With Quote
Old 03-31-2009, 10:14 PM   #7
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Also, good idea since you got the manifold off...check all the rubber coolant hoses underneat. If they look old/dry rotting, now is the time to replace them all.
CLICK HERE!!!
Old 04-09-2009, 11:18 PM   #8
93 Sr Hatch
93 Sr Hatch's Avatar
93 Sr Hatch is an unknown quantity at this point
is that manifold better than the greddy???
93 Sr Hatch is offline   Reply With Quote
Old 04-10-2009, 09:48 AM   #9
CamryOnBronze
CamryOnBronze's Avatar
Trader Rating: (131)
CamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud of
Feedback Score: 131 reviews
Send a message via AIM to CamryOnBronze
Originally Posted by brian m View Post
That is a great writeup, thanks for the heads up!
CamryOnBronze.com
CamryOnBronze is offline   Reply With Quote
Old 03-29-2011, 06:57 PM   #10
jdmboii310
jdmboii310 is an unknown quantity at this point
hey i used to own a honda civic and i upgraded to a stock 240 93 coupe and i had a sr20de swap and now its boosted with the greddy turbo kit i jus bought. im still kind of a noob on the sr so can u guys help me on where the lines go to like the line from the valve cover where does that end up to? because the godspeed intake manifold elimnated the two ports...
jdmboii310 is offline   Reply With Quote
Old 03-30-2011, 07:08 AM   #11
onehundredoctane
onehundredoctane's Avatar
onehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfection
Godspeed. There's your problem.
onehundredoctane is offline   Reply With Quote
Old 03-30-2011, 07:23 AM   #12
jdmboii310
It was free. So I didn't mind puttinng it on. I was goin to get the greddy.
Old 06-11-2012, 11:28 PM   #13
Az240sxs13
Az240sxs13 is an unknown quantity at this point
Hey what did you use has the nipples under the.manifold? Am stuck I cant find nipples anywhere. It would be so helpful thanks.
Az240sxs13 is offline   Reply With Quote
Old 06-13-2012, 12:43 PM   #14
eek
Trader Rating: (29)
eek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud of
Feedback Score: 29 reviews
godspeed + florida =
eek is offline   Reply With Quote
Old 07-10-2012, 09:39 AM   #15
sldwayz1
sldwayz1 is an unknown quantity at this point
Thumbs down
This ^ guy from the state who tried to legalize gay marrage.... HOMO
sldwayz1 is offline   Reply With Quote
Old 07-10-2012, 04:15 PM   #16
fliprayzin240sx
Home depot, Lowes or Ace hardware should have fittings.
CLICK HERE!!!
Old 03-02-2013, 08:24 PM   #17
singlejzpower
singlejzpower's Avatar
singlejzpower is an unknown quantity at this point
great write up cant get much better!
singlejzpower is offline   Reply With Quote
