Old 10-07-2018, 04:23 PM   #31
supersayianjim
supersayianjim's Avatar
supersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enough
Finally installed my oil cooler lines/tree and cooler. now it's ready for engine wiring and to mount some beefier bumper mount bolts.
and started measuring the exhaust/downpipe situation. going to be 3inches all the way back
supersayianjim is offline   Reply With Quote
Old 10-07-2018, 04:23 PM   #32
supersayianjim
Now onto the wiring nightmare, had to strip out the stock z24i engine wiring harness. hopefully I don't need any plugs off it.
setting up my mobile soldering station
Old 10-07-2018, 04:24 PM   #33
supersayianjim
seeing as this harness is fuckery as it's connected to the engine AND the interior I previously cut it because I was thinking I can send away and get a plug and play. BUT apparently that didn't happen.
so now im trying to re-construct what I need and what I don't.
got the harness line and the ecu where I want it to be
I actually made a alt/battery harness (combined the oem and an extra rb25 one I had laying around). also created a new battery cable and made a master negative cable for all the accessories.
got a master block to house all of my fuses.
and here is were we are now... got to separate, extend, and cut this to fit!!
Old 12-01-2018, 06:12 PM   #34
supersayianjim
coming along with more wiring , thinking I finally got what I needed extended and cut what I needed cut.
and also installed the alarm horn too. got the right length of my o2 sensor also.
cleaned up my "happy" corner
so next up was the ignitor/coil setup. apparently the z24i one is different, so I had to source a 240sx coil and ignitor, using the z bracket...
Old 12-01-2018, 06:13 PM   #35
supersayianjim
so this is my first custom swap. and this wiring was a bitch in the first place, so I opted for the nifty can-am box that makes Nissan swaps a snap.
after fabbing up a custom bracket I finally got a place to mount this.
after the easy to follow wiring diagram it was working
the other side was used for the fuel pump relay
here is my map sensor/iat sensor(for the moment) set up.
got the first piece of my downpipe fabbed up, cleared the brake master cylinder.
and I need to wire up my knock sensor
Old 09-21-2019, 11:12 AM   #36
snags
snags's Avatar
snags is an unknown quantity at this point
How is this project coming along? Im currently stuffing a 5.3 into my 1987 2 door pathy. We are running into similar problems! including rust under the rear seats.
this was a good read hoping to hear how it turned out
snags is offline   Reply With Quote
Old 11-04-2019, 08:16 AM   #37
supersayianjim
well I haven't been updating on this because there seems to be 0 interest. I have more in depth on infamous
http://www.infamousnissan.com/forum/...ad.php?t=42105
