03-21-2016, 12:30 PM | #6001 | |
But you can also buy this set from spal, it comes preassembled in the shroud already. http://www.summitracing.com/parts/sp...2130/overview/ You also need a 50A relay for each fan to run. Its a very robust setup, and moves a shit ton of air.
-Kyle |
03-21-2016, 12:47 PM | #6002 | |
03-21-2016, 12:49 PM | #6003 |
No idea on pusher. Never was an option for me, I dont think they offer enough cooling capacity.
I had to cut into my core support by 2" to push the radiator back to get it all to fit. It was worth it, and looks great.
-Kyle |
03-21-2016, 08:50 PM | #6005 | |
I had to hammer the firewall to get into place in my s14. I also got the collins adapter and I am definitely not happy with it. It was off centered and one of the threads were hanging right off the plate couldn't even run a bolt there. Contacted him he said he would send a new one then never responded. |
03-22-2016, 03:35 AM | #6006 | |
03-22-2016, 04:04 PM | #6007 | |
03-24-2016, 09:48 PM | #6008 |
Well, got it running and on the road. However, I'm having some stuttering at WOT/full boost, which is 14psi right now. Sounds/feels like its missing on 1 cylinder. So I gotta sort that out, its kinda inconsistent. But feels good when it runs right.
-Kyle |
03-25-2016, 04:43 PM | #6009 |
I would check your coil packs for cracks along with the rubber boots. Had the same problem, thought it was fuel/boost cut (that just feels like you hit a brick wall lol)
93 s13 Vert - 2jz/cd009 -- parted/sold 95 Supra Turbo |
03-25-2016, 05:38 PM | #6010 |
Yea, unfortunately I have to say that I have brand new oil packs from autozone lol But I agree, it feels like spark issues, I'll have to do some parts switching to figure it out
-Kyle |
03-26-2016, 06:05 AM | #6011 |
03-26-2016, 10:06 AM | #6013 |
If they're just not up to the task of high power but they're in otherwise good shape then I would suggest getting the hks ignition amplifier. My buddy made 1425 whp in his Supra with just stock coils and the hks ignition amp. I ended up going with LS truck coils which are great but you need to be able to control them with an ecu.
03-26-2016, 12:45 PM | #6014 |
Yea, I'll be stock ECU for a while. I might look into that ignition amp.
I have 3 buddies who are all making 500+whp on these same coils from AutoZone. I guess I might just have a bad one or too. Gotta do some testing this weekend.
-Kyle |
03-26-2016, 10:33 PM | #6015 |
EDIT:
Well found that 4 of my 6 brand new AutoZone coil packs are already cracked...less than 100 miles lol Guess I should have known better by trying to save a buck haha Thankfully I can full return/refund them What does everyone run for coils on these cars if you are maintaining stock ECU? I know AEM guys go with LS coils, and SR guys run splitfire, but I really haven't found a nice aftermarket coil set for these? How do you beef up the ignition on these engines with stock ECU?
-Kyle |
03-26-2016, 11:11 PM | #6016 | |
03-27-2016, 12:07 PM | #6018 | |
was told Freed Engineering mounts are they way to go. I was thinking of ordering me a set for when i am ready to drop my motor in. maybe someone who is actually running his can chime in and confirm. |
03-28-2016, 03:11 AM | #6019 |
Have heard good things about the SuperSparks from a few people.
http://www.suprastore.com/suco1jupsp.html Had bought a set for a 1.5JZ then sold the motor to a friend who decided his stock 1J needed to pop. Never got a chance to test em out.......nor has he since car isn't running yet....Jeeps taking over all his free time now.
03-28-2016, 10:40 AM | #6021 | |
The coil wiring is usually pretty crispy and crappy by now too. After I rewired my oem jdm coils I made 550whp on them. They are just sitting here in a box now, send me an offer on them if you want them. |
03-28-2016, 12:20 PM | #6022 |
Thanks man. I think I am just going to buy brand new Denso factory coils. You can get them on rockauto, and they are the OEM manufacturer.
-Kyle |
03-28-2016, 02:21 PM | #6023 | |
http://www.maperformance.com/product...nd-2jz-engines
DLG - DIRTYLOVE |
03-29-2016, 08:10 AM | #6026 |
I am not sure, I know the guy that designed them was running a Haltech on his car so that may be true. I guess a good option if someone is stand alone though.
DLG - DIRTYLOVE |
03-29-2016, 10:50 AM | #6027 |
Trader Rating: (53)
Feedback Score: 53 reviews
I have an AEM V2, but my harness is wired for the factory setup. I can only assume that once you unplug the factory ignitor that you would have to put a jumper of some sort between those two connectors.
: @e_lemonation |
03-29-2016, 01:42 PM | #6029 |
Trader Rating: (53)
Yeah, I think I saw that too while doing a brief search. I'll have to look into it because if it involves hacking up my new harness, I just can't get down with that.
: @e_lemonation |
03-29-2016, 04:36 PM | #6030 |
I have the xcessive brackets and mounts for engine and trans on my s13. the jz fits under the hood just fine. and i have enough room to run my strut tower brace.
