Old 01-12-2024, 11:28 PM   #991
slider2828
slider2828's Avatar
OK kiddos.... for further driveline tuning, this thing makes a lot of noise if you don't do it right.... I would use CA18DET engine mounts or drift freaq mounts which sit the engine 10mm lower.... You then need to raise the tranny as high as you can.... In my car, when I did this..... the output of the tranny is pointing down -2.5* whereas my rest of the driveline -1.7*....
If you aren't sure how to do this...use this and an angle finder
https://spicerparts.com/calculators/...gle-calculator
or Tremec toolbox on your phone through any app store.... make sure you take your case off your phone to measure accurately.....
Turn and Burn!
Old 01-16-2024, 01:14 AM   #992
slider2828
slider2828's Avatar
Well shit for posterity and people tracking their cd009 my tranny started leaking in the bell housing. I didnt know this but some people say the bottom screw needs sealant....
In the end put fucking sealant on all the screws. I will probably use locktite blue that has built in thread sealant... geezus...
Will be pulling the tranny and changing, the input shaft seal, front housing seal and adding sealant on the screws... ugh...
Turn and Burn!
Old 02-14-2024, 11:41 PM   #993
bl3ujay07
bl3ujay07's Avatar
bl3ujay07 is an unknown quantity at this point
Originally Posted by slider2828 View Post
Hey All,
Installed and it worked!!! The install was soooo easy. But you do need to remove the dash. Pulled constant 12v and acc 12v from the ignition tumbler. Then ground from anywhere. Then cut and wire in a wire from the dash (wire 6 y/lavendar) to speed 2 which is a sine wave and 16ppm setting.... now you have a gps and accelerometer speedo.
[img size=150]https://i.imgur.com/2iT0uXO.jpg[/img]
Thanks for sharing this! Your post led me to buy the same exact Dakota Digital unit along with the optional antenna. It?ll be nice to have a working Speedo again with a soon to swap Srvq kit.
bl3ujay07 is offline   Reply With Quote
Old 02-15-2024, 11:27 AM   #994
slider2828
slider2828's Avatar
Cool it works perfectly.... Very easy to wire... I forgot if I put it on Speed 1 or Speed 2..... and I used 20k PPM.... (I think its speed 2).
I have a kph jdm nismo cluster. But works perfectly.... Just doesn't work in a garage hahaha....
Turn and Burn!
Old 02-15-2024, 05:35 PM   #995
bl3ujay07
bl3ujay07's Avatar
Are you using the optional antenna for range? I have a dash cover with a ton of velcro to hold it down. I plan to mount the antenna in the center of the dash under the cover.
Also, your previous post mentioned using 16k PPM. Are you using the 20k PPM setting because of the kph cluster?
Old 02-16-2024, 10:20 AM   #996
slider2828
slider2828's Avatar
It could be because of KPH, that would make sense. Those are hardcoded PPMs in the module, so you can try a few settings.
I would assume under the cover is fine.... but I am not a radio technician so I have no idea..... I have to use the optional antennae because the module itself is setting behind the radio on the tranny tunnel. Its deep in the dash where there a lot of metal and radio antenna and grounding stuff...
I think the optional antennae under the dashboard cover overlay SHOULD work but its not very flat. Its about same thickness as a zippo lighter and about half the size.....
Turn and Burn!
