Old 06-21-2017, 06:34 AM   #781
hanzbrady
hanzbrady's Avatar
hanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura about
Originally Posted by jr_ss View Post
Hanz, what was the exhaust side flow numbers on that head? If anywhere needs work, it would be on the exit side of the head to increase velocity through the head. That would aid in spool up tremendously.
Just so people are aware, this is a 90mm bore drawing these numbers. A smaller cylinder is going to effect overall numbers. Any chance you have a standard bore to produce numbers on? I understand you've probably CNC'd the combustion chamber for this head. However, it would be beneficial to have numbers on a head that doesn't go "balls to the wall".
Keep me posted on the development of your "product" you contacted me about. I will need some lead time to get the car to you and square some things away with you guys.
Hey man,
Will do on the product development, as per the flow charts I'm trying to get new ones every day, looks like a stock S13 head is up for today so we'll have some awesome comparison between the VE and DET!
Now about those billet intakes I was teasing, more teasers!
[email protected]
hanzbrady is offline   Reply With Quote
Old 06-21-2017, 08:15 AM   #782
hanzbrady
hanzbrady's Avatar
Also as promised here's the flow of a stock DET head, this is an S14 not an S13. The S13 will be available in a couple of days.
[email protected]
Old 06-21-2017, 09:54 AM   #783
RalliartRsX
Trader Rating: (32)
Feedback Score: 32 reviews
I expect the S13 to flow a little more with the bigger intake ports and all
Old 07-17-2017, 10:03 AM   #784
hanzbrady
hanzbrady's Avatar
Hey guys, this is a bit off topic but since a lot of my customers frequent this thread I just wanted to let everyone know that starting the 1st of August I will no longer be with Mazworx. I will be transferring over to Real Street and look forward to still providing you guys with insight and deals.
So the TLDR, if you want Zilvia pricing on Mazworx parts you have about a week and a half to get it!
[email protected]
Old 07-17-2017, 10:54 AM   #785
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
WTF?!?!?! dam im going to have to hit you up for some parts here pretty soon then
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 07-17-2017, 11:02 AM   #786
hanzbrady
hanzbrady's Avatar
Haha, let me know man!
[email protected]
Old 08-01-2017, 10:24 PM   #787
livelovesole
livelovesole is an unknown quantity at this point
I'll be purchasing the mazworx vvl conversion kit within the week and have some questions about the iacv and throttle body. I've researched online about other setups and see alot of different answers. If i go for the q45 throttle body, what year do you prefer to use? I also see that Mazworx sells a ross 75mm throttle body or i can go with a mustang one was well (not sure of year/model, etc). Which throttle body do you guys see the best results with? And also, is there a preferable iacv to utilize?
livelovesole is offline   Reply With Quote
Old 08-02-2017, 06:55 AM   #788
hanzbrady
hanzbrady's Avatar
All Q45 TB's are the same, the Ross 75mm is the better street car tb and the 90mm is good for higher horsepower applications. The q45 is the least ideal choice of the 3 as it is just so damn bulky. As for IACV use whatever one you have now. They all function the same.
[email protected]
Old 08-02-2017, 10:06 AM   #789
livelovesole
Thanks for the input Hanz. What tps do you run with a Ross tab though?
Old 08-02-2017, 10:11 AM   #790
hanzbrady
hanzbrady's Avatar
Generic Ford style, also found on Mazworx's website.
[email protected]
Old 08-04-2017, 12:18 PM   #791
livelovesole
How much power would you say is rated for a 75mm tb vs a 90mm? I keep trying to look up references but not many 75mm users out there and everyone says 90mm for big hp (when is it efficient?)
Old 09-10-2017, 01:56 PM   #792
livelovesole
I was hoping to get some help on deciding which turbo to run Or any recommendations. I've done my fair share of research and I'm deciding between a gt3576, gt3582, or maybe even a 3076 if it can get me the hp I want without maximizing the efficiency of the turbo. I'm shooting for around 550-600. I know I can't have best of both worlds as far as response and power but I want something can come as close as possible. A brief list of mods:
p12 head & cams +1mm in +2mmexh valves
Mazworx intake manifold with 82.5mm mustang tb
Doc race dual waste gate twin scroll t3 exhaust manifold
Id1300cc fuel injectors (E85)
Sleeved block (86mm bore 9.0 compression)
More than likely Haltech ecu
What turbo do you guys have had experience with or any info on that'll help me achieve my goal, even if it's not one of the choices I stated earlier. Any info helps.
Old 09-10-2017, 03:41 PM   #793
jr_ss
Gtx3576 in .63 is what I would run. GTX3076 .84 on my car now. Should've gone with the smaller backside, but have options in decrease spool time.
Old 09-10-2017, 08:21 PM   #794
livelovesole
It seems like a great option, just want to see if there's any feedback on it. Seems like a good amount of dsm guys run it. When are you seeing full boost on your setup?
Old 09-11-2017, 05:55 PM   #795
TheRealSy90
TheRealSy90's Avatar
Get a Borg Warner EFR of some sort.
Such a good signature.
Old 09-12-2017, 07:16 AM   #796
jr_ss
I see full boost at roughly 4500rpms. Keep in mind I have the worst cams you can run for boost response. I also do not have my cams optimized. N1's sitting on the shelf currently waiting install and a retune. The smaller backside would yield better response as well. I enjoy the nice fat mid range and high rpm pull my setup provides though.
If I were starting from scratch, I would absolutely run one. I had most of my exhaust components already. I also would've had to wait quite a while, if you remember, the EFR's were delayed release multiple times.
Old 09-12-2017, 07:29 AM   #797
TheRealSy90
Should be able to get one in any turbine flange you have.
Old 09-12-2017, 07:34 AM   #798
RalliartRsX
Trader Rating: (32)
I may end up unloading another 7163 Super Core I have sitting on the shelf.
Old 09-12-2017, 09:38 AM   #799
600supersport
600supersport's Avatar
600supersport is an unknown quantity at this point
With the VE's ability to optimize cylinder pressure, I'd go 62mm EFR/GTX or down to the EFR7163
600supersport is offline   Reply With Quote
Old 09-12-2017, 09:42 AM   #800
RalliartRsX
Trader Rating: (32)
7163 is making 600+ awhp. Just ask the evo guys.
Yeah, the little "60 lb" turbo that could
Old 09-16-2017, 03:07 PM   #801
Hyaboosta
Hyaboosta is an unknown quantity at this point
600supersport, how did you get the nismotronic wired in to control the vvl solenoids?
Hyaboosta is offline   Reply With Quote
Old 09-16-2017, 03:46 PM   #802
600supersport
The Sr20/Sr22vet thread
I ran the 12v from a relay, the intake cam to generic output pin #111 (wg solenoid) and the exhaust cam to #25 (high EGTL).
Old 10-08-2017, 06:12 PM   #803
gt3071r240
gt3071r240 is an unknown quantity at this point
OK I have searched through the thread and have not found the answer...
I am in the middle of a mazworx VVL conversion on my currently built bottom end. I just want to verify that you can run 9:1 CP DET pistons using an apexi 1.8mm headgasket with the VVL setup using P11 Cams.
gt3071r240 is offline   Reply With Quote
Old 10-08-2017, 06:21 PM   #804
RalliartRsX
Trader Rating: (32)
Short answer is yes.
Do the pistons have valve reliefs??
Old 10-08-2017, 06:24 PM   #805
gt3071r240
No reliefs
Old 10-08-2017, 06:36 PM   #806
RalliartRsX
Trader Rating: (32)
You should be fine. What's the dish measurements?
Old 10-08-2017, 06:49 PM   #807
candyred_240sx
candyred_240sx is on a distinguished road
I run 8:5:1 det pistons with a p11 vvl head and tomei 1.8mm head gasket. Have run both n1 and kelford 292/303 cams with no issues. Did putty during assembly and had lots of clearance even with vvl locked on.
Although mazworx did the head work on my head and the way they set it up might have made more clearance as they knew I was running det pistons with no valve relief.
candyred_240sx is offline   Reply With Quote
Old 10-08-2017, 10:26 PM   #808
RZRSHARP_240SX
RZRSHARP_240SX's Avatar
RZRSHARP_240SX is an unknown quantity at this point
I run the n1 cams with no reliefs and haven’t had a issue with a 1.8mm head gasket
RZRSHARP_240SX is offline   Reply With Quote
Old 10-10-2017, 09:14 PM   #809
TEALSQUEAL
TEALSQUEAL's Avatar
TEALSQUEAL is making a name for him/her selfTEALSQUEAL is making a name for him/her self
Why is no one running taarks? Better pricing less bulky machining, and you don’t have to get the head machines to run a pickup.
TEALSQUEAL is offline   Reply With Quote
Old 10-10-2017, 10:38 PM   #810
RZRSHARP_240SX
I am running taarks things. It’s cheaper and works just as good.
