08-14-2017, 02:04 PM | #21271 |
So, I just picked up this Thrash seat and I was looking for some opinions on how to restore it a bit. It's pretty faded so I'm already thinking of re-dying it black but I dont want the letters to change color. Will RIT mess with the stitching? Also, the stitching is kind of falling apart. Should I just drop this off at an upholstery or embroidery place and let them handle it? Or can I hand stitch it back? Interior work isn't really my strong suit. Here's some pictures of the logo in its current state.
Follow me on Instagram or don't @cason880 |
08-15-2017, 12:55 PM | #21272 |
s13 steering issue
I was on the free way and i had dropped a gear to speed up as i did that my car quickly turned to the right by itself, even when i slowed down and i tried to switch lanes to the right as well my car would over steer, what can my problem be ?
08-15-2017, 02:42 PM | #21273 | |
08-15-2017, 04:28 PM | #21274 |
Are manual swapped 240s good? Like would the swap be significantly worse than a factory done manual transmission? or are manual swaps pretty much just as good.
my pal says that itll never been the same as a oem manual..... |
08-16-2017, 01:12 PM | #21276 |
S14 In-Bay Brake Line Tuck
So I have some Enjuku rewards points and was looking for something to buy to use them. I still have a few things to get while I am doing this here swap thingamajigger.
I was looking at the Chase Bays In-bay Brake Line relocation kit, and the reviews suggest that while it is well made, it is not long enough to actually run under the engine/tranny like they suggest. That's a no-go for me since the main reason I want to tuck them is to get the hard lines off the firewall. Every plastic clip is either broken or just looks shitty, plus bending the lines around to mate to the Z32 master cylinder left them looking sort of wonky. Structurally they are fine, but they just don't look right. It would also free up the area around the MC for the downpipe off the top mount turbo. So I started looking into building my own and put together a list from anplumbing. I have attached a screenshot of my shopping cart. Can someone take a look and let me know if I am missing anything? I'm pretty sure I have everything needed, but wouldn't want to overlook something stupid. I think 15 feet of PTFE hose will be enough, but haven't actually pulled a tape in the engine bay to confirm. I'd honestly rather have more than I need. Oh, the Z32 master has the 3rd fitting cone seat installed so the S14 hard lines would match. |
08-18-2017, 01:33 PM | #21279 | |
08-18-2017, 01:39 PM | #21280 | |
Trader Rating: (92)
Feedback Score: 92 reviews
That's the stupidest thing I've ever heard, adding manual isn't the same as a factory one. Lol wow *dead when done CORRECTLY there is NO DIFFERENCE AT ALL wouldn't want to take anymore advice from said "friend" he might just tell you that swapping over to Z32 brakes dual pistons are worse and you should leave it OEM single piston Sent from my iPhone using Tapatalk |
08-19-2017, 08:54 PM | #21282 |
Anybody have any personal experience with these seats? I don't have them in person. Curious if there'll be enough headroom to fit in an S14, with custom seat brackets.
08-20-2017, 05:52 AM | #21285 |
I own a 1991 s13 240sx and I would like to ask about wheel fitment. I want to get cosmic mr7 18x9 +25 but I don't know what size tire I should get to make the wheels fit I was think a 235/40/18 all around I've searched all around but not a lot of People run 18s in 240sx please help. I'm okay with rolling or pulling fenders and I have Bc br racing coilovers for suspension.
08-20-2017, 10:38 AM | #21286 |
GibsonS, try searching rimtuck. Found this one there;
Black coupe F: 18x9 +25 245/35R18 R: 18x9 +25 255/35R18 http://rimtuck.com/photos/2101/1463770809.jpg Search result: http://rimtuck.com/search/thumbnails...idthr=9&sort=1 |
08-20-2017, 11:48 AM | #21287 |
Those seats, if real, would have come out of a Nismo S-Tune GT 350z. But they were faked pretty often by a now defunct company called X3 Racing. Fingers crossed its real because its a relatively rare seat. Only 20 per month were made during production and the price was nearly $60k new. I'd imagine they would fit the same as other 350z seats which is a bit higher than s14s.
08-20-2017, 12:28 PM | #21288 |
I saw them in Jap auctions. Was about to buy it through Jesse but shipping was a shit ton. Description said it came out of Nissan Micra K12 not sure if authentic or not.
08-20-2017, 03:59 PM | #21289 | |
08-20-2017, 04:05 PM | #21290 | |
08-21-2017, 01:25 PM | #21291 |
I bought a japspeed elbow-downpipe-cat for my s14a but the damn downpipe doesnt fit if I keep the heat shield above it and even if I didn't it still hits the body of the chassis. It was advertised as bolt on fitment but even the bracket on the downpipe is waaay off the chassis, would a flange spacer on elbow fix this?
08-21-2017, 01:42 PM | #21292 |
ITS LISA'S FAULT!!!
Trader Rating: (41)
Feedback Score: 41 reviews
sounds like you skimped out and bought a cheap knock off part... should probably throw it in the garbage and get something else. not being a dick, just saying that a lot of cheaper parts tend to fit poorly.... or you can always have it cut and rewelded to fit properly
honestly, one of the best "affordable" down pipes ive ever used is Megan due to it being one of the few to have a built in flex section. not only does this help in fitment angles, it prevents vibrations and movement in the exhaust section from rocking your turbo loose. |
08-21-2017, 02:01 PM | #21293 |
Well it was a decent priced flexi downpipe and it seems pretty good quality for the price, BUT the parts are for s14 zenki but I got the elbow-downpipe-cat so japspeed stated it would fit then, but idk I think I'll buy a flange and just weld a better fitting bracket or try to reuse the old one. If it still doesnt fit I'll prob buy a megan pipe
08-23-2017, 12:37 PM | #21295 |
Alright so I got the new exhaust and it works but it doesn't have a hole for the second O2 sensor or temp sensor so now my wideband shows 20:0 all times, should I get a nut welded to the decat pipe for it or whats the best solution?
08-23-2017, 01:00 PM | #21296 |
Best option is to have a bung welded on for the second O2 sensor.
08-23-2017, 01:42 PM | #21297 | |
https://www.summitracing.com/search/...ounting-clamps
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 | |
08-26-2017, 03:55 PM | #21299 |
Soon I will be doing a smog check on a 240 I just purchased, the issue is the car doesnt have a cat atm, i went to a nearby Nissan parts store and they quoted me $350 for an OEM cat, to pass smog does it matter if the cat is OEM, also is there any specific things to look for when buying an aftermarket cat?
08-26-2017, 04:22 PM | #21300 | |
