Old 08-31-2022, 04:40 PM   #1
S14Gio
S14Gio's Avatar
S14Gio is an unknown quantity at this point
Question S14 Exhaust Question
Hey all, I'm looking into new exhausts for my s14. Currently the Megan exhaust that came on the car hangs pretty low and has pretty much become a semicircle on these garbage roads out where I am. What exhausts have yall found that have decent ground clearance?
Thanks
Save the Zenkis
'95 240, '01 LX470
S14Gio is offline   Reply With Quote
Old 09-01-2022, 08:22 AM   #2
AKADriver
AKADriver's Avatar
Which Megan exhaust do you have? I think they've made 3 versions, their original cannon-style exhaust had OK clearance but people hated it because it sat too level and didn't have that slanted-up HKS/Greddy/APEXi look. So they revised it to hang lower, and then came out with a "low profile" version that had an OEM style oval muffler tucked in tightly. Also where is it hitting? Lots of variation between exhausts in terms of the axleback/muffler area but if your midpipe or resonator are hitting that might be more of an install issue or your hangers are haggard.
Old 09-01-2022, 11:33 AM   #3
jr_ss
Have you tried shorter rubber hangers? Have you replaced the older ones? Usually the low spots are back by the rear axle.
There are various that still have poor clearance and that is relative to how low your car is. If it is slammed, you are t going to find a suitable alternative.
Old 09-07-2022, 01:01 PM   #4
S14Gio
S14Gio's Avatar
I believe it's the second one you mentioned as it's non-resinated and has the cannon style muffler rather than the OEM oval one. On their website, Megan lists it as the Long Tip Turbo Type. It rubs pretty much everywhere, but it's particularly bad around the curved part of the midpipe and around the muffler. I checked the hangers and they aren't in horrible shape. The exhaust tip sits fairly close to the bumper so it seems like they're doing their job.
Thanks for the info man
Save the Zenkis
'95 240, '01 LX470
Old 09-07-2022, 01:09 PM   #5
S14Gio
S14Gio's Avatar
Haven't tried the shorter hangers but I'll probably order some Gktech poly bad boys and see if they help. The ones currently on there don't seem to be in that bad of shape but new ones probably won't hurt. It seems like this exhaust is one of the lower-hanging ones, as it sits a good few inches below the diff at its lowest points. The car is about an inch from being fender-to-lip on 17" rear wheels so that definitely doesn't help with exhaust clearance lol
Save the Zenkis
'95 240, '01 LX470
Old 09-07-2022, 03:00 PM   #6
AKADriver
AKADriver's Avatar
Okay then. If you need the exhaust to sit higher then look for ones that have a tighter S-bend where it passes under the diff. This usually comes with an OEM style muffler. This style gives a ton more ground clearance because it doesn't try to "straighten the curve" and tucks in like OEM. Like HKS Sport or APEXi World Sport.
Old 09-07-2022, 07:21 PM   #7
S14Gio
S14Gio's Avatar
Gotcha, thanks!
Save the Zenkis
'95 240, '01 LX470
Old 09-10-2022, 05:29 PM   #8
My240sx
My240sx's Avatar
My240sx is making a name for him/her selfMy240sx is making a name for him/her self
I used worm clamps around the bushings and they brought the exhaust up a good amount
My240sx is offline   Reply With Quote
Old 09-12-2022, 12:22 PM   #9
S14Gio
S14Gio's Avatar
I'll give that a shot, thanks
Save the Zenkis
'95 240, '01 LX470
exhaust
