Old 06-25-2016, 11:36 PM   #1
240trooper
240trooper's Avatar
240trooper is a well-known jackass
Send a message via AIM to 240trooper Send a message via Yahoo to 240trooper
s13 S13 5speed ka24de pass side fuse/ relay box and engine harness
Looking for s13 5 speed ka24de fuse/ relay box in the pass side engine bay and the engine harness that goes from the fuse / relay box under the radiator support to the driver side of the engine bay. I don't need the main engine harness or the transmission one. I just need the fuse/ relay box and engine harness #2. Best way to contact me is through text 562243eight655. Local pick up only please. Thanks!!
Go the main engine harness now I just need the other one and the fuse/ relay box.
2.7L
240trooper is offline   Reply With Quote
Old 06-26-2016, 02:07 PM   #2
kruked
Trader Rating: (37)
kruked is an unknown quantity at this point
Feedback Score: 37 reviews
What you discribed is all one harness in case you didn't know.
I like my bikes how I like my b¡tches...naked!
2014 Triumph Street Triple
kruked is offline   Reply With Quote
Old 06-26-2016, 02:17 PM   #3
240trooper
240trooper's Avatar
I did not know. Thanks for the info.
2.7L
Old 06-26-2016, 06:45 PM   #4
240trooper
240trooper's Avatar
Lol sorry but you are wrong. The main engine harness does go to the fuse box/relay and it does go to the drivers side of the bay after the distributer connector but there is another engine harness that plugs into the fuse/relay box that goes in between the battery and underneath the radiator support then to the driver side of the engine bay.
2.7L
Old 06-26-2016, 07:05 PM   #5
kruked
Trader Rating: (37)
This is one discription. When you said, "and" that was the interpretation that you were under the impression that they were 2 seperate harnesses.
These 2 harnesses are seperate harnesses all together.
What you are seeking, (from my interpretation) is the engine bay chassis harness. It runs from by the battery, (if it's a manual chassis harness) to the SMJ.
I should have worded it differently for you. Sorry that I confused you.
Old 06-26-2016, 09:51 PM   #6
240trooper
240trooper's Avatar
Lol now I'm confused. Ok so that second harness is part of the fuse box? If so I just need that then.
2.7L
Old 06-28-2016, 06:02 PM   #7
240trooper
240trooper's Avatar
Bumpity bump!!
2.7L
Old 06-28-2016, 06:52 PM   #8
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
He's telling you there's (3) harnesses inside the engine bay.
The BAY harness which has the 2 fuse boxes & runs into the SMJ behind the driver side kick panel.
The TRANS harness, which well, runs to the transmission
The ENGINE harness which you guessed it, plugs into the sensors and such on the engine itself.
WillEastS14:
mannn u whylin son.
but that shyt has SWAG
KA-T for life!
Old 06-30-2016, 02:21 AM   #9
240trooper
240trooper's Avatar
Got what I needed. Please close.
2.7L
180sx, harness, ka24de, kouki, sr20det
