Old 04-21-2016, 09:54 PM   #1
S13xg35
S13xg35 is an unknown quantity at this point
So I bought a used ISR Oilpan for an SR20det..
So I bought a used ISR Oilpan for an SR20det and it seems to be in fairly good condition. Only problem is it didnt come with the necessary hardware.
Also, the drain bolt is tiny as shit, and I am pretty sure every bolt on this pan uses an allen key.
I cant fit a 10 mm socket inside the 4 holes that use longer bolts so id imagine its something else holding them down.
I am awaiting a response from ISR Performance but I am just looking for anyone that has come across this issue and would like to help me out with specs so i dont purchase too short of bolts or even the wrong type.
This a couple of the last pieces of putting my SR back together after rod knock and i would hate to do it incorrectly.
Thank you so much for your help and I am looking forward to your responses.
S13xg35 is offline   Reply With Quote
Old 04-22-2016, 07:51 AM   #2
hanzbrady
hanzbrady's Avatar
hanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura about
The hardware is M6x1.00
My pan was missing hardware so I had to purchase some, I used M6x1.00 30mm (has to be allen head bolts) for the 4 longer bolts and the rest are M6x1.00 20mm
Also as for the drain plug it's the standard Nissan/Toyota thread pitch M12x1.25
ISR and P2M both make magnetic plugs for this thread pitch which would convert it to a hex style bolt.
[email protected]
hanzbrady is offline   Reply With Quote
Old 04-22-2016, 09:51 AM   #3
AllThingsGravy
AllThingsGravy's Avatar
AllThingsGravy is making a name for him/her selfAllThingsGravy is making a name for him/her selfAllThingsGravy is making a name for him/her self
I was just having this same problem this week if the oem plug doesn't fit being too small try an oil plug 1/2 x 20 that did it for me.
AllThingsGravy is offline   Reply With Quote
Old 04-22-2016, 10:05 AM   #4
hanzbrady
hanzbrady's Avatar
It's a metric thread pitch M12x1.25, not an NPT thread.
[email protected]
Old 04-22-2016, 10:08 AM   #5
AllThingsGravy
Trust me I tried my oem one m12 x 1.25 and I went out and bought one. Did not work.
Old 04-22-2016, 02:47 PM   #6
S13xg35
Thank you everyone for your responses
I too tried the oem drain plug and it did not work
Is there a metric size for the drain plug ?
Old 04-22-2016, 02:56 PM   #7
AllThingsGravy
The metric size is m12 x 1.25 but I told you try a 1/2 x 20 standard drain plug they have them at autozone etc...
Old 04-22-2016, 03:41 PM   #8
S13xg35
Did any of you have a problem with the oil baffle getting in the way?
Old 11-14-2022, 07:54 AM   #9
koukis13
koukis13 is a jewel in the roughkoukis13 is a jewel in the roughkoukis13 is a jewel in the roughkoukis13 is a jewel in the roughkoukis13 is a jewel in the roughkoukis13 is a jewel in the roughkoukis13 is a jewel in the rough
Yeah man, I took the oem baffle out and cut away all the edge that was touching the isr oil pan. Kept doing it until it cleared. Definitely a shitty copy by isr.
koukis13 is offline   Reply With Quote
240sx, isis, oilpan, s13, sr20det
