Old 03-09-2014, 09:41 PM   #3091
Blackzenki82
Blackzenki82 is an unknown quantity at this point
Send a message via AIM to Blackzenki82
Here's how the rears sit now, plenty of gap hahah (obviously fit like super crap with the spacers, remember, just a test fit to see if I liked the white on white), so imagine 25mm less spacers, and 30 more mm sidewall as the current tires are toasted 235/40's.
currently, I'm on Tein S-techs and GR2's, so mad ass, I should have similar fitment? to you?
Blackzenki82 is offline   Reply With Quote
Old 03-09-2014, 09:43 PM   #3092
jr_ss
You have anything from the rear, looking down the side Marshall?
Old 03-09-2014, 10:34 PM   #3093
silviaks2nr
silviaks2nr's Avatar
Unless you want to pull the hell out of your fenders you need a higher offset and wider wheel to be able to use those 8 tires you got.
Old 03-09-2014, 10:49 PM   #3094
mad-ass
mad-ass's Avatar
Yes, I can post more pics if you'd like as I am also on tein s-tech and gr2's.
but remember this also, with the tein s-tech, by the time the suspension compressed enough to get in contact with the fender, you might have enough camber to clear it even if you have 0 camber at static height.
if I get bored enough, I'll do an experiment on my car tomorrow since I know i'm at 0 camber at static height.(good excuse to move my car out of the garage for once, do that drive way wheel tucking experiment. LOL)
Old 04-01-2014, 07:54 AM   #3095
CornSpeed
CornSpeed's Avatar
CornSpeed is an unknown quantity at this point
To anyone,
I was looking to run the same size tires as Toby on my s13... 245/35 and 285/30. What width and offset should I run on factory fenders. I don't mind rolling and pulling, but I would like to avoid notching my control arms. Any info would be appreciated.
CornSpeed is offline   Reply With Quote
Old 04-01-2014, 12:05 PM   #3096
mad-ass
mad-ass's Avatar
9.5+15~20 in front, 10+38~25 to 10.5+30 ish in rear.
the amount of fender work needed will depend on your ride height.
Old 04-01-2014, 12:21 PM   #3097
jr_ss
I'd put a 9 +20ish up front and a 10 +30ish out back. 285's will fit just fine on a 10.
Toby has an 11" wheel out back.
Old 04-01-2014, 12:24 PM   #3098
CornSpeed
CornSpeed's Avatar
Thanks for the info guys. It's probably gonna be a while before I get wheels for this thing, but I'll keep those specs in mind
Old 04-01-2014, 12:58 PM   #3099
simmode1
simmode1's Avatar
simmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfection
Send a message via Yahoo to simmode1
Keep in mind, Toby had widebody Chargespeed fenders up front & filled in the vents to make the fenders look oem. Most might have a hard time trying to match his setup with stock fenders...
simmode1 is offline   Reply With Quote
Old 04-01-2014, 01:00 PM   #3100
CornSpeed
CornSpeed's Avatar
I'll keep that in mind. I don't plan on going too much lower than stock, so hopefully I can pull it off without too much fender work
Old 04-01-2014, 02:02 PM   #3101
spooled240
spooled240's Avatar
spooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfection
Originally Posted by jewlz View Post
^specs for the rear? i'm kinda diggin this functional setup
18x9 +25 255/35r18 all around
spooled240 is offline   Reply With Quote
Old 05-01-2014, 08:59 AM   #3102
turbo2nr
turbo2nr's Avatar
turbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enough
Send a message via AIM to turbo2nr
18x9.5 + 27 can i fit a 265/35/18 up front?
do i need to run a spacer to clear the coil. Im assuming so.
Stock pulled fender btw
s14 kouki ka-t
turbo2nr is offline   Reply With Quote
Old 05-01-2014, 01:28 PM   #3103
mad-ass
mad-ass's Avatar
I had about 3mm clearance with 17x9+23's up front with Stance coilovers, so just going off of that, yes you'll need spacers to clear the coilovers.
and looking at your ride height in your sig, you'll have hell of a time clearing the fender in front with that tire size. you might be better off using 255/35/18's.
Old 05-01-2014, 01:35 PM   #3104
waxball88
waxball88 is an unknown quantity at this point
Cleaned up that amatuer blackzenkis work above me on a locals car.
275/40
17x9
Massive pull to allow for camber adjust and such
waxball88 is offline   Reply With Quote
Old 05-01-2014, 01:48 PM   #3105
turbo2nr
turbo2nr's Avatar
Plan to raise the car 1/2" and take out some camber tired of this damm hellaflush look. I would like to actually drive the shit out of my car LOL
I think i may try a 7mm slip on space in front and maybe a 15mm space out back.
Thanks
s14 kouki ka-t
Old 05-12-2014, 07:59 PM   #3106
Nikzilla
Nikzilla is an unknown quantity at this point
I wanna go with 18x9.5+15 235/40/18 all around on my S13.
Will the fenders survive the pull?
I did some measuring and the rim should clear the coilovers like 1-2mm, so this is as far in as I can push these fatties.
Nikzilla is offline   Reply With Quote
Old 05-12-2014, 08:04 PM   #3107
Yellow4g63
235 on a 9.5" rim isn't max tire.
95 240sx RB20 415whp
91 Nx2000 VVL yo
Old 05-12-2014, 08:06 PM   #3108
jr_ss
Yep, not max tire at all. Please procede to the stretch thread or wheel fitment thread for your answer.
Old 05-12-2014, 08:07 PM   #3109
Nikzilla
Old 05-12-2014, 08:18 PM   #3110
Yellow4g63
On I side note I got my 531's mounted with tires and the rear is going to need a good tug .
255-40-17 front and 275-40-17 in the rear. BFG comp sport 2's they look huge.
91 Nx2000 VVL yo
Old 05-13-2014, 06:28 AM   #3111
STURGauto
STURGauto's Avatar
STURGauto is an unknown quantity at this point
What are your wheel specs & alignment specs? Any rubbing on the front?
STURGauto is offline   Reply With Quote
Old 05-13-2014, 10:04 AM   #3112
S14DB
AFC #1
S14DB's Avatar
275/40
17x9
Offset?
Read the first post in the thread it was writen well.
Full specs on wheels and tires help everyone.
Wheel Diameter, Width and Offset.
Tire Width and Sidewall ratio. Brand and model help too because different tire manufatures use differen't points to were tread begins and ends.
Old 05-13-2014, 12:54 PM   #3113
Yellow4g63
I don't remember the specs I had my friend do it for me at his job one day when I had the stock 16" skyline gts wheels on the car. Fronts don't rub at all but my car isn't slammed at all. Fronts are 17x9 +25 with a 3mm spacer to clear the z calipers. Rear are 17×10+20 and rubs fender on hard dips on the fwy.
91 Nx2000 VVL yo
Old 05-15-2014, 06:50 PM   #3114
waxball88
Offset?
17x9 +12
msglength
Old 05-16-2014, 08:56 PM   #3115
gsracer
gsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond repute
Throwback...
front
18x10 +18
275/35/18
Rear
18x11 +18
315/30/18
ANTI-STRETCH NAZI
Vortech Supercharged Vh45de S14 V8nissans.com
gsracer is offline   Reply With Quote
Old 05-16-2014, 10:09 PM   #3116
Sumslapper
Sumslapper's Avatar
Sumslapper is an unknown quantity at this point
Stock metal
295/30-18
245/40-17
Sumslapper is offline   Reply With Quote
Old 05-17-2014, 01:21 AM   #3117
Yellow4g63
Sumslapper how much camber are you running in the rear's?
91 Nx2000 VVL yo
Old 05-17-2014, 11:53 AM   #3118
Sumslapper
Sumslapper's Avatar
-2 rear -2.5 front
Old 05-17-2014, 12:47 PM   #3119
Yellow4g63
Looks damn good man
91 Nx2000 VVL yo
Old 05-18-2014, 09:03 AM   #3120
ykemma
ykemma's Avatar
ykemma is an unknown quantity at this point
Looks damn good man
Impeccable fitment and you didn't have to get crazy with the camber: )
Sent from my LG-LS980 using Tapatalk
ykemma is offline   Reply With Quote
