Old 11-30-2016, 02:27 AM   #1
Climb385
Climb385 is an unknown quantity at this point
91 Silvia RB25DET!! OEM inspired ish lol
well lets try and get this one to work! Recently picked up a 91 silvia sr20de auto car with 67km (41k miles)
pulled my rb25 and full suspenions and brakes from my s13 vert, and sold the shell!
mods to rb
series 2 untouched motor
greddy t-belt, oem oil and water pump
freddy intake w/ q45 throttle body
ls2 truck coil conversion
wiring specialties pro harness
zero lift mount kit
driveshaft shop 1 piece
syco turbo elbow and downpipe
currently pulling the sr out of the silvia!
now for pics!
yes thats an oem aero bumper sitting on the vert
installed my bricks and my half and half turn signals!
ISR pro coils, tension rods, and nismo power brace installed, had to wait til 1/4's got rolled before i could swap subframes, 5 lug and z brakes
rb awaiting new home
picked up a q45 diff and j30 axles instead of running a welded diff on this car
there will be alot more coming!!! placed a huge order with enjuku on black friday!
Last edited by Climb385; 09-21-2017 at 12:37 AM.. Reason: fixing stupid photobucket bs
Climb385 is offline   Reply With Quote
Old 11-30-2016, 01:54 PM   #2
supersayianjim
supersayianjim's Avatar
supersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enough
Why not a j30 diff, like me?
supersayianjim is offline   Reply With Quote
Old 11-30-2016, 02:01 PM   #3
Climb385
Easier to find for one, two I got this 97 q45 22k mile diff for cheap, 3rd I wanted the 3.69 gears for when I go big turbo, plan was todo big turbo over winter on my vert, but since I bought the Silvia instead I'm going to go all out and fully build a spare rb25, so for now I'm just swapping the stock rb25 set up into the Silvia
The diff just needs a good cleaning and paint/undercoating to it
Old 11-30-2016, 03:32 PM   #4
Climb385
Some more pics, first day I had it I installed one of my 350z seats in, they are now both in and quick release steering wheel is also installed
Brand new Oem shift boot
Nismo power brace, isr pro tension rods and energy suspension bushings installed on the front, haven't swapped in my loaded subframe yet with isr pro arms, pbm solid subframe riser bushings and energy suspension bushing kit and z brakes with 5 lug and z ebrakes
Still waiting to swap the front z32 30mm calipers and 5 lug hubs
Then some Black Friday purchases showed up yesterday and today!!
Spal 1650 cfm pusher fans, I ran clutch fan on vert but I'm not cutting up the core support on the Silvia so high powered e fans will work
Aem electronic boost gauge, ran a cheap glow shift before
Waiting on enjuku to send me my aem uego wideband, solid diff bushings, walbro 255, isr rb25 short shifter, and few other things,
Old 11-30-2016, 03:59 PM   #5
DJTTon
DJTTon's Avatar
DJTTon is on the path to ruinDJTTon is on the path to ruin
Any modifications to fit the z seats?
Skurr Skurr
DJTTon is offline   Reply With Quote
Old 11-30-2016, 04:10 PM   #6
Climb385
It was very very simple, take the s and z seats and drill out spot welds on the two front brackets and the inner rear bracket, bolt the s brackets in car, line up the z outside rear bracket, tac weld the s brackets to the z seat rails, pull seat out and weld up completely, you'll have to make a 1" spacer for the front outside bracket
Old 12-09-2016, 11:36 AM   #7
Climb385
Well I got the sr yanked out, didn't take long, buyer came and picked up the sr, and many of my Black Friday parts have showed up!! Had to order ps lines mine got damaged pulling the sr out, but those should be here mid next week, and I ordered new wheels! Was an impulse buy but I ordered blitz 03's off of here!
Picked up some low mileage z32 wheel bearings, I broke an axle end of last year, drove home 20 miles and trashed the bearing, welded diff got me home tho!
New aem wideband
Got the sr pulled!! So glad it's gone
Time to clean up the engine bay, drill the clutch mster out and get ready to swap in the Rb25
Isis short shifter, another Black Friday purchase
Walbro 255 fuel pump
Solid diff bushings for the q45,
Hallman manual boost controller
Had to order a skyline r33 clutch master to clear the greddy intake, hope that it will be here soon
Old 12-24-2016, 02:57 PM   #8
Climb385
Well I got a lot of work done in the last few days figured I'd update this, sr is completely gone! And rb is installed and fired right up!!!! Finally got my 5 lug, z brakes and rear subframe from the new owner of my vert, got the q45 diff cleaned up swapped in a s13 vlsd high capacity diff cover, got the subframe and front 5 lug and z brakes installed, need to bleed the brakes and clutch. And I have to drop the rear lower control arms and replace the ball joints and bushings since I never got a chance todo so when I had the subframe out of the vert
Now for pics
Got the new walbro 255 installed
Blitz wheels finally showed up!!
Got the new street faction vent pod installed with the new aem gauages
Got the skyline r33 clutch master installed!! Talk about tight clearance!!
Rb25 sitting in her new home!!
Topping off coolant, plum'd intercooler piping just so I could start the car
The vlsd cover
Had to test fit the blitz wheels the second I got home with the wheel bearings and subframe
Finally got the subframe up and and test fit the rear, and bolted the front calipers on, realized I needed to run a spacer in the front, so I had to order 15mm bolt on spacers
Have to button up a few things, need to install driveshaft, fill trans fluid, run my boost gauge sensor, reinstall my seat, cut the front bumper beam for intercooler, and send my oem aero to paint
Old 12-25-2016, 10:21 AM   #9
supersayianjim
why no wally 455? they are the same price..
Old 12-25-2016, 10:40 AM   #10
Climb385
Because it's a stock motor set up, plus I got it on Black Friday deal from enjuku for stupid cheap!
Old 12-25-2016, 12:32 PM   #11
DJTTon
DJTTon's Avatar
That motor looks very cozy sitting in there! Congrats
Skurr Skurr
Old 12-25-2016, 08:07 PM   #12
Climb385
It fits so nicely, took a little massaging of the fire wall tho
Old 12-26-2016, 05:15 AM   #13
d_nice
d_nice's Avatar
Trader Rating: (39)
Feedback Score: 39 reviews
project looking clean man, where you picked up the j30 axles looks real clean.
Old 12-27-2016, 11:52 PM   #14
Climb385
Got the axles, diff cover, and z32 bearings off of a member on here,
Old 01-10-2017, 07:14 PM   #15
Climb385
Well I got the car 90% done, all I need to do is bleed the clutch, paint the oem aero, and enjoy her!!
Got the fender harnesses tucked up!
Got new moog ball joints, and energy suspension bushings installed in my control arms,
And I'm down in Houston tx for the next two months, first day here I picked up oem Canadian side skirts, going to sell my oem 180sx skirts as these will flow with the oem aero bumper much better
Old 01-12-2017, 07:24 AM   #16
Sansone
Sansone is an unknown quantity at this point
Looking good buddy! Can't wait to see it this year!
Life Ruiner
Sansone is offline   Reply With Quote
Old 01-12-2017, 08:05 AM   #17
Nissan2nr22
Nissan2nr22's Avatar
Trader Rating: (30)
Nissan2nr22 has a spectacular aura aboutNissan2nr22 has a spectacular aura aboutNissan2nr22 has a spectacular aura aboutNissan2nr22 has a spectacular aura aboutNissan2nr22 has a spectacular aura aboutNissan2nr22 has a spectacular aura about
Feedback Score: 30 reviews
Good stuff keep it up
Nissan2nr22 is offline   Reply With Quote
Old 01-12-2017, 04:23 PM   #18
Climb385
thanks man, i cant wait to start driving it again, i wish i would of had it finished for Texas but i brought the bike down so i'm still doing good
don't worry i will, i take pics of everything all time, so there will be many updates
Old 01-12-2017, 08:48 PM   #19
Climb385
well i bought some more stuff today... i had too after i saw it!! rb26 valve covers going on my rb25!!! cant wait!! probably wont go on until pull motor to build unless i get really bored and want to pull the rad and redo the timing belt and replace the backing plate at the same time.
i got complete oem valve covers, coil pack covers, upper timing cover and upper backing plate for timing cover, all the hardware, coil pack brackets that i will have to modify so i can run my ls coil packs!
pics of just the covers, will go to powdercoated very soon!!!
Old 01-13-2017, 07:51 AM   #20
souljaseth33
souljaseth33 is a name known to allsouljaseth33 is a name known to allsouljaseth33 is a name known to allsouljaseth33 is a name known to allsouljaseth33 is a name known to allsouljaseth33 is a name known to allsouljaseth33 is a name known to allsouljaseth33 is a name known to allsouljaseth33 is a name known to allsouljaseth33 is a name known to allsouljaseth33 is a name known to all
Send a message via AIM to souljaseth33
Nice two-tone! I've got two currently (240sx, not Silvia) and have been on the fence about getting an actual Silvia or a sedan (Cefiro or Laurel) but your car is bringing me back to the Silvia. One I've been looking at is an auto currently like yours was. Is it difficult finding RHD 5 speed swap parts, or do LHD parts fit?
Poor people and excuses ruined two tones.
souljaseth33 is offline   Reply With Quote
Old 01-13-2017, 12:11 PM   #21
Climb385
Thanks man, I honestly love having a Silvia I could of bought an r32, but after the deal I got on this Silvia I couldn't pass it up and don't regret it at all, as for the 5 speed swap I used a stock lhd clutch pedal and I was going to use the lhd clutch master but I couldn't because it was too long for the Rb25 intake manifold, so I bought a r33 clutch master, if you buy a sr20 stick car you can use the master the car already has, but a ca car you need to change to a sr or r33 clutch master, the ca and usdm one is 1.3" longer than the one needed to clear the Rb25
Old 01-13-2017, 12:21 PM   #22
Sansone
Idk if I missed this Cory but are you still going to use a aero front bumper?
Life Ruiner
Old 01-13-2017, 12:46 PM   #23
Climb385
Yea the new oem aero bumper, Canadian side skirts, Silvia valances, all going to paint when I get home from Texas
Old 02-07-2017, 08:17 PM   #24
Climb385
Well not much of an update as I have been in Texas for the last month and a half, but I have ordered a few parts, one of my favorites is a set of mint oem rear 1/4 window louvers!! Didn't plan on buying them but it kinda just happened, and currently working out a deal for getting a complete forged Rb25 all brand new still in boxes, Manley rods, cp pistons, arp head and main studs, n1 oil pump, Rb25 block with crank, complete head, so basically order timing components, head gasket, cams, springs/retainers, and drop it all off at machine shop, but here are pics of the louvers
Old 02-08-2017, 09:49 AM   #25
Fuglychuki91
Fuglychuki91 is on a distinguished road
Such a crazy build for sure. You get stuff done pretty quick haha
Fuglychuki91 is offline   Reply With Quote
Old 02-08-2017, 10:54 AM   #26
1988montecarloss
1988montecarloss's Avatar
Trader Rating: (24)
1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough
Feedback Score: 24 reviews
awesome car
love the 03's
IG: @Haley72692
1988montecarloss is offline   Reply With Quote
Old 02-09-2017, 08:33 PM   #27
Climb385
Thank you, yea I have a problem I say, I'm inpatient so I like to knock the stuff out right away even knowing I won't be driving the car until spring I want the winter project finished and ready to go, when I bought it trailered it home 4 hours, unloaded it, parked truck and instantly pull the drivers seat to install my 350z seat before I did anything else
Originally Posted by 1988montecarloss View Post
awesome car
love the 03's
Thanks a lot, I saw them listed forsale on here and googled them on a Silvia and was like yup I'm buying these, after always saying people are crazy for spending money on legit wheels I bought legit wheels lol
Old 02-18-2017, 09:24 AM   #28
Climb385
Quick update: leaving Texas this up coming week, while I was here I bought a 04 srt-4, only had 84k miles on it, got it for 2500, bringing it back to pa, where I already have it sold for $5500' I only have a total of 3400 into it after title, and some repairs it needed, so I'm making a quick penny off of it, so the rb25 is coming back out of the Silvia and the whole car is going to the paint shop!!! Fresh paint for 2017, and going to have a bunch of stuff powder coated while it's out!!
Also just bought cts-v front brembo calipers and sti rear brembo calipers bye bye z32's
But here are some pics!!
Srt4 04 84k miles, agp wastegate, spearco intercooler, mopar intake, mopar blow off, straight pipe, mad dog 70% reduction short throw shifter, lowering springs, deff a fun car but bought to make quick flip and it deff happened!!
And then the brembos, still waiting for them to show up, and I have to order 350z nismo rotors and 240 banjo style hoses
Can't wait to get home and start tearing the car back down
Old 03-08-2017, 08:11 PM   #29
Climb385
Well srt4 is sold!! So I have new plans for the Silvia! I'm pulling the motor back out and sending the whole car off to paint!!! Factory oem ivory white with Champagne gold metallic two tone, going to make the car look as if it just rolled off the showroom floor! Front brembos have been installed!
Brembos!
Finally cut the oem bumper for the intercooler
Ordered moldings from the dealer! All door moldings and both front and rear window trims
Than all the parts that showed up while in was in Texas
So motor is getting pulled out this weekend! Then sending the car off to paint!! I can't wait for it to be freshly painted!!!
Old 03-08-2017, 09:58 PM   #30
solo_ryder
solo_ryder's Avatar
Trader Rating: (18)
solo_ryder is making a name for him/her selfsolo_ryder is making a name for him/her self
Feedback Score: 18 reviews
Fuck this build is awesome.. I cant wait to see the car after the respray
solo_ryder is offline   Reply With Quote
