Old 02-20-2018, 08:06 PM   #1
miro
miro is an unknown quantity at this point
SPAL fans, LS swap parts, dogbox parts, s13 brake booster, s14 trunk
Have a few random items for sale after cleaning out the garage. Everything is located in Lodi, NJ. Will ship everything except the trunk.
Pair of used SPAL fans, $50 each, $85 for both
Remote oil pressure sensor line, connects to the port behind the intake manifold and has a 1/8" npt fitting on the other end for a sensor - $40
Pace performance LS to dogbox bellhousing, was sanded down on both sides for trans tunnel clearance - $125
Trans mount for dogbox in an s13 (used with sikky motor mounts) - $100
Shaftmasters 3" steel driveshaft for dogbox to s13 diff, 46.5"-48" required between back of trans and diff - $200
s14 trunk, has spoiler holes, otherwise decent shape - $40
s13 brake booster - $90
(2) LS header flanges, steel 1/2" thick - $90
Canton Racing remote oil filter, cartridge style with 4 brand new filters included, -10 AN fittings, 2-bolt mounting clamp - $100
Canton Racing ls1 oil pan filter adapter, -10 an fittings, swivel, works on gto pan - $60
miro is offline   Reply With Quote
