Old 12-08-2019, 11:55 AM   #1
dallaschristman
dallaschristman is an unknown quantity at this point
Talking Garage Clean Out! SR20, KA, etc.
Time to clean out the garage and make some room for new parts!
All prices are OBO. Buyer pays shipping + PayPal fees.
Located in Dayton, OH. Local pickup available.
1. SR20DE Valves, springs, retainers etc. Valve cover studs – Make offer, head is scrap
2. SR20 Alternator – Tested working, $60
3. S13 SR20 Oil Pickup Tube – $10, no hardware
4. SR20 Water Pump – Dirty, spins freely, $10
5. S13 SR20 Oil Pumps – Dirty, spins freely $40/piece
6. KA24E Distributor + NGK Wires – Working, new cap and rotor + wires – $25
7. S13 OEM Mudflaps – Pretty crusty, one has broken rivets, could be restored – $30
8. KA24E Engine Harness – No cut/ broken wires I can see, missing metal clips for plugs – $30
9. KA24E Cluster w/Harness – has 140,xxx on odo, has LED replacement bulbs – $30
10. Complete Hatch Seatbelts – black, decent condition, I believe the drivers lap belt has a small tear – $20
11. EGR, Charcoal Container, Various Emission junk – Make Offer, will separate
12. KA Starter – Was on single cam, brand new condition – $70
13. Stock Radio – works, but screen and tape deck doesn't – $5
14. DIN Pocket – good condition, no broken tabs or cracks – $20
15. S13 OEM Door Sills - All screws intact and included, good condition – $20
16. KA24E OEM Exhaust Manifold - Dirty, but good condition – $20
17. OEM Intake Box + Single Cam MAF – Box is in decent shape, has some holes but works fine. – $10
MAF should be in working condition – $20
18. KA24E OEM Oil Pan – No dents or cracks, has new drain plug and most bolts – $20
19. A/C compressors – No brackets, hardware, lines, etc. Untested. I think KA24E? $10/each
20. Auto Trans Harness + Shifter Assembly – No broken or cut wires, Shifter should be complete – $15, will separate
21. Auto Brake Pedal Assembly – Rusty, seems to work fine – $10
22. Intake hose coupler, not in great shape. Has small tears, crumbling around outer edges, but looks fine in middle. Includes bung and clamp – $5
23. Cruise control cable – $5
24. Exhaust Man. Heat Shield – From KA24E? – $5
25. Hatch Third Brake Light – Tinted black, pretty rough. Untested – $5
26. Sharknose Orange Turn Signal – Missing one screw, has small crack on one side, but pretty unnoticeable – $10
27. Unknown brake master – Untested – $5
28. KA24E Distributor - Untested – $5
29. OEM Rear Strut Covers – Dirty, one has dent but could probably be popped out with heat – $20
30. #10 and #81 ECU – #10 works – $15 #81 untested – $5
31. Street Faction Center Vent Gauge Pod – 3D printed. Crappy sand and paint job, fits 52mm gauges I believe – $15
32. Intellitronix White LED Boost Gauge + Sender – Never used, missing mounting bracket and nuts for gauge – $75
*Also looking for S13 SR20DE complete distributor!*
dallaschristman is offline   Reply With Quote
Old 12-08-2019, 12:00 PM   #2
dallaschristman
Sorry, I couldn't get the images to attach for whatever reason.
https://imgur.com/a/K35XW7c
ka24, parts, s13, sr20
