Old 04-12-2018, 11:31 AM   #1
TIGGZ_S13
TIGGZ_S13's Avatar
TIGGZ_S13 is an unknown quantity at this point
Angry Crank no start, no spark or fuel. 93 ka24de
I have a 93 ka24de which i had changed the motor on, the previous engine started knocking so i bout another engine. At first we couldnt get fuel, the pump wasnt priming and when i checked through i found the ECU with a burned diode (i think thats what its called). I changed out the ECU and got it to start. It ran for about 2 days and when idling it just shut off and now it wont start, its not the battery, its not the starter. Im not getting spark or fuel. I checked the fuses and found none blown. What else should i check? Could I maybe have a short or something causing these problems?
Thanks in advance for any input.
TEAM KRSH TST DMMIEZ-TIGGZ
TIGGZ_S13 is offline   Reply With Quote
Old 04-12-2018, 01:05 PM   #2
flartius
flartius's Avatar
flartius has much to be proud offlartius has much to be proud offlartius has much to be proud offlartius has much to be proud offlartius has much to be proud offlartius has much to be proud offlartius has much to be proud offlartius has much to be proud offlartius has much to be proud offlartius has much to be proud offlartius has much to be proud of
Well both the coil and the fuel pump should be on a relay, so if you're fuses leading up to those are good then I would check the relays themselves to see if they are getting both the constant 12v power and getting the signal to energize the coil.
Once you figure out what isn't getting power when it is supposed to you can trace it back from there.
¯\_(ツ)_/¯
flartius is offline   Reply With Quote
Old 04-12-2018, 02:03 PM   #3
staying_chuki
staying_chuki's Avatar
staying_chuki is an unknown quantity at this point
Could be wiring if you cut/spliced anything. Also injectors, i think the tool is called a noid light or something to check that.
Could be aloot of tings
staying_chuki is offline   Reply With Quote
Old 04-14-2018, 09:15 PM   #4
kyral
kyral's Avatar
kyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nice
your distributor can cause your injectors not to open cause it has the Crank angle sensor iirc
how do you know you didnt just fry out another ecu?
definately check for any blown fuses. and relays, relays can be easily checked by replacing with a known good relay. or using a multimeter and a 9v battery
The Game
you lose haha
kyral is offline   Reply With Quote
Old 05-02-2018, 11:16 AM   #5
TIGGZ_S13
TIGGZ_S13's Avatar
Update to my problem. I removed the engine harness to have it checked, they found nothing but told me the distributor might be the problem since the diode or resistor (idk the correct term for it) that burned leads to the distributor. I reinstalled the harness and turned it on and it didnt have the fault anymore. Idk Wtf the problem was but its fixed now. Just removed and reinstalled the harness, same ecu.
cranknostart, ka24de
