Old 07-26-2009, 02:59 PM   #1
MartyMcFly
MartyMcFly is an unknown quantity at this point
1990 240SX Coupe Sylvia front, $2200
$2200, located near Amarillo
130k, SOHC, auto, runs great!
VIN# JN1HS34P5LW106857
Pros:
-VERY little rust!
-clean title
-Ice cold AC
-Runs without a hiccup
-ALL power
-HUD display
-Sylvia front end
-uncracked dash
-new paint (although cheap paint)
Cons
-several dents near gas tank
-hood is bent in passenger corner
-small rust hole on passenger side skirt
-passenger side corner lights tab broke off (will give broken light to new owner)
-have to put the car in neutral to start it sometimes (common issue)
-no passenger seat
-muffler needs to be welded back on (have it in trunk)
-Power steering pump works great, but leaks a tad bit causing P.S. fluid to spray on oil pan and causes P.S. belt to squeal on startup (squeal goes away after 30 seconds) (look at pics).
-weather stripping on rear window needs replacing.
TAD BIT OF RUST:
MartyMcFly is offline   Reply With Quote
Old 07-26-2009, 09:49 PM   #2
MartyMcFly
bump it up
Old 08-06-2009, 08:23 PM   #3
MartyMcFly
edited post
coupe, sylvia
