Old 01-19-2017, 10:30 PM   #1
robmontoya11
robmontoya11 is an unknown quantity at this point
S14 misfire
Someone please help I have been going at this for weeks!!! I have a misfire in which it ideales rough and makes muffled popping noises when idling as if it's not getting spark or has fuel cuts. It also loses a good amount of top end power and sometimes makes a nasty noise that sounds like it's leaning out hard. I have replaced fuel filter, have a Walbro 255 fuel pump, MAF, distributor with cap and rotor, spark plugs, injectors, air filter, added engine ground, replaced oil, and adjusted idle. I went to get an OBD scan and I got 3 codes: EGR(removed), speed sensor, and some air sensor for this car but when I looked that code up online, nothing popped up. I am led to believe the only things left that may fix the issue are TPS, Bad wiring harness or ECU. Someone please provide further input I would greatly appreciate it.
robmontoya11 is offline   Reply With Quote
Old 01-20-2017, 07:52 AM   #2
Nissan2nr22
Nissan2nr22's Avatar
Trader Rating: (30)
Nissan2nr22 has a spectacular aura aboutNissan2nr22 has a spectacular aura aboutNissan2nr22 has a spectacular aura aboutNissan2nr22 has a spectacular aura aboutNissan2nr22 has a spectacular aura aboutNissan2nr22 has a spectacular aura about
Feedback Score: 30 reviews
What about the cables and coilpacks?
Check/clean those out, electrical grease etc.
Nissan2nr22 is offline   Reply With Quote
Old 01-20-2017, 08:10 AM   #3
jedi03
double check timing too
Old 01-20-2017, 09:26 AM   #4
robmontoya11
I already checked timing it's on point
Old 01-20-2017, 10:43 AM   #5
EDT007
EDT007's Avatar
EDT007 is an unknown quantity at this point
I can only assume that it's a KA since you didn't specify. It would help if you actually listed the P-codes you received from the OBD scanner. What year is the car?
97' 240SX - "lightly modified" - Weekend fun
08' IS250 - Daily
05' ZX6R - Twisties
EDT007 is offline   Reply With Quote
Old 01-20-2017, 02:35 PM   #6
robmontoya11
Just went to Autozone, the codes are p0110 Intake air temp sensor, p0500 speed sensor, P0325 Knock sensor, most likely activated by solid mounts or misfire, p1605 A/T diagnostics communication line( converted to manual), and P1400 EGR(removed)
