Old 02-28-2018, 12:41 PM   #1
dannyc240
dannyc240 is an unknown quantity at this point
1jz VVTI S13 8k
Ok. So I think its time to part ways with my 1jz 240sx. Just completed this about 6 months ago. And mainly looking to trade for a modded 350z.
1989 240sx
1jz vvti out of Toyota crown
Built r154
ACT 6 puck sprung clutch
Apexi Pfc d jetro
Wiring specialties harness
Excessive motor and trans mount brackets
Isr motor mounts
Cx racing trans mount
Chase bays PS lines and reservoir
Chase bags clutch line
Chase bays fuel lines wrapped in heat wrap
Cx racing exhaust
Cx racing intercooler kit
Excessive one live drive shaft
Mishimoto coolant reservoir
Street faction front and rear bash bars
Excessive skid plate
Reman steering gear from Napa
Tein inner and outer tie rods
Steering gear bushings
Steering shaft solid bushing
Brand new Nissan U joint for steering shaft
New rear brake lines and distribution block
All new ISR suspension arms
New Oem style flca
Nismo power brace
A/F ratio gauge
Water temp gauge
boost gauge
welded diff
Megan racing subframe bushings
Drop engineering coil overs (adjustments are seized but coil overs are not blown)
Has stock seats
Brand new windshield
Rust repair was done by me so it’s not perfect but no more rust. Mainly behind the side skirts
The car only needs the turbo rebuilt cuz it blows small amounts of smoke under decel (drift motion sells a rebuild kit)
Needs brake booster
Exhaust hits underbody of chassis, tried to bad out body alil. It helped but still does it. Can probnaly just tilt the engine the the left and fix the issue.
Located in Philly PA
I’m sure I’m missing a bunch of stuff done to the car but also everything on this car has less then 500 miles on it. Just want a change. Trade for 350z or make a cash offer. Text me at 2158808617
dannyc240 is offline   Reply With Quote
Old 02-28-2018, 09:49 PM   #2
Jsmith.x
Jsmith.x's Avatar
Jsmith.x is an unknown quantity at this point
Wrong section man, have to go to "cars for sale" GLWS
Jsmith.x is offline   Reply With Quote
240sx 1jz 2jz s13
