Old 07-05-2010, 01:10 PM   #2101
PNgo12
PNgo12 is an unknown quantity at this point
How important is it that I tighten the valve cover bolts to the right tq spec? Can I just use my regular socket and still be fine?
PNgo12 is offline   Reply With Quote
Old 07-05-2010, 01:14 PM   #2102
Marc240
Marc240's Avatar
Marc240 is making his/her stupidity well-knownMarc240 is making his/her stupidity well-knownMarc240 is making his/her stupidity well-knownMarc240 is making his/her stupidity well-knownMarc240 is making his/her stupidity well-known
hand tight, then another half turn
http://i48.photobucket.com/albums/f209/mj2545/logo.gif.com
Marc240 is offline   Reply With Quote
Old 07-05-2010, 01:25 PM   #2103
blitzsti22
blitzsti22's Avatar
blitzsti22 will become famous soon enoughblitzsti22 will become famous soon enoughblitzsti22 will become famous soon enoughblitzsti22 will become famous soon enough
Send a message via AIM to blitzsti22
what is the best 2 way alarm on a budget ($350)
blitzsti22 is offline   Reply With Quote
Old 07-05-2010, 01:31 PM   #2104
PNgo12
Alright, thanks!
Old 07-05-2010, 01:53 PM   #2105
zooopreme
Trader Rating: (38)
Feedback Score: 38 reviews
do you guys have any tricks to keep your license plates from getting stolen from your S13? I just got mine stolen today and I was to keep from it happening again. Please and thanks.
Old 07-05-2010, 04:02 PM   #2106
GabeS14
GabeS14's Avatar
GabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfection
Originally Posted by UGLYLOWLIFE View Post
why is my clutch making little clicking noise as i let go of the clutch? it never did this before
Stock or aftermarket clutch?
Is is starting to slip or is it fairly new?
The more info the better
E92 M3 19" wheels for sale///JWT Cams and Springs +30whp for sale... cheap.
GabeS14 is offline   Reply With Quote
Old 07-05-2010, 04:19 PM   #2107
Mita Orange
Mita Orange's Avatar
Mita Orange is an unknown quantity at this point
My hatch has a weird ticking coming from the middle to rear end. I haven't been able to pin point it; but it only ticks when moving and ticks faster as speed increases and at 17mph i get a shake in the rear end. Any ideas what could be wrong?
Mita Orange is offline   Reply With Quote
Old 07-05-2010, 05:02 PM   #2108
Bob_Sagat
Bob_Sagat's Avatar
Bob_Sagat is an unknown quantity at this point
I recently installed my bn sports hatch. when I removed the stock hatch, I cut the wires coming from the chassis ( for the defroster and 3rd brake light I assume) . Well the 15a fuse (stop lamp) blew. I replaced it and then when I stepped on the brakes, it blew immediately. So I'm assuming its because theres an exposed wire in the circuit. So how do I get it to where that fuse stops blowing? Do I need to cap off that wire?
Bob_Sagat is offline   Reply With Quote
Old 07-05-2010, 07:50 PM   #2109
EhrikETFG
EhrikETFG's Avatar
EhrikETFG is an unknown quantity at this point
Can anyone shed some light on which manual seatbelts will fit in a 89 coupe?
EhrikETFG is offline   Reply With Quote
Old 07-05-2010, 07:56 PM   #2110
sickrbs14
sickrbs14's Avatar
sickrbs14 is an unknown quantity at this point
hey guys whats the difference between odb1 and odb2
and do they perform the same or is one make more power
thanks
sickrbs14 is offline   Reply With Quote
Old 07-05-2010, 10:49 PM   #2111
nyrojas21
nyrojas21 is an unknown quantity at this point
nuub questions help
ok i have the ka24de its makeing the rattling sound, im assuming it the timeing chain guide from what i read
1. before i remove my valve cover do i have to drain my oil?
2.can i just leave to motor like that with guides broken and makeing the rattleing noise?can any problems accur?
3.to get the bottom guide off do i have to remove the front cover
4 and if i just wait and get a time chain kit ,can it be done with out removeing the engine out the bay?
nyrojas21 is offline   Reply With Quote
Old 07-05-2010, 11:32 PM   #2112
Psycho 240 Freak
Psycho 240 Freak is making his/her stupidity well-knownPsycho 240 Freak is making his/her stupidity well-knownPsycho 240 Freak is making his/her stupidity well-knownPsycho 240 Freak is making his/her stupidity well-knownPsycho 240 Freak is making his/her stupidity well-known
1. No you don't have to drain the oil
2. Just take out the guide. It's super easy. With the chain grinding away on the guide, there'll be small metal particles in your oil. I haven't heard of anyone having trouble with that yet, but I'd prefer to have fresh clean oil in my engine.
3. Yes
4. Yes
Psycho 240 Freak is offline   Reply With Quote
Old 07-05-2010, 11:41 PM   #2113
nyrojas21
3. Yes
4. Yes
does noise only come from the top guides or the bottom as well?
and im thinking no ,but can i reuse the valve cover gasket
Old 07-05-2010, 11:43 PM   #2114
nyrojas21
also
ok so my window hasnt worked since i got the car a few months ago,the amp clicks so i thought it was the motor,took the motor out cleaned alittle bit,tried it and it worked for a sec after jiggleing the plug to the amp,then stoped .so then i took the motor and pluged it to the passenger side and it works fine. so my question is if the amp clicks is it bad?? and if my amp is bad can i bypass it or do i need the amp?? o yeah i have a 95 s14
Old 07-06-2010, 12:29 AM   #2115
jiggs
jiggs's Avatar
jiggs has made poor choicesjiggs has made poor choicesjiggs has made poor choicesjiggs has made poor choicesjiggs has made poor choicesjiggs has made poor choices
will a 17x10 zero offset wheel fit on a s13 without hitting the coilovers? i know its gonna poke out but i need to know... thanks in advance.
JS4HATERS
jiggs is offline   Reply With Quote
Old 07-06-2010, 12:34 AM   #2116
deuce40sxftw
deuce40sxftw is an unknown quantity at this point
for the rears, allen wrench bolts, for the front i have it ziptied to my passenger sun visor, cause my windshield top is tinted to its hard to see and cause im not putting holes in my bumper for shit. or tamper proof bolts, they cost a bit and you need a special drill bit to put em on. but worth it
my question, who steals plates?
deuce40sxftw is offline   Reply With Quote
Old 07-06-2010, 12:38 AM   #2117
deuce40sxftw
thanks
on board diagnostics, obd. obd1(01 lol)
obd1 started in like 88 to 94-95 i believe. not sure on the start date really. all it had was pretty much check engine light codes, all of it was manufacture specific, so nissan obd plugs wont be the same as toyota obd plugs. really no performance gain other than you can do much more with the engine without throwing codes, like turbo and what not.
obd2, you have much more communication with the engine. Any little issue that can occur will be stored on the diagnostics log and you can check it with a scanner, most plugs are also universal. Only problem, it communicated with alot of stuff in your engine so you cant really remove stuff without getting codes, like emissions stuff and shit.
Modifications are easier with obd0/1 engines, cause it isnt really informative or controlling, but obd2 makes it easier to troubleshoot your engine in the event of a problem
Old 07-06-2010, 12:39 AM   #2118
deuce40sxftw
may be an axle, worn rotor, or gear. my brake pad slipped off the shim and wore into my rotor. creating a tick that eventually grew into a whine. check everything in your back end
Old 07-06-2010, 12:50 AM   #2119
nyrojas21
also
3. Yes
4. Yes
Any one please help
Old 07-06-2010, 02:05 AM   #2120
jiggs
jiggs's Avatar
do all work wheels (in my case work mesters s1) always have the word "work" engraved in between the spokes on the face of the wheel?
JS4HATERS
Old 07-06-2010, 02:21 AM   #2121
s13coupe1988
s13coupe1988's Avatar
s13coupe1988 is an unknown quantity at this point
socal people do you guys know where they carry ngk-bkr8eix in stock i need some asap thanks for the help
s13coupe1988 is offline   Reply With Quote
Old 07-06-2010, 11:38 AM   #2122
zooopreme
Trader Rating: (38)
For your front plate, is that legal? lol
& to answer your question, I don't even know, man. I drove my dad to Costco to go get some groceries and when we came back to my car, someone stole my rear license plate. Maybe they wanted to take my tags, idk. But whatever it's all said and done.
Old 07-06-2010, 12:54 PM   #2123
deuce40sxftw
LOL man thats bogus as hell, lame thieves
i honestly dont even know if its legal, but it shows and i have a front plate. so they can suck my nuts, its a loop hole pretty much, as long as it shows. just like how some people stuff it behind their bumper ziptied to the radiator/support, same concept but different area
i would rather have a ticket for like obstructed view of license plate or some bullshit than no plate at all, you know?
Old 07-06-2010, 05:17 PM   #2124
PNgo12
If the gasket is in good shape reuse it. It never hurts to get a new one though...
Old 07-06-2010, 06:58 PM   #2125
deuce40sxftw
my side markers on the driver side dont light up, but my passenger side does. this is for the front and back
is there a separate fuse for each, or something i should look at? i find it wierd that only one side works, since they should all have 4 separate connections... you know what i iz sayn
Old 07-06-2010, 10:46 PM   #2126
Bob_Sagat
Bob_Sagat's Avatar
Is there any aftermarket s13 silvia front bumper that somewhat resembles the jdm aero bumper? I want a subtle look like that.
Old 07-06-2010, 10:51 PM   #2127
Kwonza Says
Kwonza Says's Avatar
Kwonza Says is a jewel in the roughKwonza Says is a jewel in the roughKwonza Says is a jewel in the roughKwonza Says is a jewel in the roughKwonza Says is a jewel in the roughKwonza Says is a jewel in the roughKwonza Says is a jewel in the roughKwonza Says is a jewel in the rough
What are some awesome tires to stretch and some to avoid?
Weeee!~Coupe love <3
Kwonza Says is offline   Reply With Quote
Old 07-06-2010, 11:45 PM   #2128
singlecamslam
singlecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymore
Originally Posted by singlecamslam View Post
OK flamesuit on. Can someone please tell me if this is the correct ball joint for the s14 from control arm........MOOG-K9820 Front Lower Ball Joint Made By
Reason i ask i heard those have the wrong taper? Are they wrong? Or do they really have the wrong taper and i need to look somewhere else.
I'm 80% sure these are right?
Nothing says racecar like a stock car with no interior.
singlecamslam is offline   Reply With Quote
Old 07-07-2010, 12:32 AM   #2129
GabeS14
GabeS14's Avatar
theres an auto parts store that carries the hard to find stuff,
they are on la Brea and Adams in los angeles,
just exit the 10fwy and take la Brea south and turn right on Adams blvd, they are located right after the autozone on the corner.
I am assuming those are special gapping spark plugs? I got mine there no one else had them. they ordered them and had them by the afternoon.
Old 07-07-2010, 01:37 AM   #2130
s13coupe1988
I found a spot in garden groove california that had ngk bkr8 and 9's great price also
they are on la brea and adams in los angeles,
just exit the 10fwy and take la brea south and turn right on adams blvd, they are located right after the autozone on the corner.
I am assuming those are special gapping spark plugs? I got mine there no one else had them. They ordered them and had them by the afternoon.
