Old 09-13-2019, 10:30 PM   #1
Jayce
Jayce is an unknown quantity at this point
Toyota Celica GT-S 3 Owner PowerPlant 3sgelc 1st Gen
Price TBD at the moment I'm open to honest offers.
1989 Toyota Celica Gts Black on Black special edition Clean Title No Accidents
Fully Loaded with Leather interior and everything electric including drivers seat.
New 3sge JDM Spec engine imported from Japan with 0 miles
On D2 36 way adjustable coilovers "Very Rare" not made anymore
Still have oem usdm spec motor and transmission
LSD Equipped Both tires make power
OEM Paint still shines
Vin numbers matching front to back stickers are all present.
3 owner car since new
All images are to current Date.
Rear seats are torn and dryed out probably won't be fixing that #racecar
Everything else is minty fresh.
I have 1 new driver's side fender not installed in OEM Black.
Added Cold air ram intake New.
Added dual core Radiator New.
Dual Core Rad installed with OEM electrical fans attached.
Replaced ignition switch
Replaced Distributor
Replaced TPS sensor
Replaced Cv axels x2
Replaced Control arms x2
Replaced Ball Joints x2
Replaced with Reman Starter
Replaced Fuel pump & Strainer
Replaced Fuel filter
Replaced Rack and pinion
Replaced inner and outer tie rods
Replaced Klutch SL1's
Replaced Falken 205 45r 16 tires
Full tune up done since new engine install.
Replaced Cap and Rotor
Replaced NGK wires
Replaced Spark plugs
Replaced Valve cover gasket with install
IAC Valve Serviced
Intake manifold Serviced
Always running full synthetic oil and 91 premium fuel.
If you have watched some of my videos on youtube. The driving videos are from the same day. Went on 1 touge run to test out the dual core radiator. Since that very day I parked it. Put it on non op. Reason for that is she had a bad starter, thermostat, and fuel pressure regulator. 1 of 3 issues has been fixed. I have always garaged Rocket Sally and have put lots of care into her. Anyone who get's her will be very lucky to have her.
The only other issue is 2nd gear pops out does engage very well regardless of that. I'm never in 2nd long enough to be bothered by that issue. I do have another transmission you can make 1 great 1 out of. I'm not a transmission specialist so I haven't tryed to dismantle either one.
I've cared for her for the last 5 years and as you can see it shows.
I'm open to RWD Trades especially an MR2.
Cold Start Video
https://youtu.be/XI3hHRYqy28
You can see pictures on my instagram @jefesgarage
Jayce is offline   Reply With Quote
Old 09-16-2019, 12:28 AM   #2
Jayce
Sold Sold Sold Thank you Lord Jesus she's off to her new home.
