12-31-2017, 08:05 PM | #21541 | |
12-31-2017, 10:25 PM | #21542 |
Wow that’s mildly ironic, I had replaced the battery about a month and a half ago RIGHT BEFORE all this started, when I removed the old battery the battery tray is so rusted or ate up with holes it’s a wonder the battery has a place to even rest I was blown away by how rusted/corroded the metal was under it I did see the ground you mentioned but didn’t pay any attention to it AT ALL, I Will be checking that ground for corrosion or loose placement due to the issue I’m having I’ll be honest I never would’ve thought that could have it doing this but at this point anything helps, if it were the ground would it still turn over and crank? Just curious btw Thank you times a million I owe u greatly
12-31-2017, 10:56 PM | #21543 | |
Take an volt meter and measure the voltage drop or resistance from every engine bay ground to the negative terminal of the battery. Anything higher than an ohm is suspect or whatever the fsm says. Ideally the resistance would be zero, so the closer to zero you are the better |
01-01-2018, 07:02 AM | #21544 |
11920N
11950-71E10 Belt-Compressor F/AIR CONDITIONER-STD TYPE Replaced by: 11950-71E11 $22.97 $16.67 11720N 11720-26E02 Belt-Fan & Alternator Replaced by: A172M-26ESBVW $17.67 $12.83 11950N 11950-53F10 Belt-Power Steering Oil Pump Replaced by: A195M-53FSMVW $19.63 $14.25
01-01-2018, 04:49 PM | #21545 | |
01-01-2018, 05:15 PM | #21546 |
Im switching to the z32 rear ebrake and I was wondering if R33 cables would work with an S13. I know Z32 2+2 cables are the more bolt in solution but I can get new R33 cables for a decent bit less. Are they too long or do they work?
Follow me on Instagram or don't @cason880 |
01-01-2018, 05:28 PM | #21547 | ||
GM2 (SW/AW)
Yep you can use them. http://importnut.net/300zxbrakeswap.htm#ebrake
KA-T for life! Current for sale advertisement |
01-08-2018, 09:25 PM | #21550 |
The Architect.
Trader Rating: (392)
Feedback Score: 392 reviews
Sam (owner of Jspec) just doesn't have the time to keep up with Jspec anymore.
He does still have quite a few parts in storage. If you're interested in anything, I'd be more than happy to relay the message to him. |
01-09-2018, 05:22 AM | #21551 | |
Trader Rating: (31)
Feedback Score: 31 reviews
Sent from my SM-G955U using Tapatalk |
01-14-2018, 02:46 PM | #21553 |
Does anyone happen to know how thick z32 tt hub flanges are? The bit that sticks out and spaces the ebrake anchor out? I've got a z32 tt ebrake assembly with the thinner anchors so I wanted to make sure they were spaced out correctly on my s13.
01-14-2018, 05:13 PM | #21554 |
with the tps unplugged it should make the car idle smooth right? Also with the tps unplugged you shouldn't be able to rev it right? Because with the tps unplugged my cars idle still fluctuates and i can still rev it. Does this mean my tps is bad?
01-14-2018, 08:02 PM | #21555 | |
but maybe someone can measure exactly for you |
01-14-2018, 08:34 PM | #21556 | |
Small Questions Thread (SEARCH FIRST! Use this instead of making NEW threads)
You can still rev it with no tps, you’re opening the throttle and adding more air to the engine, more air means rpms increase, that’s how an engine works. |
01-14-2018, 10:07 PM | #21557 |
ok thanks for the reply, somewhere i heard someone say as soon as you touch the gas it will die. As for the idle whenever i see people doing ignition timing they unplug the tps. My understanding of that was to ensure a steady idle. So should I be seeing a steady idle with it unplugged?
01-15-2018, 07:06 AM | #21558 | |
01-15-2018, 06:23 PM | #21560 |
Yes, except that it's a lot smarter than you are, so it knows it doesn't have a TPS, and to TRY to not do anything that might make big holes in your engine - but nissans are pretty bad about engine holes, and you seem to be determined...
01-16-2018, 04:35 AM | #21561 | |
Now that you are laughing, go download the fms and get to figuring it out
01-16-2018, 09:04 PM | #21562 |
the tps was out of adjustment. Ive adjusted it and now when i unplug the tps the car just stops idling, making it hard to set base timing. What would cause it to stop idling with tps unplugged?
01-17-2018, 06:33 AM | #21563 | |
Sent from my SM-G930U using Tapatalk |
01-17-2018, 08:25 AM | #21565 |
I have an S13 Silvia that I am doing an RB25 neo swap in. I want to keep AC. I have 1.5" between the rad and engine, so i don't think a puller is an option (I will loose the AC before I cut the rad support).
Can I get away with mounting a high flow pusher in front of the condenser? This is not a track car, so the most it will see is spirited runs on back roads. I also don't see much stop and go traffic where I live. I have a Mishimoto KA radiator and the stock AC condenser. I will buy air diversion panels if needed. Thanks for the help! |
01-17-2018, 10:31 AM | #21566 | |
At this point with the questions you're asking, I would highly recommend you download the FSM and start there. You'll wan't the "EC" (engine control) pages to start. http://www.nicoclub.com/FSM/240sx/ |
01-17-2018, 04:13 PM | #21567 |
I have 20mm spacers that I'd want to put on since my front offset is kinda bad and my wheels will hit the calipers, but I've recently put extended eibach studs and with 20mm spacers the studs won't allow my wheel to fit. My wheels are dual pattern so that's why this is an issue for me.
The question is that is it safe to "enlarge" the other pattern holes (like drilling or something) in order to fit the wheel? I mean it only touches the wheel like a few millimeters so slightly enlargening the threads would allow the wheel to fit right? The extended studs are new and I wouldn't want to damage them, but the wheel I don't mind since I'll never use the other pattern or resell the wheels. Or any other idea how I could fit the wheel? |
01-17-2018, 04:24 PM | #21568 |
ITS LISA'S FAULT!!!
Trader Rating: (41)
Feedback Score: 41 reviews
drilling hubs is no big deal... lots of off road guys do it. if i were you, id PAY a shop to bore the centers PROPERLY instead of doing it yourself. this way the damn hub will stay centric
01-17-2018, 04:36 PM | #21569 |
I think he's talking about bolt-on spacers, and the stock studs are protruding past the spacer and interfering with the wheel. You need 25+mm to "cover up" the stock studs.
There shouldn't be the problem OP is describing with extended studs and slip-on spacers. I just can't picture how. With all that being said, and if it's a bolt-on spacer issue, go ahead and clearance the 2nd bolt pattern. Stock studs protruding past a bolt-on wheel spacer: Stock studs recessed into a bolt-on wheel spacer: Slip-on wheel spacer with extended studs: |
01-17-2018, 06:34 PM | #21570 |
[QUOTE=LoSt180;6254494]Do you shut engine off, unplug, then restart engine; or are you unplugging the TPS while the engine is running? Also is car warmed up when you're doing this? Make sense your engine shuts off if you unplug while running since the ECU thinks something broke while running.
At this point with the questions you're asking, I would highly recommend you download the FSM and start there. You'll wan't the "EC" (engine control) pages to start. http://www.nicoclub.com/FSM/240sx/[/QIf If i unplug it while its running it will stop idling. If i shut the engine off, unplug it, then start the engine, it runs as if I never unplugged it. My car idles poorly and this also makes it hard to set base timing. Yes the car is warmed up when i do this. I checked out the fsm and I have not found anything that describes my problem. I have found stuff that will help me fix my idle but i would like to set base timing first. I have also tested the tps itself and it tested good except the drops to 0 right before you reach full throttle then it goes to 4 volts.(I thought it should be 5 but the fsm says it can be around 4.) But i don't think that will affect idle. Thank you for the suggestions. car is a 1990 with ka24e btw |
