Old 09-13-2012, 03:03 PM   #1
wakeboarder843
wakeboarder843 is an unknown quantity at this point
SR Sr20det wont stay running and bogs out
I just swapped a blacktop sr into my car and it will start up for maybe 5 seconds then dies and runs terrible
today I took the valve cover off and checked the cas and everything was good I cant check the timing because I cant get it to run long enough
I also replaced the spark plugs and turned the car over while I had the plugs out in the coils and they are all firing and in the correct order so I know Im getting spark
I ordered a z32 maf and it seems to be working but how do you know if the maf is good or bad? when I unplug the maf the car revs by itself to 4000 rpm then dies
Any other suggestions? Im running out of Ideas here
here is a short video of what it does
Sr20det wont run - YouTube
wakeboarder843 is offline   Reply With Quote
Old 09-13-2012, 05:16 PM   #2
di-devol
di-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enough
What's done to the motor? Biggier injectors? What are you running for a tune?
di-devol is offline   Reply With Quote
Old 09-13-2012, 05:18 PM   #3
AsleepAltima
AsleepAltima's Avatar
AsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura about
this. also, which maf? stock sr or different one?
AsleepAltima is offline   Reply With Quote
Old 09-13-2012, 07:12 PM   #4
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
Try to adjusy the iacv valve and see if the idle changes. Or u can unplug the connector and check for voltage.
Old 09-13-2012, 07:21 PM   #5
Lil_D
Lil_D is an unknown quantity at this point
vacuum leak? timing off??
Lil_D is offline   Reply With Quote
Old 09-13-2012, 07:29 PM   #6
SnakeKack
SnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of light
Send a message via AIM to SnakeKack
Is it getting fuel?
SnakeKack is offline   Reply With Quote
Old 09-13-2012, 08:32 PM   #7
wakeboarder843
It's a stock motor haven't had it tuned as I just put it in and am trying to get it running properly. It has a z32 maf and other upgrades are just the regular swap things like intercooler greddy intake radiator etc..
I know it's getting fuel because I can smell it and one of the fuel lines was loose when I first started it and was leaking fuel all over the intake manifold and also I squeezed the fuel line and I can feel that it has pressure
Old 09-13-2012, 08:34 PM   #8
wakeboarder843
How do you adjust the ivac valve? I've heard of ppls ivac having a vacuum leak but from eye balling it I don't see anything
Old 09-13-2012, 08:55 PM   #9
AsleepAltima
z32 maf on stock sr ecu?
Old 09-13-2012, 08:59 PM   #10
wakeboarder843
Yea. Since I had to get a new intake I figured I'd get the z32 maf with it. Does that cause problems on a stock motor?
I tried to see if the maf was bad so I unplugged it and it just revs super high then dies
Old 09-13-2012, 09:03 PM   #11
AsleepAltima
yes. you need a stock sr ecu. the ecu has to be told that you are using a different maf.
Old 09-13-2012, 09:04 PM   #12
billiam
billiam is an unknown quantity at this point
new fuel pump and youll be good
billiam is offline   Reply With Quote
Old 09-13-2012, 09:06 PM   #13
wakeboarder843
Ok so I can't run a z32 maf with the stock sr ecu then? I have a j4 ecu cause it's a type x blacktop. What do I need to do to the ecu to run a z32 maf? Would a tune work or do I need like an air fuel controller or something?
Old 09-13-2012, 09:12 PM   #14
AsleepAltima
you have to have a tune for it. well, i guess there is a way you can do it with an safc, but i dont know how.
Old 09-13-2012, 09:21 PM   #15
wakeboarder843
Yea I didn't realize that you couldn't just swap out the maf. Will the stock ka maf work with the sr ecu?
Old 09-13-2012, 09:24 PM   #16
AsleepAltima
i dont think it will. you dont have the stock sr maf?
Old 09-13-2012, 09:27 PM   #17
AsleepAltima
i might have an extra sr ecu but i wont know till tomorrow. i wrote ecu but i meant maf.
Last edited by AsleepAltima; 09-14-2012 at 06:12 AM.. Reason: wrote the wrong thing...
Old 09-13-2012, 09:27 PM   #18
wakeboarder843
No I just have all my old parts from my ka. The swap came with motor tranny ecu harness and ignitor but no maf
The question now is would it be cheaper to get a tune or af controller or to buy a stock maf and different intake
Old 09-13-2012, 09:30 PM   #19
AsleepAltima
a tune is around 500 bucks depending on who you go to. you might even be able to buy an ecu already tuned for what you need. thats what i did when i bought my jwt ecu - it goes along completely with my build. but youre looking at close to 600 bucks for that route.
Old 09-13-2012, 09:33 PM   #20
wakeboarder843
Hmm ok I'll look into it thanks for the help hopefully this solves my problem!
Old 09-13-2012, 09:38 PM   #21
S14Driftr91
S14Driftr91's Avatar
Trader Rating: (26)
S14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to all
Feedback Score: 26 reviews
Your ecu is stock im guessing... in order to run a z32 maf you would have to get the ecu tuned to run the z32 maf. Now if your only upgrades are intercooler and maf, getting a tune is going to be more costly than just switching to a SR maf
www.allthingsproper.com
S14Driftr91 is offline   Reply With Quote
Old 09-13-2012, 09:38 PM   #22
Srsil
Srsil is an unknown quantity at this point
Sounds like u disnt even hook up the iacv also iv ran into this prob with a ka check ur dash plug wiring i.e the plug above the ecu begind the glove box and u do know that the type x harness needs to be wired diffrent than a regular sr
Srsil is offline   Reply With Quote
Old 09-13-2012, 09:46 PM   #23
wakeboarder843
Yea I might just buy an sr maf then but idk if it will fit with the greddy airnix intake that I bought
I bought a type x harness from wiring specialties so I think my wiring is good and the dash plug is connected
Old 09-13-2012, 09:56 PM   #24
rwtf
rwtf's Avatar
rwtf is an unknown quantity at this point
inb4tehfail.....oh wait.
rwtf is offline   Reply With Quote
bogging, maf, sr20det, timing, wont run
