04-02-2012, 10:12 PM | #1 |
*s13* crank crank crank no start
So Last week I drove my car home from work. Shut it off, Went to start it the next day and boom dead, Cranks and cranks but doesnt start
91 with a stock ka24de its got spark, Fuel pumps working. I cant for the life of me figure out why it doesnt start. It will crank till the battery dies. All fuses are good too. Thoughts on what I could look for? All fluids are good too. |
04-02-2012, 11:47 PM | #2 |
I had this problem on my sr20 not to long ago. One of the connectors that runs power to my injectors got water in it at one point in time and it slowly corroded. eventually it broke the pin inside and no power was getting to my injectors. a simple rewire and the car is back up running like new. yours could be the same problem. see if you can chase the wire from your injectors to the source of the problem?
04-04-2012, 01:55 PM | #7 |
Trader Rating: (50)
Feedback Score: 50 reviews
when you cranking and cranking=does it smell like fuel? if it does, then you have fuel but no spark. check the ignition system. i have this problem and what i did was take off 1 injector clip and it fired right up. need to narrow down if its fuel or ignition problem.
04-04-2012, 09:41 PM | #9 |
Have you checked each plug to see if theyre firing? If each are firing and you have fuel you may want to check you distributor cap and rotor button. If not firing see if you have spark from the coil.
