Forum Suggestions & Technical Support Post any suggestions or questions related to this site. |
02-22-2017, 09:51 AM | #1 |
SOLVED: PostIMG.org emmbeded pictures not loading in posts
If you can see this then you are good, if not, follow the below. Once you apply the 'fix' refresh and check this image again. Hopefully some finds this as useful as I did, but I am using uBlock Origin (Chrome) and it was causing an issue with only embedded images in posts from postimg.org. Example [Substituting ' ( ' for ' [ ' : (img)http://s11.postimg.org/u055s0yfn/image.jpg(/img) Would show as a broken image link: However if I right-clicked and opened it in a new tab, it worked. The Fix: > Go to the uBlock Extension options > Whitelist Tab > Add (not quotes): 'zilvia.net' and'postimg.org' > Apply and refresh the page. Boom-Sauce; fixed. This is likely the issue with any other "ad-blocking" software; your mileage may vary. Also, because Zilvia isn't a shit forum, there are no intrusive ads, so turning your ad-block off on here isn't going to cause you any random shit.
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 | |
