03-03-2008, 04:59 PM | #1 |
my s13 i call her brandy...56kmake a sandwich
^^thats not me ^^ alright well atleast now i had time to put the pics in order shes a 93 with 96k miles this stuff is done vvvvvvvvvvvvvv 5lug z brakes 350z front 300zxtt rear megan track coilovers 12k front 10k rear godspeed sways misimoto radiator w/single 14"tourquflow fan nismo powerbrace no name fender braces raceonusa vertex knockoff kit advan avs5s with 255/35/18 maxxis victra ma-z1 front nankang ns1 rear nardi wheel schroth harnesses 350z seats wcfab custom chromoly harness bar ats and accross carbonetics 1.5 lsd w/redline oil this stuff is allmost done vvvvvvvvvvvvvvvvvvvv vq35hr swap w/6mt <<*scraped* going built sr20det onepiece aluminum drive shaft single garret gt35r turbo aem ems w/wideband cusco 6 point cage Last edited by titaniumbmx; 04-25-2008 at 11:06 AM.. |
03-03-2008, 05:36 PM | #7 |
the mesh is already gone the dash fit with barely any mods but the gauges dont work after the swap because the signal is different from the aem ems. the door panels from the 240 dont look bad you need to make a filler piece to go from the a pillar to the dash though. also for everything to fit right you have to modify the dash brace from the 350 to bolt into the 240 and you need the 350z steering column... long story short on the dash its not worth it unless your making a showcar. i took it out because the gauges wont work.
03-03-2008, 06:35 PM | #18 |
he said that dirt is already gone, dash looks like it will be sick when all put together
edit: just saw your not using it, sucks Last edited by allntrlundrgrnd; 03-03-2008 at 06:36 PM.. Reason: Im dumb |
03-03-2008, 08:12 PM | #22 |
the aem unit produces a totaly different type of signal. to make it work i would have to have the entire 350z wire loom adapted to run the 240 and i would be using the stock 350z ecu so no programability and a stupid speed limiter. its not worth it.
03-04-2008, 12:27 AM | #27 |
MY PRECISOUSSSSSSSS!!!!!!!!!!!!!
SHIFT_Patience 1989 Ka24De Hatchback: 12/20/2005 - 11/03/2006 1991 Ka24De Hatchback: 12/20/2006 - Current Day |
03-04-2008, 01:58 AM | #28 |
how well does that z dash fit?
i thought about using it for my vq35de swap but the front end conversion i did was already pretty out there so I decided to use my stock s14 dash with s15 cluster.
Drives a BRZ and is building a V6 S12 coupe. |
03-04-2008, 09:42 AM | #29 |
it fits as well as can be expected the 350zs firewall is realy tall so leg room is an issue once everything is attached on the driverside the passenger is fine though. if you leave off the under panel that the fuel door button is on then its doable. also you need to heat the main plastic dash piece up with a heatgun and make the corners stay about 2" down where they meet the door panel. its alot of work to make it not look half assed...
03-04-2008, 09:47 AM | #30 | |
gauges and fill in some space that removing all the stereo/climate control left. |
