Old 02-01-2013, 05:42 PM   #1
todd5854
todd5854 is an unknown quantity at this point
Vacuum leak please help (pic)
Very loud and obvious.
If I spray starter fluid in the circled red area, my idle goes back to normal for a bit.
idle is rough, low, and the entire engine shakes. It almost sounds like a misfire... when I rev past 1500 the misfire type sound goes away.
Sometimes when coasting, I push in the clutch, it'll stay around 2000rpm to 2500 for a few seconds then drop to 500 - 700
20130201_193454 by todd5854, on Flickr
todd5854 is offline   Reply With Quote
Old 02-01-2013, 05:46 PM   #2
todd5854
Note-
I know there are no hoses on my egr. I removed the BPT and plugged the vacuums going to it / them. EGR is next to go. Also that hose with no clamps on it... that hose is not leaking. It is mangled and will be replaced. Car has been running fine for 5 months, this problem came up a week ago and I still can't figure it out.
Old 02-01-2013, 07:02 PM   #3
godsmack
godsmack's Avatar
godsmack is an unknown quantity at this point
Manifold gasket or injector o-ring. I'm leaning more towards the manifold gasket being shot there. Get new gasket and replace.
godsmack is offline   Reply With Quote
Old 02-01-2013, 07:11 PM   #4
steve shadows
steve shadows's Avatar
Here's a way to know for sure: DIY How-to: build a vacuum leak detection machine - Pennock's Fiero Forum
Like Me on FaceBook !
Old 02-01-2013, 07:27 PM   #5
todd5854
I already replaced my intake manifold a few months ago. New gasket obviously lol.
My o ring gaskets are hard as rock. They can be changed.
Other symptoms..
Driving just above 2000rpm if I push clutch in the revs go to 2500 then drops to idle.
Sprayed starter fluid on injector no. 4 and idle went smooth for short time
At wide open throttle (WOT) I hear whining from 3k to about 6k
Old 02-01-2013, 08:34 PM   #6
Frank_Jaeger
Frank_Jaeger is an unknown quantity at this point
Other symptoms..
Doesn't mean jack if the manifold isn't flush with the head. Did you reinstall the braces for the lower manifold?
EDIT: If you're getting new o-rings, you can get them from FRSport. http://www.frsport.com/OEM-Upper-and...ts_p_1325.html
Frank_Jaeger is offline   Reply With Quote
Old 02-02-2013, 10:16 AM   #7
todd5854
The braces... those 3 14mm bolts? Only one would go in.
I purchased new o-rings, and seals for the 4 injectors for $20.
Mine are hard as a rock so it won't hurt to just change them anyway.. when I swapped manifolds I reused them too, that's two strikes against those shitty ones.
I agree with you, it seems like it would be a leak from my manifold..hopefully not a crack.
I have another one I can put in if all else fails.
Old 02-02-2013, 01:33 PM   #8
todd5854
Oh by the way, when the car is COLD the idle is normal.
Old 02-02-2013, 01:45 PM   #9
Frank_Jaeger
Did you install that one bolt for the brace before or after you bolted the IM to the head?
When the car idles cold it's usually running at a high enough RPM that a vac leak isn't apparent.
Old 02-02-2013, 09:21 PM   #10
todd5854
Brace installed after bolted to head. and yeah that makes sense.
cold it idles at 1000 now (this is also normal)
warm it idles 400- 1100 its all over the fucking place
Old 02-02-2013, 11:35 PM   #11
todd5854
injector o-rings and seals for all 4 injectors are on the way. Getting my intake manifold ready for replacement..... gonna order those gaskets as well.
Would anyone recommend changing the knock sensor? It's like $60 but I don't want to spend the money if I don't have to... my 94 ecu had CEL for knock sensor, but when I swapped manual, the 92 ecu is throwing no codes.
