Old 11-05-2014, 07:46 PM   #121
Big Zee
Big Zee's Avatar
Big Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choices
Originally Posted by Options13 View Post
been a while since i have posted on here!!
Yes, a big turbo is defiantly in the making!!
some Quick FIX pics.
On hot days i've been having some over heating issues because my intercooler was mounted to close to my radiator. So now i am going with a v-mount setup, along with a twin scroll turbo, and cage.
I am unsure on what top mount turbo to run, maybe you guys will have a some suggestions for me?
I'm looking for full boost by 3500, and 450-500whp. I've been reccomended a few turbos, PTE5858, GTX3076, GTX 3576, Borg Warner efr 7670, and Borg Warner S358.
I have no idea which one i really want though!
Here's a quick teaser video of what in store for the car in 2015
I will begin updating this thread regularly again!
https://www.youtube.com/watch?v=8Vps...ature=youtu.be
if your aiming for a really responsive motor, I recommend a GTX3076 in a .64AR, big power then go with the GTX3576 in a .64 or .73 AR
Great build so far, watched the Dyno run at PSI vid and it sounds so good, keep up the outstanding work, but may I suggest some attention to brakes
maybe a set of 30mm Z brakes to a 350Z rotor for the fronts and full z32 rear brakes, would help keep the car from doing sad things in tight places
Two-Tone owner#011509-Lightly Modded
Old 11-06-2014, 06:38 PM   #122
Options13
Options13's Avatar
Trader Rating: (43)
Options13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the rough
Feedback Score: 43 reviews
buying the EFR 7670 tonight! i think it will be the right decision..hopefully!
Drift team page
www.facebook.com/savageimpression
Options13 is offline   Reply With Quote
Old 11-10-2014, 02:39 PM   #123
Mannykiller
Mannykiller's Avatar
Mannykiller is an unknown quantity at this point
Thanks for your input mannykiller!
The car will be used to mainly street drifting / events. Mainly Drifting though. I plan on running race gas at the track, but on the street i am just going to run 91 oct plus water meth.
From the sounds of it, it looks like i may be better off with the 7064 .92 housing and just weld the internal wastegate shut?
I want quick response.. I currently have the M8280 and the response on that was awesome. is the 7064 .92 about the same size as my tomei?
THe 7670 is a good choice. I don't have any experience with the m8280. Just Garrett's GTX series and BW EFR's and even though I thought my GTX3582 spooled up quick.... the EFR smoked it. I really don't think there is much of a comparison. Put it this way... MY EFR is pushing more air into my Engine than It can handle. That wasn't the case with my GTX. I think it'd be smarter to go with the 7064...for response...but even the 7670 is going to be just fine. You'd only notice the difference if you drove them back to back. Trust me your going to be happy either way. But NO DO NOT weld the INternal wastegate shut...... how will you control boost? That's a really really bad idea. THe internal wastegate on the EFR's work great, some argue better than external counterparts... even at higher boost levels. The only reason to go external would be if you planned to run some astronomically high boost pressure... like 30+ Lbs of boost.
IG:@AAPARKAH #ThisIsTheWolf
Mannykiller is offline   Reply With Quote
Old 11-10-2014, 03:45 PM   #124
finalimport
finalimport is an unknown quantity at this point
looking good
finalimport is offline   Reply With Quote
Old 11-10-2014, 08:28 PM   #125
Options13
Options13's Avatar
Trader Rating: (43)
It's between the PTE 5862 and the s358..
s358
-11 blade GTX58mm compressor wheel ( quicker spool )
-360 HD thrust pad upgrade ( quicker spool)
-quick spool turbine wheel
-.83ar twinscroll hotside
main difference will be journal vs ball bearing... what should i do!!
and will one hit my power goal easier than the other?
i'm expecting around 15psi around 3500rpms, and want to run around 20-30 psi max.
I'm aiming for 500whp and also on pump gas and water/meth.
Drift team page
Old 11-11-2014, 01:02 AM   #126
Options13
Options13's Avatar
Trader Rating: (43)
never mind, i decided on the EFR 7670 with 1.05 exhaust housing.
Seems like the best option for the response/power i'm looking for.
Drift team page
Old 11-12-2014, 12:20 PM   #127
Mannykiller
^ excellent Choice!!!
You won't be disappointed! Trust me!
Old 11-14-2014, 12:20 AM   #128
Options13
Options13's Avatar
Trader Rating: (43)
ahh well now I'm kind of stuck what i want..
Either the EFR with the .92 housing or the 1.05 housing.
The .92 housing is internally castigated, and i would just be welding that shut and running two 38mm tial wastegates..
or just get the 1.05 and maybe buy a quick spool valve to make up for the difference in price..?
the .92 is about $300 more... and i wouldn't even be using the internal wastgate..
ANYWAYS, i got my new kit fitted up!!
One of my sponsor's, TEAM SDMF doing work on the JZ chase!
Drift team page
Old 02-19-2017, 10:16 PM   #129
Options13
Options13's Avatar
Trader Rating: (43)
2 years later i have the car back guys!! this thread is coming back to life!!!
Drift team page
Old 02-22-2017, 09:03 AM   #130
snatchmarks
snatchmarks's Avatar
snatchmarks is an unknown quantity at this point
holy shit that tubing work is incredible..
snatchmarks is offline   Reply With Quote
Old 03-02-2017, 06:28 PM   #131
Silviacraze05jr
Silviacraze05jr is an unknown quantity at this point
Anyone done vvti 1.5jzgte? Lots of non vvti but haven't seen here using the vvti 1jzgte head.
Silviacraze05jr is offline   Reply With Quote
Old 03-16-2017, 06:38 AM   #132
AscendaShogun
AscendaShogun's Avatar
AscendaShogun is a jewel in the roughAscendaShogun is a jewel in the roughAscendaShogun is a jewel in the roughAscendaShogun is a jewel in the roughAscendaShogun is a jewel in the roughAscendaShogun is a jewel in the roughAscendaShogun is a jewel in the roughAscendaShogun is a jewel in the rough
damn, bump of the century...
SuperRadDriftyFranz
'88 S13 Silvia
Originally Posted by LockOn! View Post
decrepit teenage shitsleds
Originally Posted by LoSt180 View Post
"Cut my springs, car is bouncy, will a camber kit help?"
AscendaShogun is offline   Reply With Quote
