Old 03-31-2008, 11:59 AM   #1
aziankingz
aziankingz's Avatar
Trader Rating: (28)
aziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really nice
Feedback Score: 28 reviews
need help!
Hi All,
Ok, I just replaced my new clutch with an EXEDY OEM replacement, plus an 11lb lightweight flywheel from F1 Racing. I need to know if the following is normal for the breaking in period for a new clutch: The shifter gets very stiff and starts to vibrate (no violent vibrations, just pulsing vibrations) after 2500RPMs. The thing is, the shifter gets stiff but once i press the clutch to change gears it is fine, however, it seems to grind in most or all gears too! Any ideas on what this can be?
aziankingz is offline   Reply With Quote
Old 03-31-2008, 01:20 PM   #2
emersonLP
emersonLP's Avatar
emersonLP has a reputation beyond reputeemersonLP has a reputation beyond reputeemersonLP has a reputation beyond reputeemersonLP has a reputation beyond reputeemersonLP has a reputation beyond reputeemersonLP has a reputation beyond reputeemersonLP has a reputation beyond reputeemersonLP has a reputation beyond reputeemersonLP has a reputation beyond reputeemersonLP has a reputation beyond reputeemersonLP has a reputation beyond repute
Send a message via AIM to emersonLP
Try bleeding your clutch slave, or maybe you need to adjust the engagement point on your pedal.
Me- "what the f*ck did we do to my boost controller" Brandon-"I dunno?"
emersonLP is offline   Reply With Quote
Old 03-31-2008, 02:02 PM   #3
aziankingz
aziankingz's Avatar
Trader Rating: (28)
the clutch pedal/master cylinder rod was adjusted last week and the slave was bled after the clutch was changed..any other ideas? the pedal feels good, just might be grinding due to me not used to the height of the pedal since before the clutch change, i adjusted the pedal lower.
Old 03-31-2008, 02:21 PM   #4
5t341tH
5t341tH's Avatar
5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute
Send a message via AIM to 5t341tH
do u still have the clutch dampener on there? its a square box that leads to the slave
5t341tH is offline   Reply With Quote
Old 03-31-2008, 02:29 PM   #5
aziankingz
aziankingz's Avatar
Trader Rating: (28)
yeah its still on there..
