Old 01-21-2015, 04:54 PM   #1
beems240sx
beems240sx's Avatar
beems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant future
The S14 part out you've been waiting for... tons of parts!
It's finally time to let this car go. I built it up from a bare shell to where it is now. Im moving on to finding myself the perfect FD so everything on this car must go. My car must remain a roller until May, unless of course the shell sells before then or if you bring me stock parts. i might be able to get it full stripped much sooner and i will update this thread when that happens. ALL PRICES DO NOT INCLUDE SHIPPING.
Shell
-Clean Illinois Title in hand
-Fully undercoated with POR15 and 3M rubberized spray
-Tubbed front wheel wells and stitched seams
-All bay holes welded up and grinded down
-trunk cut out and 15 gallon RCI fuelcell mounts welded in
-Engine bay painted sparkle purple
-Exterior painted nissan AR2
-Brand new windshield
-Rear quarter panels cut and welded for widebody
-Interior is stripped, still has dash and door panels
-Refinished subframes with POR15
-Stance solid subframe risers
-Energy suspension rack bushings
-Will come with hood, trunk, doors, taillights
SOLD (This is for a nonrolling shell, add parts below to make it rolling or bring your own.)
Suspension
-Stance GR+ coilovers SOLD
-ISIS/Megan adj. arms with SPL ecc. lockout bolts (POR) $350
-OEM rear lower control arms reinforced plates new moog ball joints (POR) $200
-Moog inner tierods TF outers $100
-Brand new OEM 5 lug hubs SOLD
-Front knuckles SOLD
-OEM rear knuckles w/ energy suspension bushings $100
Brakes
-300zx 26mm front calipers w/ hawk hps pads, new hardware SOLD
-300zx 26mm front rotors used SOLD
-300zx 30mm front rotors brand new $100
-300zx rear calipers and rotors SOLD
-300zx rear ebrake backing plates, shoes, hardware (missing one spring) $150
-DIF stainless steel front lines SOLD
-ASD 16" Hydro w/bolt in mount by shifter PC sparkle purple with custom made brake lines, banjo off master. rear runs to hydro through firewall then mounts to T above rear subframe to rear calipers SOLD
-300zx master cylinder SOLD
-brake booster SOLD
-clutch master SOLD
Interior
-Sparco Corsa seat minimal fart stains SOLD
-Bride seat mount w/sliders SOLD
-NRG blue harness bar SOLD
-TeamTech 6 point harness Purple w/ white stitching SOLD
-NRG 4 point $can of monster and we burn it together
-NRG purple quick release (gen2 or 3?) SOLD
-Purple bubble shift knobs SOLD
-Moroso switch panel SOLD
-Autometer Phantom2 Boost, Water, Fuel $150
-Fardi steering wheel, pretty beat SOLD
-Innovate lc1 SOLD
-stock shifter SOLD
-Dash SOLD
Electrical
-AEM EMS V2 w/ water, boost, MAP, IAT sensors. CAS w/trigger disk, wiring specialties AEM harness, ID injector pigtails. currently tuned for my setup by Tony at UMS. SOLD
Exterior
-Origin stylish kit, sideskirts and rear bumper sold. Front still available for $200
-Origin front fenders SOLD
-Origin type2 50mm rear SOLD
-Circuit sports clear headlights SOLD
-Origin clear corners SOLD
-Kouki Wing SOLD
Engine
-PBM highmount intercooler w/tial flange SOLD
-HKS cam gears SOLD
-Garrett GT2871R .86 SOLD
-Tial BOV blue SOLD
-ISIS pulleys WP and PS, PC sparkle purple $80
-HKS divided o2 housing SOLD
-Circuit Sports downpipe w/flex $80
-Circuit Sports test pipe SOLD
-Thermostat housing and water neck PC sparkle purple $80
-Stance water neck adapter $35
-ISIS intake manifold PC sparkle purple w/iacv + tbody SOLD
-Throttle cable bracket PC sparkle blue $30
-Mishimoto Radiator w/fans SOLD
-Samco rad hoses SOLD
-ISIS oil cooler SOLD
-Solid motor mounts $40
-OBX crank pulley SOLD
-ISIS catback SOLD
-powersteering resovior $20
-Earls stainless turbo lines SOLD
-stage8 locking SOLD
Fuel
-RCI 10 gallon fuel cell SOLD
-Fuelab dual inline filters -8an anodized purple SOLD
-Parker nylon feed and return line -8an SOLD
-Injector Dynamic ID1000's SOLD
-Circuit Sports top feed rail SOLD
-Fuelab FPR anodized purple w/guage and -8an fittings SOLD
-Bosch044 -8an fittings SOLD
Driveline
-Suburban driveline 1 piece steel driveshaft SOLD
-Welded diff POR coated SOLD
-DIF solid diff bushings SOLD
-Axles $30each
-Tennessee clutch supply 6 puck $150
Wheels
-Dai Yoshihara Champions 18x10 +15 SOLD
i will post general pictures of the car, if you want something specific please ask and i will get it to you asap. please view my build thread for more pictures also.
if it is not listed, it is not currently forsale
beems240sx is offline   Reply With Quote
Old 01-21-2015, 05:15 PM   #2
kerrykerrykerry
kerrykerrykerry is not welcome here anymorekerrykerrykerry is not welcome here anymorekerrykerrykerry is not welcome here anymorekerrykerrykerry is not welcome here anymorekerrykerrykerry is not welcome here anymorekerrykerrykerry is not welcome here anymorekerrykerrykerry is not welcome here anymorekerrykerrykerry is not welcome here anymore
Peak trans mount come with all four bolts? Also, street or track version? Thanks
kerrykerrykerry is offline   Reply With Quote
Old 01-21-2015, 05:22 PM   #3
beems240sx
beems240sx's Avatar
sure ill include the hardware. i dont know what version, i assume track
Old 01-21-2015, 10:35 PM   #4
iHateMySilvia
iHateMySilvia's Avatar
Trader Rating: (30)
iHateMySilvia is an unknown quantity at this point
Feedback Score: 30 reviews
Any broken fans or damage on headlights?
NaVanBrosガレ​​ージLtd,Co.
iHateMySilvia is offline   Reply With Quote
Old 01-21-2015, 11:20 PM   #5
beems240sx
beems240sx's Avatar
broken fans? headlights are pending right now just awaiting payment
Old 01-21-2015, 11:28 PM   #6
Dauzat's 40
Dauzat's 40's Avatar
Dauzat's 40 is an unknown quantity at this point
Sent you a pm.
Dauzat's 40 is offline   Reply With Quote
Old 01-21-2015, 11:33 PM   #7
da_crew10
da_crew10's Avatar
da_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond repute
That is an awesome deal on the shell. Pm me a price shipped on the FPR & wideband.
Dudes voice makes my arm feel punchy.
da_crew10 is offline   Reply With Quote
Old 01-22-2015, 06:18 AM   #8
Twosteptj
Twosteptj is an unknown quantity at this point
Pm a price for both the coilovers and the ebrake. With pictures as well. I can ship my struts and springs to you to keep it a roller
Twosteptj is offline   Reply With Quote
Old 01-22-2015, 06:59 AM   #9
beems240sx
beems240sx's Avatar
You'll need to pm me your zipcode please.
Old 01-22-2015, 09:35 AM   #10
beems240sx
beems240sx's Avatar
I'm getting bombarded with messages so please be patient and bear with me while I get quotes. I also work 50 hour weeks so I'll be as quick as I can be. I should hopefully be able to move the car and get it on jack stands this weekend or next. Thank you for choosing beems240sx your one stop thread for rad s14
Old 01-22-2015, 12:43 PM   #11
iHateMySilvia
Trader Rating: (30)
Oops ment tabs lol not fans , let me know if the headlights don't sell
Old 01-22-2015, 12:50 PM   #12
Mcpot132
Mcpot132 is an unknown quantity at this point
I'll take the master cylinder shipped to 60614
Mcpot132 is offline   Reply With Quote
Old 01-22-2015, 03:19 PM   #13
sw20>>s14
sw20>>s14's Avatar
Damn shame to part out something so clean. Bump for you!
sw20>>s14 is offline   Reply With Quote
Old 01-22-2015, 03:26 PM   #14
JSimpson
Banned from the Marketplace
JSimpson is an unknown quantity at this point
^^^ NO KIDDING! This thing is beautiful, such a shame it doesn't get to stay in this glory. Interested in the bride rail and z32 BMC. Ready to send payment
JSimpson is offline   Reply With Quote
Old 01-22-2015, 03:26 PM   #15
KOUKIboy
KOUKIboy's Avatar
KOUKIboy is making his/her stupidity well-knownKOUKIboy is making his/her stupidity well-knownKOUKIboy is making his/her stupidity well-knownKOUKIboy is making his/her stupidity well-known
Oh no, say it ain't so!!! This Zenki was sooo Rad!!! interested in the Kouki wing and I'm local....
[SIGPIC][/SIGPIC] http://wheelflip.com/r/Wheelwhore87
KOUKIboy is offline   Reply With Quote
Old 01-22-2015, 03:52 PM   #16
beems240sx
beems240sx's Avatar
I'm working out a deal on the rail and seat combo currently. I'd prefer to sell it that way.
I just opened a FedEx account so I am working on all shipping quotes currently
Old 01-22-2015, 04:06 PM   #17
S14kouki805
S14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud of
Are you selling any interior tidbits? I need a drivers side power window regulator and switch...
S14kouki805 is offline   Reply With Quote
Old 01-22-2015, 04:07 PM   #18
JSimpson
these are damn good prices
Old 01-22-2015, 07:02 PM   #19
beems240sx
beems240sx's Avatar
ALL parts that are sold are updated.
i believe i got everyone a shipping quote and already sent out a few parts! lets keep this going! snag what you want before tax season and someone else does!
Old 01-22-2015, 10:18 PM   #20
Skullrx3
Skullrx3 is an unknown quantity at this point
I rear calipers 28303
Skullrx3 is offline   Reply With Quote
Old 01-22-2015, 11:12 PM   #21
Drift_86
Drift_86's Avatar
Trader Rating: (60)
Feedback Score: 60 reviews
Is that oem kouki wing
Old 01-24-2015, 02:45 AM   #22
KAs14slider
KAs14slider is making a name for him/her selfKAs14slider is making a name for him/her selfKAs14slider is making a name for him/her self
I'm just waiting on a shipping quote for the front calipers. I want them. I sent you a pm.
Corndrift Blog
KAs14slider is offline   Reply With Quote
Old 01-24-2015, 08:40 AM   #23
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
That tranny mount is the "Pro"/track version. You can see it's black in the pic.
http://www.frsport.com/Peak-Performa...15_p_1249.html
Old 01-24-2015, 01:24 PM   #24
beems240sx
beems240sx's Avatar
I possibly have a buyer for the rolling shell. I will keep everyone updated. Thank you.
Old 01-24-2015, 02:25 PM   #25
94NissanSilviaS14
94NissanSilviaS14 is an unknown quantity at this point
Is the rad still available ?
Sent from my iPad using Tapatalk
94NissanSilviaS14 is offline   Reply With Quote
Old 01-24-2015, 02:30 PM   #26
94NissanSilviaS14
Pm me ur mail box is full interested in intercooler too
Old 01-24-2015, 05:06 PM   #27
S14_ZX10R
S14_ZX10R is an unknown quantity at this point
are all these still available and how much power u make on those 1000cc injectors Fuelab dual inline filters -8an anodized purple $180
-Parker nylon feed and return line -8an $80
-Injector Dynamic ID1000's $380
-Circuit Sports top feed rail $120
-Fuelab FPR anodized purple w/guage and -8an fittings $160
-Bosch044 -8an fittings $180
S14_ZX10R is offline   Reply With Quote
Old 01-24-2015, 06:48 PM   #28
beems240sx
beems240sx's Avatar
Yes it is
Intercooler is pending to a friend currently. I'll message you if it's available next week
All available still. I made 470rwhp on 91 octane 19psi. This fuel system should handle nearly anything. Could run another bosch044 if needed
Old 01-25-2015, 01:53 AM   #29
94NissanSilviaS14
I'll take the rad for sure then ! No leaks and still in good shape ??
Old 01-25-2015, 03:59 AM   #30
KAs14slider
Hey do you still have the calipers or are you leaving them on the car when you sell the chassis? If you still got the front calipers, I want them. I just wanted to get a shipping quote to zip 16803.
Corndrift Blog
