Old 01-19-2013, 09:53 AM   #1
vutony
vutony's Avatar
Trader Rating: (145)
vutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfection
Feedback Score: 145 reviews
Arrow *** SR20 Parts *** 2013 Garage SALE - ALL must GO GO GO!!
Check out my Feedback or Trader Rating
Located in Garden Grove, CA. 92843.
Email/Paypal ID - [email protected]
Call/Text -
7I4-951-thirty 47
Price does NOT include shipping and shipping is not free. Please add 3% for PayPal or send as gift. NO trades b/c CASH is KING. I delete ALL sold parts within 24 hours so if you see it here, its available.
* For instant respond, reply to this thread since it will forward to my cell.
My other thread:
Here are the last of my 240 parts I have left. The majority of the performance parts were purchased new from either phase2motortrend.com or frsport.com. Some parts looks dirty but still in great shape with minimal miles on them. I will clean them prior to shipping. This is a rough draft of my for sale thread. I will update this ad frequently and will be adding more parts. Now onto the parts...
S13/S14 2-Way Tomei LSD - SOLD
Spare diff parts
Axles bolts (complete set) - $40 shipped
Driveshaft bolts (4) - $20 shipped
Diff bolts to subframe (2) - $15 shipped
Diff cover bolts (8) - 20 shipped
Diff fill 1/2" ratchet bolt (1) - $10 shipped
Diff drain -sold
Tomei diff gasket - $20 shipped
(used but very little miles and looks new)
S13 diff cover - SOLD
Full Race Pro Stock Manifold - SOLD
i have engine hoist for rent
i do SR wiring
vutony is offline   Reply With Quote
Old 01-19-2013, 09:55 AM   #2
vutony
vutony's Avatar
350Z G35 Brembo Slotted Rotors Front Set $220 (Purchased new at FR @ $389.95 plus tax)
- In great shape with less than 2,000 miles.
- Has a minor defect from the calipers rubbing on the rotors.
- Rotors measured 30.16mm, minimum is 28.4mm.
- Rotors are 12.75 in diameter
Z32 Front conversion brackets to use 350Z rotors
The brackets below are sold.
i do SR wiring
Old 01-19-2013, 09:57 AM   #3
vutony
vutony's Avatar
Nismo radiator cap - $20 ($55 @ frsport.com)
Mishimoto radiator cap - sold
OEM S13 SR20DET Fuel Rail w/ injector caps - sold
i do SR wiring
Old 01-19-2013, 09:58 AM   #4
vutony
vutony's Avatar
Intake hose from SR Greddy manifold kit - $10
i do SR wiring
Old 01-19-2013, 10:00 AM   #5
vutony
vutony's Avatar
OEM SR headstuds - $40
- In excellent shape
- Has about 5,000 miles on them
SR20DET Exhaust Manifold Inlet Gasket - $8 each shipped, 1 left
OEM SR20DET 5 Hole Turbo Outlet Gasket - $8 each shipped, 1 left
- Gaskets are used but still in good shape
- I have reused them before and had no problem with leaks
SR20 Turbo Oil Return Tube - $20
SR20 5 speed flywheel bolts (8) - $30
- bolts are in good shape, not stripped
S13 SR20DET dipstick w/ tube - $20
Crank pulley bolt and washer - $30
i do SR wiring
Old 01-19-2013, 10:01 AM   #6
vutony
vutony's Avatar
SOLD
S13 SR20DET knock sensor w harness
S13 SR20DET coil pack harness
S13/S14 SR20DET 7 Layers Metal Exhaust Manifold Gasket
S13 SR20DET motor mount brackets
S13 SR20DET Megan Racing Pulley Set
S13 SR20DET starter
Garrett GT2871R Ball Bearing Turbo w/ HKS actuator
S13 SR20DET TAKA Turbo Lines
S13 SR20DET alternator
S13 SR20DET AAC Valve
S13 SR20DET PS pump
S13 SR20DET PS bracket and hardware
S13 SR20DET Greddy Intake Manifold
OEM S13/S14/S15 SR20DET O2 Sensor
Intial D toy cars
DIF Dual Electric Fan Controller
3" custom aluminum cold pipe
FRS Polished Aluminum Hotpipe S13 SR20DET
S13 SR20DET coil packs
S13 stock motor mounts
Tomei/N15 TB 70mm throttle body
Nismo/Tomei 740cc Fuel Injectors
Nismo Fuel Pressure Regulator Type-B
S13 SR20DET water inlet
Toda Flywheel
RPS Max Street Clutch
S13 SR20DET water outlet
S13 H4 Hella Headlight Housings
Power Enterprise 4PK865 V-Belt
S13 SR20DET Tomei 3" elbow
S13/14/15 ARC Oversize Oil Pan
S13 SR Koyo radiator
S13 SR20DET Pro Fab Design Intake Manifold Gasket
S14 SR20DET TPS
Redtop head
DPI Rocker Arm Stopper
Valve cover hardware (rubber grommets, washers, SS nuts
Walboro fuel pump
Nismo SR13 thermostat
S14 SR20DET engine harness
i do SR wiring
Old 01-19-2013, 12:49 PM   #7
lilrusty
lilrusty's Avatar
Trader Rating: (37)
lilrusty is an unknown quantity at this point
Feedback Score: 37 reviews
What 350z rotors would i use to use those brackets for my 30mm z32 front brakes? Pm me thanks
lilrusty is offline   Reply With Quote
Old 01-26-2013, 09:16 AM   #8
vutony
vutony's Avatar
the ones i have listed works. Im looking to sell the rotors.if the buyer needs the brackets i can get it for them. not selling brackets beside that
ps, the fullrace mani and sr cas should be sold soon
i do SR wiring
Old 01-26-2013, 10:18 AM   #9
outlawstar1023
outlawstar1023 is an unknown quantity at this point
Send a message via AIM to outlawstar1023
Nismo Engine oil cap is sold to me, thanks.
outlawstar1023 is offline   Reply With Quote
Old 01-26-2013, 02:05 PM   #10
OriginalB69
OriginalB69's Avatar
OriginalB69 is an unknown quantity at this point
Got a sr20det Water Pump? I have cash
OriginalB69 is offline   Reply With Quote
Old 01-28-2013, 10:38 AM   #11
vutony
vutony's Avatar
yupp and will be shipped today
sorry no
i do SR wiring
Old 01-28-2013, 10:27 PM   #12
ShadowMan
ShadowMan's Avatar
ShadowMan is an unknown quantity at this point
Still have the tomei 2 way?
in any situation....thou shalt blaze
ShadowMan is offline   Reply With Quote
Old 01-29-2013, 12:45 AM   #13
KevinEdgar
KevinEdgar's Avatar
KevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to all
$70 shipped for the SR bell housing?
http://milktea-man.com
KevinEdgar is offline   Reply With Quote
Old 01-29-2013, 11:39 PM   #14
vutony
vutony's Avatar
YES pm'd
pm sent
i do SR wiring
Old 02-18-2013, 10:54 AM   #15
vutony
vutony's Avatar
RIP Jerry Buss, my thoughts and prayer go to you and your family.
GO LAKERS!
i do SR wiring
Old 02-18-2013, 11:53 PM   #16
tyler734
tyler734 is an unknown quantity at this point
hey man, do you happen to have a valve cover gasket for a redtop.
pm me if so, if not, free bump for you.
thanks
tyler734 is offline   Reply With Quote
Old 02-19-2013, 02:03 PM   #17
tyler734
valve cover gasket sold
Old 02-28-2013, 11:21 AM   #18
vutony
vutony's Avatar
thanks
yupp thanks for your business
i do SR wiring
Old 03-08-2013, 12:49 AM   #19
mailman31090
mailman31090 is an unknown quantity at this point
chain tensioner sold to me
mailman31090 is offline   Reply With Quote
Old 03-14-2013, 01:29 PM   #20
OriginalB69
I need a part from a tranny, PM Sent
Old 03-21-2013, 11:01 PM   #21
vutony
vutony's Avatar
yup and shipped
sure lmk
i do SR wiring
Old 03-31-2013, 06:26 PM   #22
vutony
vutony's Avatar
happy easter!
i do SR wiring
Old 04-07-2013, 09:29 PM   #23
Dbruesch
Dbruesch is an unknown quantity at this point
do you have working tb and iacv for redtop? if so how much
Dbruesch is offline   Reply With Quote
Old 04-14-2013, 09:13 PM   #24
vutony
vutony's Avatar
sorry no..................
i do SR wiring
Old 04-15-2013, 12:41 PM   #25
SlideMyRide
SlideMyRide's Avatar
SlideMyRide can only hope to improve
Redirect Notice do u have these for a red top
SlideMyRide is offline   Reply With Quote
Old 04-15-2013, 12:45 PM   #26
SlideMyRide
http://i34.photobucket.com/albums/d1...p/HPIM0245.jpg redtop power steering banjo bolt and connector
Old 04-20-2013, 09:14 AM   #27
vutony
vutony's Avatar
sorry no
Happy April 20th!
i do SR wiring
Old 04-20-2013, 11:09 PM   #28
idc101
idc101 is an unknown quantity at this point
Do you have sr fuel pump relay?
idc101 is offline   Reply With Quote
Old 04-27-2013, 10:59 AM   #29
vutony
vutony's Avatar
Yes if same as ka
i do SR wiring
Old 05-05-2013, 10:31 AM   #30
vutony
vutony's Avatar
bumpitup!!
i do SR wiring
