Old 03-26-2018, 06:17 AM   #1
brokeboi01
brokeboi01's Avatar
brokeboi01 will become famous soon enoughbrokeboi01 will become famous soon enoughbrokeboi01 will become famous soon enoughbrokeboi01 will become famous soon enoughbrokeboi01 will become famous soon enough
180sx sr20det blacktop (non notch) s13 or s14 VSS?
My 240 came w the 180sx (not notchtop) blacktop sr and the speed always read exponentially (ie 10 at 25 15 at 30 mph). When i first pulled out the vss it was an s14 vss. Bought a new one assuming this one was defected but still no result. Is it possible i have an s14 trans w my engine which is causing a whole shitstorm or should i stick w an s13 vss? Ive looked through other vss threads but they really have no clear answer.
Sent from my SM-G950U using Tapatalk
brokeboi01 is offline   Reply With Quote
Old 03-26-2018, 08:21 AM   #2
jedi03
I think it would be either your final drive or the speedo...
Old 03-26-2018, 09:06 AM   #3
Krusty_s13
Krusty_s13's Avatar
Krusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud of
Stuff a s13 VSS in there. s13 or s14 trans, doesn't matter. The VSS should coincide with the cluster you are using.
Krusty_s13 is offline   Reply With Quote
Old 03-26-2018, 10:26 AM   #4
brokeboi01
brokeboi01's Avatar
Does that mean getting a different vss gear as well? The one currently inside the trans wont fit the s13 vss insert, its way thicker than the s14 insert.
Old 03-26-2018, 11:43 AM   #5
Krusty_s13
Krusty_s13's Avatar
Not 100% sure what you're getting at. I had a blacktop in a s14 but it used a s13 vss, speed read double. plopped in a s14 vss and speedometer read fine. I would just grab a s13 vss with the red gear (as it comes stock). Sorry if im not helping much lol.
s13:
s14:
Old 03-27-2018, 08:00 AM   #6
jedi03
should just come out and new one should come with a gear...autozone has em for about 100 iirc...
