Old 01-20-2019, 01:29 PM   #1
R3b
R3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond repute
SR20VVL long block, trans, turbo setup
Hollywood FL 33020
Listing for a friend, willing to ship at buyers expense, can also get compression results but last time we checked it after buying car it was within spec. Any messages i'll link you to the owner either facebook or by number.
Full turn key swap $4500 obo
Available to purchase in parts.
Motor/head/ harness-$3250
Turbo kit- $1000
Transmission- $300
Differential- $300
Driveshaft- $100
Ecu-$100
Parts listed below
Motor:
S13 sr20 built block
Manely turbotuff I beams rods
Cp pistons
Oem sr20 crank pulley machined for vvl set up
ARP head studs
New rear main seal
Neo vvl converted intake manifold
All the other vvl add ons that are required to complete the set up.
Head:
Neo vvl P11 head
Cometic multi layer steel head gasket
N1 cams.
Turbo kit:
Gt35 turbo 64trim A/R .70
God speed intercooler (big as hell)
Hks bov
(Unknown) wastegate.
Xs power down pipe
All the necessary piping
Drivetrain:
Stage 4 clutch
Light weight flywheel
Sr20 transmission
2 piece drive shaft
Z32 diff
Engine management:
Rs enthalpy ecu
Wiring specialties engine harness
R3b is offline   Reply With Quote
Old 01-29-2019, 07:25 AM   #2
err
err is an unknown quantity at this point
is he willing to split with the head?
err is offline   Reply With Quote
