Old 10-30-2012, 07:33 AM   #91
Turbo Nismo
Turbo Nismo's Avatar
Trader Rating: (18)
Turbo Nismo is an unknown quantity at this point
Feedback Score: 18 reviews
Keep up the good work. Super sick build. I wan't to learn how to weld so bad.
IG: chris___s14
Turbo Nismo is offline   Reply With Quote
Old 11-02-2012, 12:39 PM   #92
Chad Dugan
Chad Dugan's Avatar
Chad Dugan is an unknown quantity at this point
Thanks again for all the respect guys.
I am fortunate enough to have access to a full fabrication shop and was able to replicate this Racepak mounting bracket and get a few pieces made on a CNC plasma.
I also went back and added over 20 new pictures of specific things you guys have asked for - let me know if there is anything you guys would like to know more about or see more detailed pictures of.
Thanks, Chad
Chad Dugan is offline   Reply With Quote
Old 11-05-2012, 07:48 PM   #93
food7373
food7373 is an unknown quantity at this point
Niceeee........
food7373 is offline   Reply With Quote
Old 11-06-2012, 10:13 AM   #94
Royal_T
Royal_T's Avatar
Royal_T is an unknown quantity at this point
pretty badass
http://zilvia.net/advertise.html
Royal_T is offline   Reply With Quote
Old 11-07-2012, 03:05 AM   #95
smithrcing17
smithrcing17's Avatar
smithrcing17 is an unknown quantity at this point
Hey chad do you have a picture of your roll cage right at the top of front window where your rear view mirror would be? Did you have to take out your head liner?
smithrcing17 is offline   Reply With Quote
Old 11-07-2012, 01:11 PM   #96
Chad Dugan
Chad Dugan's Avatar
I pulled all the interior bits including the headliner and rear view mirror for this car and had the bar basically touching the roof. The headliner was not important to me in this case.
Old 11-07-2012, 01:21 PM   #97
NismoTuner21
NismoTuner21's Avatar
NismoTuner21 will become famous soon enoughNismoTuner21 will become famous soon enoughNismoTuner21 will become famous soon enough
JIZZ!
Whats the name of that color? I love it.
NismoTuner21 is offline   Reply With Quote
Old 11-12-2012, 07:41 AM   #98
Chad Dugan
Chad Dugan's Avatar
Originally Posted by NismoTuner21 View Post
JIZZ!
It was actually just a blend of gunmetal and dark grey that we had left over in the shop, it has a gold flake in the sunlight too, something I haven’t been able to catch on camera yet.
Old 12-27-2012, 04:29 PM   #99
Teigen
Teigen's Avatar
Teigen is an unknown quantity at this point
any updates?
Don't PM me asking for parts
Teigen is offline   Reply With Quote
Old 12-27-2012, 11:15 PM   #100
bc.
bc.'s Avatar
bc. is an unknown quantity at this point
holy thread batman! this is good stuff.
* S14SR22 * 9.0 c/r * GT3071R *
bc. is offline   Reply With Quote
Old 02-05-2013, 02:25 PM   #101
Chad Dugan
Chad Dugan's Avatar
Thanks for all the comments, I have learned so much while doing this build!
I took some time while breaking down the chassis harness, to make a few block off plates and a switch panel tucked inside the arm rest. I think nothing in the cockpit is so clean.
Old 02-05-2013, 03:35 PM   #102
Teigen
Teigen's Avatar
Hey man dont steal my idea hihi
Sent from my LT25i using Tapatalk 2
Old 02-05-2013, 04:08 PM   #103
Extreme Dimensions
Extreme Dimensions's Avatar
Extreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to behold
wow this thing looks amazing!! Keep up the progress.
- Chris Gary
p: 714-278-8000 x 19
E: [email protected]
Extreme Dimensions is offline   Reply With Quote
Old 02-06-2013, 07:17 AM   #104
Chad Dugan
Chad Dugan's Avatar
Still need to remove the ignition and clean the inside out before I paint all the white parts again.
I also finally got around to patching my passenger side rocker which needed a little TLC. Cut the rust off and bent these patches out of 16g, but after a few quick tacks we just decided to replace the entire section on both sides.
My neighbor helped make some tabs for my license plate
The fuel cell is not sitting level in the picture because there was a box underneath from earlier, but the straps were done and I just needed to get some threaded rod to tie them down and add a new jack point.
Old 02-06-2013, 07:32 AM   #105
collegekid
collegekid's Avatar
collegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to all
Hey, I just wanted to ask what you do for a living?
I just switched my major in college from Biology to Mechanical engineering and I was wondering how you were designing everything. Are you using Autocad or solidworks? Are you just doing it the old fashioned way and just taking measurements and doing math? Are you just welding shit together? I'm curious on how you learned to do everything you are doing.
The fabrication work in here is top notch dude.
collegekid is offline   Reply With Quote
Old 02-06-2013, 08:29 AM   #106
Chad Dugan
Chad Dugan's Avatar
Thanks man I really appreciate it!
To answer your question, I would say I have used all the tools you mentioned, CAD and solidworks have helped me design and cut various pieces for this car from my Racepak bracket, and block off plates to heat shields and mounting brackets. I am familiar with these programs from school but they are also very easy to learn for first timers.
Definitely not just welding shit together, math is very important. Measure twice cut once everyone knows, I have re done most of the car since first starting this build, the first time is always the guinea pig, the second time around you learn tricks, what works better etc.
Learning to TIG and MIG weld over the last few years has really let me get creative with this car, if you can visualize what you are trying to accomplish and take your time, you can get it right. My car is by far perfect and there will always be room for improvement, and things to learn.
Old 02-06-2013, 06:38 PM   #107
zenkiset
zenkiset is an unknown quantity at this point
wanna come do my passenger rocker panel? haha. it needs some extreme TLC :/
amazing build btw! just read through the whole thing.
A welded is like the car equivalent to a blowjob.
zenkiset is offline   Reply With Quote
Old 02-07-2013, 07:24 AM   #108
Chad Dugan
Chad Dugan's Avatar
Thanks man, get that car some love!
I think my car is pretty much rust free now. I am trying to paint the inside in the next 2 weeks and have everything back assembled really soon, but Canada is so damn cold!
Old 02-07-2013, 11:58 AM   #109
bc.
bc.'s Avatar
Honestly, for as many terrible terrible terrible 240's out there, there are quite allot of stellar projects going on as well. This is one of those projects.
Old 02-08-2013, 06:15 AM   #110
Chad Dugan
Chad Dugan's Avatar
Thank you very much BC!!
Old 02-08-2013, 09:01 AM   #111
treeafodo
treeafodo's Avatar
treeafodo is an unknown quantity at this point
Just read the whole thread today. This is my dream build. Nice work man, keep it up!
treeafodo is offline   Reply With Quote
Old 02-12-2013, 09:17 AM   #112
Nissansota240
Nissansota240's Avatar
Nissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really nice
Build looks pretty amazing dude. Very nice work. Subscribed for more updates.
Also would you be able to tell me what material this is that you are using to make the block of plates and switch panel? Thanks
Originally Posted by Chad Dugan View Post
DLG - DIRTYLOVE
Nissansota240 is offline   Reply With Quote
Old 02-12-2013, 09:42 AM   #113
Matt191
Matt191's Avatar
Matt191 is an unknown quantity at this point
Amazing build good luck up there in Canada!
Matt191 is offline   Reply With Quote
Old 02-13-2013, 08:37 AM   #114
Chad Dugan
Chad Dugan's Avatar
Thanks Guys!
Thanks man, the material is just a firm plastic sheet I had laying around in the garage, I think it was a shield for a belt on a compressor. It is about as thick as a recycling box and the textured look matched my dash perfectly.
Old 02-13-2013, 09:12 AM   #115
cchondro
cchondro is an unknown quantity at this point
It looks like abs plastic
I use it for all of my block of plates and little clusters
__________________________________
Btw your build is going along awesomely.
just took the time to read thru the whole thing, and its amazing.
it's everything I will be doing on my hatch when the time comes.
Keep it up man A++++ build
cchondro is offline   Reply With Quote
Old 02-13-2013, 09:21 AM   #116
Nissansota240
Thanks, yeah I basically couldn't for the life of me think of the name for the stuff so my google searching was coming up empty. Found some and made an order already. Thanks for the reply.
DLG - DIRTYLOVE
Old 02-15-2013, 12:10 AM   #117
Fatlace
Fatlace is making a name for him/her selfFatlace is making a name for him/her selfFatlace is making a name for him/her self
Awesome build.
Mark | Fatlace
Fatlace is offline   Reply With Quote
Old 02-21-2013, 02:25 PM   #118
Chad Dugan
Chad Dugan's Avatar
No problem!
Originally Posted by Fatlace View Post
Awesome build.
Thanks man, I appreciate it.
I will have more updates this weekend with the wiring progress and completed interior.
Old 03-11-2013, 10:07 AM   #119
JohanM
JohanM's Avatar
JohanM is an unknown quantity at this point
updates!!!
JohanM is offline   Reply With Quote
Old 03-11-2013, 01:02 PM   #120
Sleepy_Steve
Sleepy_Steve is an unknown quantity at this point
Love the switch panels, and the rear quarter windows.
I may have to copy those rear quarter windows. Any idea how much weight was saved with them? Are they water tight?
'95 240 | @SleepySteve72
Sleepy_Steve is offline   Reply With Quote
