Old 12-17-2014, 05:26 AM   #1
Slow96240sx
Slow96240sx is an unknown quantity at this point
Any body know where the other end of this turbo line goes it wraps behind the motor
I don't where it ends up after it wraps around the motor I just got steel braided line and want to swap the hard lines out ImageUploadedByTapatalk1418819159.172659.jpgImageUploadedByTapatalk1418819173.539082.jpg I wrap tape around it so you can see it any body have there motor out that can take a pic
Slow96240sx is offline   Reply With Quote
Old 12-17-2014, 11:23 AM   #2
Slow96240sx
Bump anybody
Old 12-17-2014, 11:29 AM   #3
No 240.. No id
No 240.. No id's Avatar
No 240.. No id is on a distinguished road
Thats a water line to cool the turbo? I had to change it months ago after it decide to break.. Very pqinful to replace. Connects to a hardline under the intake manifold.
You can sleep in your car, but you can't drive your house.
No 240.. No id is offline   Reply With Quote
Old 12-17-2014, 11:58 AM   #4
Slow96240sx
Would you have a pic of it it's a tight fit I still have my ac hook up too so it's really tight did you have ac lines in your way
Old 12-17-2014, 12:04 PM   #5
No 240.. No id
My car is rhd, so my ac lines wasn't a problem.. Disconnect the trans mount and jack the trans up to clear space between the head and firewall
Old 12-17-2014, 12:35 PM   #6
Dillinja666
Dillinja666 is an unknown quantity at this point
Yep I hate that line. To make life easier get the steel braided lines when you replace it.
http://www.frsport.com/DIF-10034-Bot...-_p_15427.html
Dillinja666 is offline   Reply With Quote
Old 12-17-2014, 12:58 PM   #7
Slow96240sx
That's all i am trying to do is swap the lines to those with a t28 s15 turbo thanks I'll check it out when I get home
Old 12-17-2014, 01:07 PM   #8
jedi03
I suggest cut it under the head an swap to s14 waterneck an lines...no issues anymore! I had the steel behind the head still leak on mine...
Old 12-17-2014, 01:07 PM   #9
blackmags91
blackmags91 is an unknown quantity at this point
I did the exact same thing about a year ago when swapping to s15 turbo. Its already been said, but yeah, there is a hard line that it meets halfway between the hot and cold sides behind the head. I ended up just plugging that hardline and ran a new line off the water neck for future ease. Good luck
blackmags91 is offline   Reply With Quote
Old 12-17-2014, 01:43 PM   #10
Dboyizmlg
Dboyizmlg's Avatar
Trader Rating: (18)
Dboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-known
Feedback Score: 18 reviews
Or... You could just snag up a S14 water neck and run a SS braided line to that!
Delete the line in the rear of head.
Pain free with no headaches!
Dboyizmlg is offline   Reply With Quote
Old 12-17-2014, 01:53 PM   #11
Slow96240sx
At the intake? Delete it or can I just block it at the line and leave it there cause it seems like it's a pain to get where it goes on the intake since I still have ac
Old 12-17-2014, 02:17 PM   #12
S14DB
AFC #1
S14DB's Avatar
Cap the line.
Old 12-17-2014, 02:27 PM   #13
Slow96240sx
Where it turns to the rubber line just cap the rubber line and then I'll be good?
Old 12-17-2014, 04:03 PM   #14
Def
Either way - just make sure it's a reliable connection. Don't use a vacuum cap, it won't last.
S13 Hatch - Goes around tracks quickly
DEFSPORT
Old 12-17-2014, 05:06 PM   #15
Dboyizmlg
Dboyizmlg's Avatar
Trader Rating: (18)
I caped it on intake side. But you can certainly cap it on the rubber line behind the head, I would say you can use a thick bolt and clamp and done.
Either way works fine.
Get your self the S14 coolant water neck! Your going to love it!
Old 12-18-2014, 10:14 AM   #16
Def
BTW - the cheaper way to go is to just drill and tap the S13 water neck and put a 1/8" NPT to whatever fitting you're using on the water lines (I've usually used -4, small and plenty of flow).
Takes a few minutes, and the fitting costs a few bucks. An S14 waterneck is kinda pricey.
DEFSPORT
Old 12-18-2014, 01:00 PM   #17
jedi03
I cut mine below the intake where it starts to turn toward the engine an used a different water hose...a google search should yield the part number for it
Old 12-18-2014, 02:58 PM   #18
Bleakley
Bleakley is an unknown quantity at this point
Might be pricey, but (for me) it was nice because it aloud me to put a water temp. sensor right there as well. *Hint hint..*
Pretty tits if you ask me.
Bleakley is offline   Reply With Quote
Old 12-18-2014, 03:01 PM   #19
Def
If you're using the existing M14x1.5 mm port for a temp sensor, then you need to do something to add the coolant return to it.
So why not just mod what you've got?
People on Zilvia are so afraid of doing some light fabrication it's ridiculous.
DEFSPORT
Old 12-19-2014, 05:53 AM   #20
Bleakley
I am in agreement with your last statement.
I utilized the existing port for my coolant return and then drilled and tapped the square pad on top for the sensor.
