Old 04-11-2015, 05:47 PM   #1
magicalhawk6
magicalhawk6 is an unknown quantity at this point
s13 Ka24de, Crank, No start.
My nissan 240sx s13 running a KA24DE has alot of trouble staying alive. in the last few months it has been running really rich and ecu flashed two codes; 12 and 33. (MAF sensor and O2 sensor). i have replaced both sensors but code is still flashing. Now my Ka24de won't start and if it does, it stalls after a few seconds of rough idle.
also, i know i have a spark on all 4 cylinders.
magicalhawk6 is offline   Reply With Quote
Old 04-12-2015, 06:31 PM   #2
that1guywithans13
that1guywithans13's Avatar
that1guywithans13 is an unknown quantity at this point
Try taking the fuel pump fuse out it's located in the engine bay area. With it off try starting your car while pumping the gas pedal. If it starts you have liquid (either oil, gas, or coolant) wetting 1 or more spark plugs. When they are wet, the fuel being injected to that cylinder will not burn and it will have a "flood" condition.
try it see what happens.
ITS ALL FUN AND GAMES TILL THE FLYING MONKEYS ATTACK..
that1guywithans13 is offline   Reply With Quote
Old 04-12-2015, 10:12 PM   #3
Levhiathan
Levhiathan is an unknown quantity at this point
a faulty fpr does something similar, it will start, run for a few seconds and then cut off. have u tested ur fuel pressure yet?
Levhiathan is offline   Reply With Quote
ka24de, maf sensor, no start, o2 sensor, rich.
