03-26-2007, 04:29 PM | #1 |
RWD Super Celica 1985!!!
For Sale: 1985 Toyota Celica. AKA super celica, last year of the rwd monsters. This car is in immaculate condition.Motor is built as well.
Specs: Pro EFi 2.6 litre Crate Engine from LC Engineering in Phoenix Arizona Intake has been extrude honed (polished and bored out on the inside) Big Bore Throttle Body www.lcengineering.com http://www.toyotacatalog.net/M1WebGe...E-45AE05180400 22R (85-95) EFI Pro Long Block The LCE EFI Pro long block is a 2.5L high-performance engine designed for street applications. It includes the ported and polished EFI Pro Cylinder Head (new casting) with stainless steel valves, big bore forged pistons and ARP head studs for more power and reliability. You can utilize the factory fuel injection system, radiator, A/C and power steering system. Like every LCE product, it's designed for performance and reliability. Features: * * 2.5L - 135 HP @ 4,900 rpm * Extremely strong, predictable, low rpm throttle response * Perfect for 4WD's & 4-Runners * Very smooth idle Here is a brief list of components in this engine. Top End: * * 1021024 Street Performer Cylinder Head (85-95) * 1022021 EFI Pro Camshaft * 1023042 45.5mm SS Intake Valves * 1023033 37.5mm SS Exhaust Valves * 1023201 Street Performer Valve Springs * 1023006 Street Performer Retainers * 1023090 Hardened Valve Keepers * 1023099 Toyota Valve Seals * 1045030 New Exhaust Studs * 1023018 Complete Rocker Arm Assembly * Custom Valve Cover (Red/Silver/Black) Bottom End: * * 1011003 Pro Cylinder Block * 1024069 Pro Head Stud Kit * 1014343 94mm Pro Forged Piston Set * 1013003 Street Performer Connecting Rods * 1013048 Street Performer Crankshaft * 1013072 Clevite 77 Main Bearings * 1013132 Clevite 77 Rod Bearings * 1013165 Clevite 77 Thrust Bearings * 1016019 Brass Freeze Plugs * 1015012 Dual Row Timing Chain Conversion Kit * 1016033 Complete Engine Gasket Set * Oil Pan (depends on year & make) Additional Parts & Accessories Shown: * * 1016123 Underdrive Pulley Kit * 1081045 LC Pro Distributor - Red * KN621370A K&N Front Breather w/Adapter * 1024078 LC Pro Polished Oil Cap * KNHP3001 K&N Heavy Duty Oil Filter * 1083009 LC Pro Plug Wire Set * 1085006 LC Billet Wire Loom * Big Bore Throttle Body (depends on year) * EFI Intake Runners (depends on year) * Equalized Fuel Injector Sets Mileage: 36,000 miles 5 speed transmission, 1200 lb clutch disc/9 lbs. flywheel Trd 411 Limited Slip, Independent rear end New Toyota calipers Brembo rotors new paint koni struts/eibach springs All new suspension includes: inner outer tie rods, ball joints, control arms Show quality, Car has been restored as if it were coming fresh out of the factory. Asking pirice $12,500. obo please email me at [email protected] or pm me! |
03-26-2007, 04:32 PM | #2 |
Damn, that's really nice. My friends mom has one in blue. It's not in tip top shape like your's but it's fun to mess around in. GL on your sale.
SHIFT_zilvia |
