Old 11-16-2008, 12:28 AM   #151
project-D180
project-D180's Avatar
project-D180 is an unknown quantity at this point
curious..wil bc 264s work fine with the 90 pistons??what kind of settings are you guys runnin with the afc's???
project-D180 is offline   Reply With Quote
Old 12-28-2008, 06:54 PM   #152
BlackRedX
BlackRedX is on the path to ruinBlackRedX is on the path to ruin
Originally Posted by 240KAT View Post
theres a couple ka stroker kits out there now a days for those who want it..crower makes a 2.6L kit for a little less than 3k
I thought boring out the KA to 2.6 would drop the RPM revs to like 5500 instead of its 8000. You would get some nice torque but wouldn't this be useless for drift/track/ I only see this being used for 1/4 times and thats it. In which case I wouldn't bother.
BlackRedX is offline   Reply With Quote
Old 12-30-2008, 12:50 AM   #153
ninja_star
ninja_star is an unknown quantity at this point
i got a twim cam harness 240sx and my car is a single cam does anybody know why it doesnt plug into the dashborad consle
its 93 harness gold top s13 motor and my car use to be single cam doing a motor swap and dashborad consle doesnt plug in help
ninja_star is offline   Reply With Quote
Old 01-13-2009, 12:36 PM   #154
Iceman00
Iceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymore
not true. The crank is FCW, and allows RPM's over 8000.
* > Drifting
JWT powered Altima
Iceman00 is offline   Reply With Quote
Old 01-14-2009, 11:03 AM   #155
ZenkiKid
ZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud of
youre supposed to cut the sohc connector for the console and match the wires with the dohc connector.
ZenkiKid is offline   Reply With Quote
Old 01-18-2009, 01:16 AM   #156
fuk240sx
fuk240sx is an unknown quantity at this point
not sure
I'm not 100% sure but I dont think the 264's will work with the sohc cam pistons, something about valve clearances, you have to get your pistons milled.......look it up its on zilvia......
fuk240sx is offline   Reply With Quote
Old 02-15-2009, 09:04 AM   #157
Phill
Phill is an unknown quantity at this point
Yeah, You have to get your Pistons milled for the valve clearances, Or you'll bend valves when you attempt to start up.
Here's my ka build info
95 Ka24DE:
BC 264 cams
BC Stage 2 Dual valve springs
Clevite Crank bearings
Clevite Rod Bearings
Micro Polished crankshaft
Arp head studs
Stock HG (new)
Stock Rods
Stock Pistons(Cleaned up of all carbon)
Gasket matched intake and exhaust ports
Freshly cut Valve Seats
New Valve guides
Freshly cut valves(Also sand blasted of all carbon deposts on valve heads)
I'm curious as to what WHP numbers I'll be seeing.
Phill is offline   Reply With Quote
Old 03-16-2009, 06:21 PM   #158
project-D180
hmm anything new in the n/a world??
Old 03-20-2009, 12:36 PM   #159
fuk240sx
Did you ever actually do this and if so what were the results?
Originally Posted by project-D180 View Post
90 pistons,eagle rods,xcessive intake mani,n60 maf,light flywheel,stge2 clutch,shaft masters aluminum drive shaft(free shippin i might add so check'em out),ported exhaust side of head,obx headers and pulley kit(crank pulley,power steerin,water pump,and alt),248x2 cams,and knifed crank..and maybe a retuned stock ecu from EFI Specialist (Powered by CubeCart)..lookin 2 put out atleast 200 to the wheels..if not i have a project 2 that will consist on 11:0:1 je pistons n head work and bigger cams..so come on people stop half a**in and let get this N/A thing goin
Old 03-20-2009, 06:16 PM   #160
project-D180
*******yea stil workin on it ..its up and runnin but it needs tunin..i dont recommend 248x2 withh the 4 teeth method
Old 03-20-2009, 06:18 PM   #161
project-D180
dont really care for the idle plannin on gettin bc spring kit n runnin stock 240 248 cams for now and see what i get ...if not im runnin the 11.0.1 with 264 cams
Old 03-20-2009, 06:19 PM   #162
project-D180
it sounds nasty... let me tell u..but when i get it tuned i will let u kno whats good
Old 03-22-2009, 10:10 PM   #163
fuk240sx
Get it tuned and we want dyno sheets!!!
Old 03-24-2009, 07:22 AM   #164
project-D180
lol...ight..
Old 03-28-2009, 11:10 PM   #165
ZilviaKid
ZilviaKid's Avatar
ZilviaKid is a jewel in the roughZilviaKid is a jewel in the roughZilviaKid is a jewel in the roughZilviaKid is a jewel in the roughZilviaKid is a jewel in the roughZilviaKid is a jewel in the roughZilviaKid is a jewel in the rough
est time of having it tuned?
and why only 248 cams? seems kinda pussy lol. why not go for the 264's?
2004 Nissan 350z
2002 Nissan Silvia
ZilviaKid is offline   Reply With Quote
Old 03-29-2009, 01:36 PM   #166
project-D180
dont believe the vavles will clear with 90 pistons
Old 04-01-2009, 10:24 PM   #167
ZilviaKid
ZilviaKid's Avatar
oh good call, i do believe you are correct.
what was the shipping time like on the xsessive manifold btw?
2004 Nissan 350z
2002 Nissan Silvia
Old 04-03-2009, 08:31 PM   #168
kidexpo
kidexpo is an unknown quantity at this point
How much whp will a healthy KA24DE achieve with I/H/E and an Dyno'd ECU tune?
kidexpo is offline   Reply With Quote
Old 04-03-2009, 08:57 PM   #169
Howlermonkey
Howlermonkey is an unknown quantity at this point
Some rebello built engine owners claim 190hp at the crank and a recent rebello GT3 normally aspirated engine made 266hp at the crank.
Howlermonkey is offline   Reply With Quote
Old 04-03-2009, 09:53 PM   #170
TravisSW
TravisSW is close to perfectionTravisSW is close to perfectionTravisSW is close to perfectionTravisSW is close to perfectionTravisSW is close to perfectionTravisSW is close to perfectionTravisSW is close to perfectionTravisSW is close to perfectionTravisSW is close to perfectionTravisSW is close to perfectionTravisSW is close to perfection
Send a message via AIM to TravisSW
Probably just a 10HP increase if anything.
Just a 4 banger. Want numbers, drop a lot of cash or forced induction in there lol.
1986 Porsche 944 Turbo (951)
1995 Nissan 240sx (S14) Miss ya.
TravisSW is offline   Reply With Quote
Old 04-04-2009, 04:46 PM   #171
kidexpo
10whp???
i remember a while back before i owned a 40... i was reading up some old guy's build and he made 160whp on a N/A KA24DE with just I/H/E then 185whp on a tuned ECU.
Old 04-04-2009, 07:31 PM   #172
soreballz
soreballz's Avatar
Trader Rating: (22)
Feedback Score: 22 reviews
Just a 4 banger.
Everybody, please disregard Travis's comment. It is incorrect.
n00b.
-Kyle
Old 04-04-2009, 09:00 PM   #173
project-D180
it didnt even take a week to get the mani and i live in jersey
Old 04-20-2009, 08:39 PM   #174
fuk240sx
you know you can take ka24e pistons to a machine shop and have valve reliefs milled in them for about $25 a piece and you can run beefier cams, If your going for a NA KA setup I highly recommend using more aggressive cams and porting polishing the head.....
Old 04-21-2009, 10:55 PM   #175
project-D180
hmmm wish i knew it was so cheap before i even put the motor back together..hopefully my ecu should be back by the end of the week no later than begining of next week
Old 05-09-2009, 06:56 AM   #176
gsxr141
gsxr141 is not welcome here anymoregsxr141 is not welcome here anymoregsxr141 is not welcome here anymoregsxr141 is not welcome here anymoregsxr141 is not welcome here anymoregsxr141 is not welcome here anymoregsxr141 is not welcome here anymoregsxr141 is not welcome here anymoregsxr141 is not welcome here anymoregsxr141 is not welcome here anymoregsxr141 is not welcome here anymore
dumb question.
are there any na headers available other than obx or pacesetter?
gsxr141 is offline   Reply With Quote
Old 05-09-2009, 12:32 PM   #177
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
DC sports, Greddy made one for the s14, which bolts to a s13 and allows you to run a sr20 downpipe. Its kinda hard to find though.
Slip Gypsies Blog
not sure if you realize this
Old 05-09-2009, 05:53 PM   #178
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
Xtune, I have it and its good. 110 shipped I believe. Survived winter and a shitload of exhaust abuse such as jacking the motor up, tranny swap etc all without unbolting the header from the exhaust.
Bigsyke is offline   Reply With Quote
Old 05-09-2009, 11:22 PM   #179
gsxr141
good stuff, thanks.
Old 05-11-2009, 02:41 PM   #180
gsxr141
after looking around for hours and hours, i figured i would ask here.
does anyone know where to get the xtune header for a sohc . i pmed one person, but didn't get a reply yet.
thanks in advance........
