10-27-2013, 12:10 PM | #1 |
400hp sr20 swap $2800 OBO
located in georgia
400 hp sr20det turn key swap 2800 OBO with options 500 miles on the motor 1500 miles on the accessories everything was purchased brand new all machine work done by twister engines/ GRIMES machine shop the gt35 setup was installed needs to be tuned. The motor had a gt2871r on it before bottom end: hot tanked decked honed brand new oem pistons brand new piston rings. eagle rods acl race bearings. brand new nissan oem oil pump s15 oil pick up arp mains. apexi head gasket 1.8 mm new timing chain new timing chain guide and tensioner. new nissan oem watter pump. head: ported head. new tomei rocker arm stoppers. new oem valver cover gasket. new circuit sports thermal intake manifold gasket. new s15 7 layer exhaust gasket. new isis intake manifold. 550cc injectors real turbo xs RFL blow off valve. emusa top mount turbo manifold. emusa 17 pound waste gate. cx racing GT35-2 dual ball bearing turbo stainless steel lines for turbo only oil cooled earl fittings s15 waterneck with looped coolant line to block accesories: chase bays power steering kit for s13 circuit sport oil filter relocation kit safc neo wired in already heat is deleted no ac new clutch fan new shroud z32 maf blow through emusa intercooler. cxracing radiator custom piping samco lime green hoses 1000 degree catch can lines cusco catch can general Bkr7e spark plugs 50/50 vp114 race gas and 93 octane mix always used stri oil pressure gauge and harness stri coolant temp gauge and harness hks intake 404-401-7854 |
Tags |
sr20 240 s13 sr20det |
