Old 05-23-2011, 02:35 PM   #1
noynek
noynek is an unknown quantity at this point
Boost Limit for the Stock OEM SR20DET Recir Valve
Hi there
I know that many have talked about the OEM SMIC and Heat Soak associated with high boost. My Searches have yielded many answers in that dept.
I'm interested, however in the physical OEM Recirculating Valve and its boost limits as it relates to diaphragm strength.
Thanks much
noynek is offline   Reply With Quote
Old 05-23-2011, 02:45 PM   #2
KaminaSan
KaminaSan's Avatar
KaminaSan is an unknown quantity at this point
You can expect it to start leaking boost/opening prematurely at around 11 psi.
someone in the car is screaming when that deadly t25 spools up!
KaminaSan is offline   Reply With Quote
Old 05-23-2011, 03:01 PM   #3
noynek
Thanks much. If anyone else would like to concur or add their two cents it would be appreciated. Ive read of the diaphragm of OEM type Recirculating Valves rupturing under "high" boost. This is the reason for my question
Old 05-23-2011, 03:12 PM   #4
camaro379ss
camaro379ss's Avatar
camaro379ss is an unknown quantity at this point
I too have heard around the 10-11psi range.
1991 Nissan B13 Sentra sr20det 300whp/1991 Nissan S13 240sx sr20det ~260whp
camaro379ss is offline   Reply With Quote
Old 05-23-2011, 03:46 PM   #5
herbieS13
herbieS13's Avatar
herbieS13 is an unknown quantity at this point
Send a message via AIM to herbieS13
+1 for 11psi
herbieS13 is offline   Reply With Quote
Old 06-05-2011, 07:31 AM   #6
noynek
Thanks Guys for all your input. I'll work with 11psi
