Old 08-19-2011, 01:36 AM   #3031
swiftmini
swiftmini is an unknown quantity at this point
Heres a few pics of my Geomasters fitted. I have more lock than the pics show.
In the pics you can see that the outer rose joint is at its limit. need to bend the lca with heat
[SIGPIC][/SIGPIC]
swiftmini is offline   Reply With Quote
Old 08-19-2011, 11:15 PM   #3032
Jonnie Fraz
Jonnie Fraz's Avatar
Trader Rating: (29)
Jonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfection
Feedback Score: 29 reviews
Send a message via AIM to Jonnie Fraz
Gotta say I saw something funny the other day while Ryan Kado was out at the track testing. He was doing some slow turns in the pits, and he has so much angle that the car will pivot on the inside rear tire. It is pretty amazing.
Stealth-Custom-Fab.com
Jonnie Fraz is offline   Reply With Quote
Old 08-20-2011, 12:13 AM   #3033
SicBastard
SicBastard's Avatar
SicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the rough
So the turning radius is basically the wheel base?! Do the knuckles make the car a little twitchy on the freeway?
BURN OUT IN YOUR FACE!
1998 S14 LS7/T56 swap in progress, build thread:
http://zilvia.net/f/tech-talk/147301...d-gto-pan.html
SicBastard is offline   Reply With Quote
Old 08-20-2011, 01:45 AM   #3034
nieko
nieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfection
Kado's car doesn't go on the freeway brooo. haha
nieko is offline   Reply With Quote
Old 08-20-2011, 04:04 AM   #3035
GSXRJJordan
GSXRJJordan's Avatar
Yeah Kado's car was just at my shop, we looked over everything while I fixed a few things, and he did the alignment/suspension settings again. The front geometry is nuts. Still trying to figure out the best coordination of angle and grip, but the turning radius is VERY close to the wheelbase.
Old 08-20-2011, 11:55 AM   #3036
lflkajfj12123
You will gain more from lightening unsprung weight on your car.
What wheels are you running? Light wheels along with aluminum bodied coilovers would help quite a bit.
sway bars are not a part of unsprung weight
Old 08-20-2011, 01:22 PM   #3037
!Zar!
!Zar!'s Avatar
I never said they were?
Old 08-20-2011, 04:39 PM   #3038
lflkajfj12123
lol what
the posts above you were all talking about lighter sway bars and that was your response
Old 08-20-2011, 06:20 PM   #3039
SicBastard
SicBastard's Avatar
Technically half of the sway bars arms, and all of the sway bar end link weight ARE unsprung weight.
Old 08-20-2011, 07:32 PM   #3040
!Zar!
!Zar!'s Avatar
lol what
I was simply talking about how one should focus on more important things than swaybar weight.
Old 08-22-2011, 12:04 AM   #3041
nieko
Sorry if this is a dumb question...
Are there any negatives to making your front LCA's long as hell?
I'm trying to push my wheel the fuck out so I can use all my angle and stop hitting the sway bar and what not.
I know it will give me a bunch of camber, but I can always Dial it out with the upper mount.
Sorry if this was a completely retarded post. -_____-
Old 08-22-2011, 07:06 AM   #3042
PoorMans180SX
PoorMans180SX's Avatar
Having an increased front track will also change the handling dynamic (understeer/oversteer) a little as well, but that goes more in depth than I have knowledge of, especially with the specifics of the s-chassis.
Other than having to redo your alignment, I can't think of any big disadvantages. The C's garage guys have their LCA's extended 25mm, and seem to like it.
Old 08-22-2011, 09:06 AM   #3043
swiftmini
Originally Posted by PoorMans180SX View Post
It will increase your scrub radius a bit if you don't dial out the additional camber with the camber plate.
I personally don't think scrub radius will change much, if at all. scrub rad is distance from. centre of contact patch to the point where kpi hits the floor
roll centre will change as well as swing axle length (instantaneous centre).
I wouldn't worry though. my lower arms are 35mm longer than stock s13
[SIGPIC][/SIGPIC]
Old 08-22-2011, 09:29 AM   #3044
nieko
That's what I wanted to hear gentlemen....
I'm pretty sure I will now be able to get retarded amounts of angle now.
I'm excited.
Check out this video, there are a few clips of some of the angle I was already getting
ASBXI Part 3 of 3 on Vimeo
1:58 5:30 8:52
Old 08-22-2011, 09:31 AM   #3045
SicBastard
SicBastard's Avatar
It's almost all good. Increased track width WITHOUT increasing the scrub radius. Increased track width means you will gain traction on that end of the car (this is not chassis specific). That's a particularly good thing on the front of an s-chassis though because it will allow you to increase the wheel rate, which will allow you to keep the camber where you want it (something our front strut design naturally fights). Because the struts have almost no camber gain these cars need a ton of static negative camber in front (~3 degrees). So even that shouldn't be a problem with adjustable camber plates.
Really the only negatives I can see is a possible loss of caster if you don't have enough adjustment in your tension rods, and hitting the fender if you are running some real meat on stock fenders.
Old 08-22-2011, 09:53 AM   #3046
PoorMans180SX
You are correct sir, I was thinking about it the wrong way and it doesn't change scrub radius. I've edited my post to say such.
The good thing is that the tension rods can stay in the same position if you extend the lower arm by cutting outside the mounting points and adding more LCA in there.
Thank you for the track width information. I was reading a forum with a bunch of engineers arguing about what it did and it was very general, so I didn't want to spout off information when I didn't know how it related to the s-chassis. It makes sense though considering the track width is basically equal front and rear on an S13.
Old 08-22-2011, 05:26 PM   #3047
nieko
Coool. Now I just hope my tie rod setup reaches -_______-
We will find out tonight. Maybe I'll even take pictures
Old 08-22-2011, 05:46 PM   #3048
Patrick Bowering
Patrick Bowering's Avatar
Patrick Bowering is an unknown quantity at this point
probably wont my s13 with s14 arms and pbm knuckles wouldnt reach with s14 tierods i have georges spacers on both sides.
Patrick Bowering is offline   Reply With Quote
Old 08-22-2011, 05:55 PM   #3049
PoorMans180SX
BTW, this doesn't make sense. Sure your tie rods aren't Z33? What tie rod ends are you running?
Old 08-22-2011, 08:48 PM   #3050
nieko
I have these gigantic driftworks offset spacers that push the tie rod out quiiiiiiite a bit.
and SPL outters and that adds quite a bit of length too.
Stuff didn't come in today, so we'll seeeeeeeeeeee.
Old 08-23-2011, 08:26 PM   #3051
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
Hello gentlemen, a few questions if I may.
My plan was to upgrade to S14 rod ends and buy some nifty angle-increasing inner tie rods. I wanted the Max ones, but they are out of stock and they do not know when they will have new ones, so I researched more, and started looking into these offset spacers:
My main question is, which would be more beneficial; the offset & angle spacers with new OEM S14 inners and outers, or angle-increasing inner tie rods with new S14 outers?
What companies sell the offset spacers? So far I know of Driftworks and Era1. I would like to compare and find ones with the largest spacer for über angle.
One final thing, do the steering rack boots fit over the spacers? I would hope so.
Thank you for any input.
Old 08-23-2011, 11:56 PM   #3052
Patrick Bowering
mine are s14 inner and outer and with driftworks spacers you should be fine.
Old 08-24-2011, 12:38 AM   #3053
nieko
You need to read through this thread more Matej.
"My main question is, which would be more beneficial; the offset & angle spacers with new OEM S14 inners and outers, or angle-increasing inner tie rods with new S14 outers?
If you get the offset spacers, they have the little inner spacer built in. You do not need the offset spacers unless you get a buttload of angle and your steering is going over center.
Inner tie rods don't increase angle unless they have a built-in spacer on the rack side. But you can just get that spacer from PSM or whatever for dirt cheap and throw it on your tie rods.
And yes... if you do end up getting the offset spacers, the boots fit over.
Old 08-24-2011, 01:27 PM   #3054
Matej
Trader Rating: (39)
Sorry, searched around after posting that only to end up back in this thread and be embarrassed to see you were discussing them just a few pages back.
One last thing; how come the offset spacers are not symmetrical, while tie rods and all the other non-offset spacers are? Or will it be self-explanatory once I look at the rack?
Old 08-24-2011, 03:10 PM   #3055
PoorMans180SX
Once you look at the rack, you'll get it.
BTW, PSM is going to come out with an offset spacer soon. If I were you, I would wait for them, but that is just my opinion.
Also, you only need S14 outers if you are using S14/PSM/Z32/Z33 inners, as stock S13 inners are smaller and can only use S13 outers.
Old 08-24-2011, 08:36 PM   #3056
DC Dan MAX USA
DC Dan MAX USA's Avatar
Trader Rating: (79)
DC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond repute
Feedback Score: 79 reviews
Ryans car is truely amazing, did you all see this???
http://www.youtube.com/watch?v=fJhNPyY2Vqc&
Its all good
The FLCAs you ordered can widen the track 5 inches, its THAT gangster.
Sorry we sold out before you got your FLCA/TENROD combo, one more week for fresh stock.
thats true.
Developed for the 350Z angle kit ... but can be used on s-chassis too.
I want to let you guys know about whats new...
Parts Shop MAX PRO steering knuckle modification:
$400 plus return shipping
Availability - NOW
This is the most aggressive knuckle available today with up to 62 degrees of angle, 45mm roll center correction and the lowest possible ackerman.
caution! - this is only for real men who relentlessly pursue the art of throwing cars at 90+ degrees of drift angle
wussies need not apply.
http://www.youtube.com/watch?v=cQsRiqNRRJ0
http://www.youtube.com/watch?v=ExsO6QJHOps
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate.
Order Inquiry: IM me your real name and paypal address.
Thanks for your business!
DC Dan MAX USA is offline   Reply With Quote
Old 08-24-2011, 08:54 PM   #3057
Def
Why would you use a Class 8.8 bolt in that location? That thing holds your steering together with a huge bending load on it.
Since 99.99999% of the people in the world don't understand the distinction, a Class 8.8 bolt is equal to an SAE Grade 5 bolt.
S13 Hatch - Goes around tracks quickly
DEFSPORT
Old 08-24-2011, 09:25 PM   #3058
Matej
Trader Rating: (39)
The size of the spacer on those is cool, but the hardware store bolt looks off, unless the final product will feature a different one. Is there enough room to freely remove/install the tie rod and rack bolt? It seems that they may be cramped a bit close together.
Old 08-24-2011, 09:30 PM   #3059
DC Dan MAX USA
Trader Rating: (79)
Def, for the prototype parts mock up (pictured), we just took an off the shelf bolt and re-threaded it as a matter of convenience in our test fitting session for the Z parts. Thanks for paying attention to detail.
We will use grade 10.9 in production just like we have been using in Ryan Kado's formula D car.
The production bolt will also have plating - prototype photo bolt does not.
Please also notice the details that make this latest prototype rack spacer a really nice piece, like the radius that distributes the load from the sleeve to the main body, and the lip on the perimeter for retaining a dust boot.
Matej, of course the tie rod fits next to the bolt!
Old 08-24-2011, 09:51 PM   #3060
Matej
Trader Rating: (39)
Originally Posted by DC Dan MAX USA View Post
Matej, of course the tie rod fits next to the bolt! wow
Ouch, haha. Just noticed that yours is offset more than the Driftworks one, thus not requiring a recessed bolt. What is the projected price estimate?
anti-squat, best thread ever, kpi, roll center, steering angle, suspension
