09-01-2016, 07:24 PM | #1 |
1989 240sx Sil-Coupe SR20DET
$10,000 O.B.O.
Suspension/drive/wheels: Older dmax adjustable arms. Tension in the front, camber, toe, and caster in the rear. fortune auto 500 coil overs s14 vlsd 5 lug conversion extended lugs up front lower subframe brace front and rear strut tower bars hubcentric rings project mu 7 sided lugnuts Klutch republic sl1 16x9 +12 225/50 kuhmo up front 245/50 falken in the rear engine/transmission: shaved engine bay tubs recently re-sealed s13 blacktop megan motor mounts tomei poncams tomei rocker arm stoppers 550cc Injectors Enthalpy ECU rebuilt t25 new style megan elbow don't remember the down pipe or test pipe blitz nur-spec cat back 2-piece tucked engine harness with barrel plug in the fire wall brand new p2m 95 amp alternator blitz BOV mkiii supra drift motion intercooler maradyne jetstream 2600 fans larger radiator nismo thermostat silicone hoses isr s14 water outlet j-star intake manifold j-star exhaust manifold wrapped and sealed nismo FPR tucked brake lines tucked clutch line with new master and slave freshly rebuilt transmission excedy hyper single gauges for voltage, fuel pressure, wideband, water temp, oil temp, oil pressure, boost, and vacuum greddy turbo timer oil cooler power steering cooler Interior: sparco evo I drivers seat tomei shift knob works bell hub NRG 2.3 QR grip royal wood grain wheel NRG harness on drivers side omp harness on passenger side Exterior: OEM metal fenders OEM metal hood Silvia aero bumper dorkidori lower grills ITR lip Dorkidori v1 skirts magic aero valences MoreCollage grill 50/50 turn signals Brick headlights with r32 reflectors, touge factory lenses LED bulbs. clear corners carbon roof wing 50/50 tails square silvia trunk lock 20161121-_JDM1175 by Justin S. (Underworld Media ), on Flickr 20161121-_JDM1175 by Justin S. (Underworld Media ), on Flickr 20161123-_JDM1268 by Justin S. (Underworld Media ), on Flickr 20161123-_JDM1285 by Justin S. (Underworld Media ), on Flickr 20161123-_JDM1289 by Justin S. (Underworld Media ), on Flickr 20161123-_JDM1312 by Justin S. (Underworld Media ), on Flickr Yes, I purchased this car from a member here, and I am not in a rush to part with it, but I wouldn't mind getting into something different as well. Thank you for your interest. Last edited by Splintercellsz; 03-09-2017 at 10:32 AM.. Reason: Moved to NEVADA, no longer in Tennessee |
09-18-2016, 06:10 PM | #8 |
12-17-2016, 06:10 PM | #13 |
Bump, Car now has a T28, and new alternator.
20161123-_JDM1333 by Justin S. (Underworld Media ), on Flickr |
12-17-2016, 09:38 PM | #15 |
Mileage is unknown, sold to me with cluster swap, and things of that nature. Was told it was a recent engine rebuild. Interior has cracked dash (under cover, no back seats, has carpet. Stock front seats. Only photo I have at the moment
13912501_599744843547158_1958408168334523372_n by Justin S. (Underworld Media ), on Flickr |
12-19-2016, 09:59 AM | #16 |
Super Moderator
Trader Rating: (73)
Feedback Score: 73 reviews
Cleaned up the thread. Next person that tries to start a fight or continue one is pinked for 3 months.
12-19-2016, 01:34 PM | #19 |
12-27-2016, 04:52 PM | #26 |
