Old 09-25-2013, 09:04 PM   #1
Darrenb
Darrenb is an unknown quantity at this point
DarrenB’s 1uz Itasha zenki s14 build
Hey everyone, decided to do an s14 build. A little background information about myself, I have no formal education on working on cars but since the beginning of high school have always been working on building cars. I have learned a lot through experience and reading up . I have dabbled in drifting in the past but never had the funds to forgo it. I’m now 26 years old and have decided to finally build my dream zenki s14 in my house garage to test my knowledge and passion for building cars.
I would like to also give a big thanks to Touge Factory, powered by max, Brett Collins, SNTRL, Diamond Vinyl, Broken motorsports, and my friends for being a big support in my build.
When I first got her, just a shell and a hideous lime green engine bay.
The full interior
Started stripping the interior and the chassis harness since I’m doing a switch panel
Took out the rear and gas tank and started rust proofing/removing rust on the undercarriage.
Undercarriage wasn’t bad at all
Blasted and metal washed.
Por15’d
Did a restoration job on the gas tank
Before:
After:
Did the same to the heat shield as well
Before:
in process:
After:
Next it was roll cage time, I’ve welded a few times but don’t have easy access to bending tools and metal. So I decided it was more cost effective and easier to have a place that specializes in building cages do the Job. I trailed the shell to my friend Bill over at Broken motorsports and had the cage with NASA rules, FD reg and my specs built.
While the car was at the shop I decided to work on the 5 lug hubs I purchased, the rear were used and the fronts were new. New bearings, and cleaned them up
Now parts started arriving. My whole suspension is all PBM with the exception of the RLCA, rear traction arm, and rear knuckles.
Some of the first parts that came in
@phoshizzl3
Darrenb is offline   Reply With Quote
Old 09-28-2013, 11:12 PM   #2
Darrenb
I originally decided to go with an rb25det and did research and found that the 1uz would fit my needs better, wasn’t looking for anything to crazy in hp. I wanted something with good torque, light, and budget friendly.
Picked up the motor and the transmission
I finally got the car back and decided to start painting the interior. I went with the Toyota super white 2 paint.
por15’d the floor
floor painted
Did he dash support as well.
Also did the engine bay as well, cut out tubs and had broken motorsports put in brace bars. I media blasted that hideous green bay and welded most of the holes shut. Unfortunately don’t have any pictures of the bare bay.
Primered
Painted:
Worked on the subframe, had some rust. I removed all the rust, then coated it in gold
After with the PBM stuff on
@phoshizzl3
Old 09-28-2013, 11:19 PM   #3
Darrenb
After a couple of months of waiting, the kit has finally arrived. It was a mix of the rocket bunny and origin body panels
Yay, more goodies
Got bored waiting on more parts and did a small restoration job on the steering rack and crossmember.
cleaned up
I finally test fitted the panels, some required some work to get them to fit well.
I then did work on the rear knuckles
Before:
After:
The passenger door on the s14 was all banged up and it was too far gone to save, so I got a door from someone selling one in NYC. While I focused on installing everything on my car, my friend and owner of Diamond Vinyl started wrapping the car as well as the body panels
Swapping the parts to the new door
After much anticipated wait for PBM’s new forged knuckles, they have finally arrived.
Mocked up the chasebays brake booster eliminator kit with the z32 brakes.
Once that was all done finally went ahead and put in the brake booster eliminator kit, the front crossmember and the steering rack I cleaned up.
Rolled the chassis outside for some light.
My friend finally finished wrapping everything.
Mounted the tires to the wheels and my awesome Abercrombie motorsports outer tie rods came in.
@phoshizzl3
Old 09-28-2013, 11:30 PM   #4
Darrenb
Interior all finally went in (switch panel, seat, and etc).
Then installed the rear subframe and everything else under the car (r33 ebrake cables, rear nismo 2way diff, and etc)
Now that all of those things are done, time to work on the motor. Big thanks to Bret Collins for all the swap parts.
Cleaned up the motor and switched the sump from rear to front sump.
Putting on the final touch, the oil pan.
Now, working on the top end of the motor.
Motor going in.
Once the motor was put in, the itasha HOTD graphics finally arrived, around 1am which was laid on and done by 3am.
A few pics from Import Expo where I unveiled the car. Unfortunately some key parts needed for the motor to run didn’t arrive in time.
Still waiting on my chasebays radiator. A few of the key parts have finally come in. I should start putting the key parts in this week.
@phoshizzl3
Old 09-29-2013, 08:43 AM   #5
Gotenks64
Gotenks64's Avatar
Gotenks64 is an unknown quantity at this point
Nice build man, How long did it take you to get to that point?
Gotenks64 is offline   Reply With Quote
Old 09-29-2013, 01:33 PM   #6
Darrenb
Thanks man. It took me roughly a year to get it to it's current state.
@phoshizzl3
Old 09-29-2013, 02:12 PM   #7
Jifter
Jifter is an unknown quantity at this point
damn thats one dope s14. I just finished my 1uz swap into my s13 coupe. Its a torquey engine. u will love it. keep us updated!
Jifter is offline   Reply With Quote
Old 09-29-2013, 06:57 PM   #8
xoxide
xoxide's Avatar
xoxide is an unknown quantity at this point
Beautiful build. Stupid question, but what wheels are those? They dont look like real VS-XX's for some reason (looking at the lug nut area)?
xoxide is offline   Reply With Quote
Old 09-29-2013, 08:51 PM   #9
zooopreme
Trader Rating: (38)
Feedback Score: 38 reviews
Liking this car a lot, nice work!
For Sale #1 | For Sale #2
Old 09-30-2013, 12:03 AM   #10
s14zenki21
s14zenki21's Avatar
s14zenki21 is an unknown quantity at this point
Hey wicked build man! I'm too currently rebuilding my 95 s14. I was hit by a drunk driver on the front passenger core support and now tubing the front end. By any chance are you gonna give a list of what you put in for your build? Also for the 1uz which tranny did you use? Curious cause I just have the stock KA24DE and not sure which power plant I want to do.
s14zenki21 is offline   Reply With Quote
Old 09-30-2013, 01:15 AM   #11
killer240
killer240's Avatar
Trader Rating: (24)
killer240 is an unknown quantity at this point
Feedback Score: 24 reviews
sweet build
REVIEW
killer240 is offline   Reply With Quote
Old 09-30-2013, 09:48 PM   #12
s14zenki21
s14zenki21's Avatar
How come you didn't take out sound deadening? Just curious.
Old 10-01-2013, 03:08 PM   #13
Darrenb
Thanks man, exactly what I was going for, a torque'y budget motor!
Not a stupid question at all, the wheels that are currently on the car are xxr 521. I am using the xxrs as my drift spares. I'm having some 3-piece wheels being made for cruisers/show wheels.
Thanks zooopreme!
Thanks man! I have a very big list, if you really want I can pm you the list. I used the stock ka24de 5 speed tranny. It should hold up fine but if it does blow I'll be switching over to the z32 or 350z trans.
Originally Posted by killer240 View Post
sweet build
Thanks killer240!
I took out the floor sound deadener out but not the ones on the trans tunnel and the rear seats because I got lazy
@phoshizzl3
Old 10-02-2013, 05:55 AM   #14
ingmar F
ingmar F is a jewel in the roughingmar F is a jewel in the roughingmar F is a jewel in the roughingmar F is a jewel in the roughingmar F is a jewel in the roughingmar F is a jewel in the roughingmar F is a jewel in the rough
sweet car man! i saw your car on instagram an started following you. i am doing the same swap in my s13, but i was wondering, how are you going to do the wiring?
ingmar F is offline   Reply With Quote
Old 10-02-2013, 09:56 AM   #15
7x13
7x13's Avatar
7x13 is an unknown quantity at this point
Pimp a$$ Zenki man.
another one i see with a 1UZ
Try to get some action shots
7x13 is offline   Reply With Quote
Old 10-02-2013, 10:21 AM   #16
Trinidrift3
Trinidrift3's Avatar
Trinidrift3 is an unknown quantity at this point
SNTRL crew checking in! can't wait to see you out on the track with it bro
Trinidrift3 is offline   Reply With Quote
Old 10-04-2013, 09:16 AM   #17
Darrenb
Thanks man. As for wiring, I took out the whole chassis harness and fuse box. I am running a switch panel, which is pretty straight forward, power to ecu, starter, fuel pump, and radiator fans. I dont have AC, heat, or radio. Making a separate harness for headlights, taillights and windows.
Originally Posted by 7x13 View Post
Pimp a$$ Zenki man.
Thanks! I definitely will take some action shots!
Awesome!! Definitely appreciate it! See you at the track events!
@phoshizzl3
Old 10-04-2013, 09:34 AM   #18
collegekid
collegekid's Avatar
collegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to all
Holy fuck Darren, that was quick. Hopefully the trans holds up well.
I like how your car is essentially my car's end goal minus the welding and maybe the engine.
collegekid is offline   Reply With Quote
Old 10-07-2013, 05:35 PM   #19
Darrenb
Haha, thanks man! I hope the transmission holds up well as well! Hope your build is going great!
@phoshizzl3
Old 10-09-2013, 09:13 PM   #20
imoverherre
imoverherre's Avatar
imoverherre is an unknown quantity at this point
Pictures don't work ; (
imoverherre is offline   Reply With Quote
Old 11-02-2013, 11:11 PM   #21
Darrenb
Update: Finally a few key parts have arrived. Wiring the ECU and the switch panel right now, hopefully will test fire the motor this Wednesday.
In the mean time, I was hoping to buy a vented hood but needed to address some parts for the motor so instead I did some work on my original busted hood.
Sanded, cleaned and prepped for primer
filler primered
topcoated
All finished
How it looks on the car
@phoshizzl3
Old 11-03-2013, 01:18 AM   #22
Drifting Kalamari
Drifting Kalamari is an unknown quantity at this point
Hey,I love your build! I am doing the same engine build for my S13. Got most done, working on the wiring and such now. How much does a wrap like that cost? It's awesome!
Drifting Kalamari is offline   Reply With Quote
Old 11-03-2013, 08:58 AM   #23
poundit
poundit is an unknown quantity at this point
The car looks so sick. I dont really like the hood but the quality looks amazing.
What switch board are you going with? Painless or something different?
poundit is offline   Reply With Quote
Old 11-03-2013, 10:13 AM   #24
Royal_T
Royal_T's Avatar
Royal_T is an unknown quantity at this point
Looks good bro.. keep up the great work
http://zilvia.net/advertise.html
Royal_T is offline   Reply With Quote
Old 11-05-2013, 11:18 PM   #25
Darrenb
Thanks man! I'm sure you'll be happy as well with the motor. A wrap like this costs around $2,000-$3,000 by shops around me.
Thanks! I appreciate the honesty, with some of my friends the hood was either a hit or a miss but they all agree that it came out well. I didn't go with painless, I went with Digital Delay's Switch Panel. DIGITAL DELAY - Switch Panels - Mega Panel, Mega Dial Panel
Thanks Royal_T! Definitely appreciate it.
@phoshizzl3
Old 11-09-2013, 01:06 PM   #26
Darrenb
Well I had my good friend Matt Petrie come by to take some test shots for an overseas feature. Still need to clean up a few wires in the engine bay, and still need to go out and get some radiator hoses, and cut the driveshaft. On a better note, the igniter module for the motor came today, unfortunately I'm away this weekend. Also can't wait to finally get my 3 piece wheels soon. Going to test fire the motor this Monday and will keep you all posted.
Some teaser shots.
Don't worry, doing a projector retrofit soon on the headlights. Also motor is abit off centered because I didn't tighten the right mount yet.
@phoshizzl3
Old 11-17-2013, 04:58 PM   #27
Darrenb
Well finished wiring up the motor, ecu and switch panel. Motor finally runs. Still waiting on MAF, rad hoses. I am also building custom headers. Aside from those things, all that is left is shortening the driveshaft, making the harness for the exterior lights and hooking up the gauge cluster.
Start up video (Don't mind the wires, going to clean up the wiring in the engine bay)
https://www.youtube.com/watch?v=Z6gMLE81RlQ
@phoshizzl3
Old 11-17-2013, 05:54 PM   #28
Jifter
Congrads! Sounds amazing!
Old 01-17-2014, 03:30 PM   #29
Beas
Beas is making a name for him/her selfBeas is making a name for him/her self
whats your header setup like?
Beas is offline   Reply With Quote
Old 12-24-2014, 02:29 AM   #30
DP-AE86
DP-AE86's Avatar
DP-AE86 is close to perfectionDP-AE86 is close to perfectionDP-AE86 is close to perfectionDP-AE86 is close to perfectionDP-AE86 is close to perfectionDP-AE86 is close to perfectionDP-AE86 is close to perfectionDP-AE86 is close to perfectionDP-AE86 is close to perfectionDP-AE86 is close to perfectionDP-AE86 is close to perfection
i honestly hadn't thought of looking you up on zilvia. lololol.
cool to see a build.
-ルカルカ☆-
DP-AE86 is offline   Reply With Quote
