Old 10-13-2014, 09:48 PM   #1
SidewaysJake
SidewaysJake is an unknown quantity at this point
Question Can I run t25 on s14 sr?(come t28 from factory)
Pros(if any) of running t25 on a s14 sr? They come stock t28. My turbo is gone, burns oil when I boost. A friend has a t25 and I was wondering what would happen if I ran it.
injectors aren't for t25. Run rich, wash cylinder walls out, blow up?
Let me know your opinion!
SidewaysJake is offline   Reply With Quote
Old 10-13-2014, 10:55 PM   #2
typhoonslippery
typhoonslippery's Avatar
typhoonslippery will become famous soon enoughtyphoonslippery will become famous soon enoughtyphoonslippery will become famous soon enoughtyphoonslippery will become famous soon enough
rebuild t28
CA18 is the only way to go!
typhoonslippery is offline   Reply With Quote
Old 10-13-2014, 11:37 PM   #3
SidewaysJake
Originally Posted by typhoonslippery View Post
rebuild t28
I plan on it, but there's an event I wanna make in 2 weeks and the rebuild wouldn't be done by then. Was wondering if running t25 would be possible. Just found out both s13 and s14 srs have the same injectors (370cc) so I wouldn't run rich. Do you know the flange size of t28?
Old 10-14-2014, 12:45 AM   #4
bmxer882x
bmxer882x is an unknown quantity at this point
in short, no u cant
The t25 bolts up differently which is why us guys with a s13 sr needed to get clocking adapters when we swapped turbos. In order to make it work you would need a new intake and hotpipe. But since your only wanting to run it short term it wouldnt be worth it. unless he has an intake and hotpipe you could borrow as well.
As far as running correctly I wouldnt worry to much. I ran a s15 t28 turbo on my stock s13 sr for 2-3 months and noticed no running lean or anything on my wideband.
bmxer882x is offline   Reply With Quote
Old 10-14-2014, 09:07 AM   #5
Prok0
Prok0 will become famous soon enoughProk0 will become famous soon enoughProk0 will become famous soon enough
Send a message via AIM to Prok0
Yea you can run it, you would just need to modify the intake setup, and the hotpipe.
Also the drain tube is a bit different between t25/28.
I wouldnt worry about the tune as if its pulling less air, the MAF is going to see that, not show as much voltage, and should in turn not dump as much fuel.
Sales @ Enjuku
email:[email protected] phone:352-241-8399
Prok0 is offline   Reply With Quote
Old 10-14-2014, 10:22 AM   #6
jr_ss
Your car is busted, fix it, miss the event. There will always be another event.
Old 10-14-2014, 01:17 PM   #7
SilviaSR20DET
SilviaSR20DET's Avatar
SilviaSR20DET is making a name for him/her selfSilviaSR20DET is making a name for him/her selfSilviaSR20DET is making a name for him/her self
Just a get used t28 there's plenty of them around for sale. I wouldnt want to downgrade to a t25 on a s14 sr, the powerband would react a bit different.
SilviaSR20DET is offline   Reply With Quote
Old 10-15-2014, 09:16 PM   #8
jscherf92
jscherf92 is an unknown quantity at this point
dunno if youre considering it but ive got a t25/28 rebuild kit from G-Pop Shop, im not gonna be using it. They're usually $80 plus another $14+ for shipping. Its yours for $75 shipped. Let me know.
jscherf92 is offline   Reply With Quote
Old 10-16-2014, 12:07 PM   #9
SidewaysJake
I have one also, Im pretty sure it's for journal bearing, I have ball bearing.
Old 10-16-2014, 01:57 PM   #10
jscherf92
Ah, yeah then youll need a new chra ~$600+. You might be better off finding a used T28 on here but there certainly wouldn't be anything wrong with the T25 for a short period of time but you will probably notice a difference in spool, response, and overall behavior of the engine and its output.
Old 10-16-2014, 03:04 PM   #11
SidewaysJake
Would I need s13 manifold and lines to run t25? Or will everything bolt right up?
Old 10-16-2014, 03:22 PM   #12
eek
Trader Rating: (29)
eek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud of
Feedback Score: 29 reviews
If you actually spent the time to search you would have figured out that the t25/t28 flange on the s13/s14/s15 are all the same. Even looking at after market bolt on manifolds would have netted you that.
Your answer to your latest question has been answered in post #4 and #5.
eek is offline   Reply With Quote
Old 10-16-2014, 07:26 PM   #13
jbt_92
jbt_92 is an unknown quantity at this point
[emoji106]
jbt_92 is offline   Reply With Quote
Old 10-16-2014, 03:38 PM   #14
Loomis112
Loomis112's Avatar
Loomis112 is an unknown quantity at this point
It would fit your manifold but it would take some work to get everything to line up right plus it would be a downgrade. Rebuild the t28.
Loomis112 is offline   Reply With Quote
Old 10-16-2014, 07:33 PM   #15
rotation3x
rotation3x's Avatar
rotation3x has made poor choicesrotation3x has made poor choicesrotation3x has made poor choicesrotation3x has made poor choicesrotation3x has made poor choicesrotation3x has made poor choices
Send a message via AIM to rotation3x
I have been running the isis t25/28 on my s14 sr @ 12 lbs no tune runs fine.
rotation3x is offline   Reply With Quote
sr20 240 s13 sr20det, sr20 240 s14 sr20det, t25, t28, turbo
