03-07-2005, 06:09 PM | #1 |
lug conversion question
my friend has a 5 lug s14 and I have a 4 lug s13 can we just swap our suspension so I can have his 5 lug and him with 4 lugs??? thanks
03-07-2005, 06:41 PM | #4 |
no. it will bolt up for you because your using more s14. knuckles spindles ball joints etc etc
whatever is listed above is not swappable to s14 i dont believe. search |
03-07-2005, 07:15 PM | #5 |
I've been doing a small amount of research, and I'd like to know myself.
Edit..after more reading/searching(key word) You can use the s14 knuckle with these http://www.5lugsleeves.com/. Thank you for a cheaper alternative. If you'd like to run more camber, or chaper/easier alternative than attain you can even use teh S14 LCA. Or you can use the S13 LCA with S14 balljoint with S14 knuckle. |
03-08-2005, 12:22 PM | #7 |
no
the other route is for the price of a drill bit you can take the 12 mm holes out to 14 and then you can use the larger bolts
I never knew you could do that with an eggplant |
03-08-2005, 07:20 PM | #8 |
If you swap your hub, spindle, LCA, and strut altogether it will bolt right u. but you'll have 10mm less length on the LCA. In the rear of course you just swap hubs.
03-09-2005, 01:24 PM | #10 | |
If its just a shock/spring than go for it.
92 FastBack - Project 98 SE - Daily Driver |
03-10-2005, 03:08 PM | #11 | |
