Old 06-24-2009, 03:19 PM   #1
David B S12
David B S12 is an unknown quantity at this point
drift car build
im david i work on this car, eh, kinda daily/weekly, im dedicated to drifting and thats all this car is ment to do, expect updates periodically
1984 datsun 200sx
1990 240sx ka24 swap
im 18 all my work $1000ish spent on car and swap combined
Drivetrain:
h190 solid rear axle bitches!
ka24 transmission
custom poly trans mount to use ka trans
welded differential
newish replacement clutch haha
frankinstein s13/s12 driveshaft combo
suspension:
rear billstein shocks, home made seperated coilover using random coil springs, and metal tubing
s13 coils
s13 knuckles
s13 balljoints
modded s13 tie rods
engine:
KA24E swap with 130 k miles previously auto now manual
random cold air intake with k n filter shoots through car under the battery tray
home made 2.5/3 inch exaust to HKS muffler
removal of lots of egr crap
replaced rear main seal and other small gaskets
e fan
jumper harness for ca20e to ka24e
interior:
wheel off a boat. but im going to be cool and say its some $$ brand
tach i got for cheap since my stock one doesnt function
unknown hub brand
momo seat
4 point sparco harness
fresh new automotive home-made carpet
rear is stripped, and lined,
battery relocated to rear
new oem headliner from california parts dealer
new oem door panels from dealer
home made rear strut tower bar out of gas piping
fully professionally dyed black interior, the dash, all the plastic
switch board for hard line pump/e fan
exterior:
200sx SE front lip
2 riken mesh wheels
4 jdm hoshino impul G5 wheels, super rare, over 30 years old, used in ae86 n2 compeitions in the late 70's
mk2 turbo hood
added a mk2 wing
heres my homemade suspension idea for the rear since i cant really find anything aftermarket for the car
heres the s13 suspension conversion going into the front, before next event on the 20th
megan s13 coils
q45 brakes
s13 tension rods
s13 lca
s13 tie rods
s13 spindle/hub
heres it when i got it non running with the stock engine
some progress pics
i moved
got a engine for 40 bux off a friend
home made trans mount for the new trans
cut shifter hole cause the trans is longer
finished the drive train
installed engine
moved, AGAIN!
my old s12
was clean
until i hit about 6 walls
sold it for 600 2 weeks ago
then, got some coilovers and started my s13 swap
i have q45 brakes but they dont clear my wheels i need a spacer, for now im using just s13 ones
s13 ball joints
got a disk brake setup from a nissan s110 (older 200sx)
started putting the suspension together
rethreaded and cut my tie rods to remove my toe in
David B S12 is offline   Reply With Quote
Old 06-24-2009, 09:02 PM   #2
s13 @ fullboost
s13 @ fullboost's Avatar
s13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfection
dude I am really diggin this haha +1
Old 06-24-2009, 09:10 PM   #3
adam s
adam s's Avatar
adam s is an unknown quantity at this point
Props for all the custom work.
adam s is offline   Reply With Quote
Old 06-24-2009, 10:52 PM   #4
dakota_lyons
dakota_lyons is an unknown quantity at this point
looks good. reminds me of an AE86, which is an up
i love those wheels.
nice job
dakota_lyons is offline   Reply With Quote
Old 06-24-2009, 11:08 PM   #5
vqdreaming
vqdreaming is an unknown quantity at this point
nice man, doing shit differently...way different but oh so sweet
vqdreaming is offline   Reply With Quote
Old 06-25-2009, 02:40 AM   #6
David B S12
thanks, it was all pretty clean till i started drifting, the ka is getting old and nasty, and shit breaks, i keep replacing it
its only been like 4 events but tis time for SR or CA18
heres the damages from last event (hyperfest)
more dirt, more grime, its funny how fast all this shit collects from drifting, but i like breaking shit it gives me something to do
pulled my driveshaft to find this out, THATS why my shit was clanking around halfway throught he day, some scrap metal got caught and messed it all
dyed my head, tapped valve cover nuts, i had stripped valve cover holes before, most reason to why i probally was leaking oil
u can see some of the leak onto the mani here
heres my crushed power steering line haha, i dunno how it broke loose and got under the member
check out my oil pan clearence! i love how it doesnt drop past the crossmember
more wires i gotta cut and remove lol.
started taking the h165 axle apart (disk brake conversion)
its not really common to find these disks so i dont have much info on the writeup
i could possibly swap those axles and bolt them into my other solid axle
but im not sure if
A my h190 diff has the same spleen gear as the h165 axles
and
B im not sure how much weaker the h165 axles are...
because the h190 differential on my car is rated at a silly 285 tq
possibly the h165 axles could be even more weak, and i dont want that shitt
if i had a god damn irs s12... aka any other year then 1984, id have disks, and a r180 good for liike 300+ tq
Old 06-25-2009, 04:12 AM   #7
Orly? Yarly.
Orly? Yarly. is an unknown quantity at this point
Send a message via AIM to Orly? Yarly.
david when will we sex??
you know how i think about this car
-Alex
Orly? Yarly. is offline   Reply With Quote
Old 06-25-2009, 09:51 AM   #8
ZilviaKid
ZilviaKid's Avatar
ZilviaKid is a jewel in the roughZilviaKid is a jewel in the roughZilviaKid is a jewel in the roughZilviaKid is a jewel in the roughZilviaKid is a jewel in the roughZilviaKid is a jewel in the roughZilviaKid is a jewel in the rough
nice corrado dude.
lol i kid, its looking good.
2004 Nissan 350z
2002 Nissan Silvia
ZilviaKid is offline   Reply With Quote
Old 06-25-2009, 10:01 AM   #9
MisS13
MisS13's Avatar
MisS13 is an unknown quantity at this point
Send a message via AIM to MisS13
impressive =) good job!
MisS13 is offline   Reply With Quote
Old 06-25-2009, 10:37 AM   #10
burnsauto
burnsauto's Avatar
Its getting there. I'm interested to see what the car can do once you get rid of all the body roll.
Old 06-25-2009, 02:31 PM   #11
David B S12
those are old pics i got most of the body roll gone
with the megans up front, but i need to redo my rear and get lower with more stiff springs, otherr then drifting drag style, ive gotten rid of most of the roll, it was very bad stock
from last weekend
Old 06-25-2009, 03:24 PM   #12
rage
rage is an unknown quantity at this point
Send a message via AIM to rage
shit needs to go lower, frame rail scraping on yr driveway, lower
rage is offline   Reply With Quote
Old 06-25-2009, 03:25 PM   #13
David B S12
dude my car beaches as i leave my driveway, once i drop the rear i have to tell myself to never go off track again haha
Old 06-30-2009, 09:28 PM   #14
David B S12
dropped the rear another inch, i might raise the front a tad and add a 8 mill spacer
im buying 2 rear 20 mill spacers so work with me
man im not sure aboutt hese hoshino wheels, there cool, rare, i love the look, but there 14's, and trying to lower a car on 14's then go out and drift on 15's like i do, is highly annoying, not to mention my tire choices, and my contact patch
im probally going to throw them up for sale, and get some 16x8 i want a good =10 offset or something
here are the pictures
Old 07-02-2009, 11:08 PM   #15
David B S12
Old 07-02-2009, 11:45 PM   #16
skate_osiris_4life
skate_osiris_4life's Avatar
skate_osiris_4life is an unknown quantity at this point
Send a message via Yahoo to skate_osiris_4life
damn man, props to all the customization on this beast, i gotta old 200sx myself and i lost the keys so i had to wire up a toggle switch for the ignition. hahaha
skate_osiris_4life is offline   Reply With Quote
Old 07-03-2009, 09:00 AM   #17
David48
David48's Avatar
David48 is an unknown quantity at this point
Send a message via AIM to David48
Damn, looks nice. And my name is David B too!!
David48 is offline   Reply With Quote
Old 07-03-2009, 09:26 AM   #18
XenoVibe
XenoVibe is an unknown quantity at this point
I love S12 so much, wish I had one! Good luck with project, shes coming along nice
XenoVibe is offline   Reply With Quote
Old 07-03-2009, 12:23 PM   #19
civilized_drifter
civilized_drifter's Avatar
civilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of light
Send a message via AIM to civilized_drifter
i love this car. keep up the good work
civilized_drifter is offline   Reply With Quote
Old 07-03-2009, 12:32 PM   #20
artdrifter
artdrifter is an unknown quantity at this point
This looks pretty sick
artdrifter is offline   Reply With Quote
Old 07-03-2009, 03:20 PM   #21
David B S12
spacers on, i might add another 5 mill i dunno
Old 07-03-2009, 03:57 PM   #22
David B S12
3 s chassis's
s12, s13, s14
Old 07-03-2009, 04:14 PM   #23
johngriff
johngriff's Avatar
Looks good.
if you are keeping the Sohc in there I would def find a ca20e 87 or 88 car and take the rear end out for a irs, drive shaft and trans. Swap the KA bellhousing onto the CA20e trans, fix your weird driveshaft and shifter placement.
plus that short ca20 trans has super tight gearing, which will help drifting with such little power.
[email protected]
Old 07-03-2009, 04:30 PM   #24
wannabdr1ftr
wannabdr1ftr's Avatar
wannabdr1ftr is an unknown quantity at this point
awesome
wannabdr1ftr is offline   Reply With Quote
Old 07-03-2009, 04:31 PM   #25
David B S12
Originally Posted by johngriff View Post
Looks good.
fuck i gave my old ca20e away, i never thought about the shorter gearing, damn.
im pulling a ca20e from a s12 and doing a dohc ka swap at my house so id have a chance there to get it.. but that is alot of work
my plans, could possibly be to get a ca20 car, because i miss IRS, sra is kinda annoying but fun
i got a new job at autozone, i want a ca18det, or sr
Old 07-03-2009, 06:37 PM   #26
codyille
codyille's Avatar
codyille is an unknown quantity at this point
Props on building one of the sexiest S12's out there!!! Keep up the good work!
codyille is offline   Reply With Quote
Old 07-03-2009, 07:16 PM   #27
sukimoto
sukimoto is an unknown quantity at this point
is that seat leopard print?
sukimoto is offline   Reply With Quote
Old 07-03-2009, 09:08 PM   #28
ILoveMyRHS13
ILoveMyRHS13's Avatar
Trader Rating: (25)
Feedback Score: 25 reviews
Damn! That's awesome, dude. I've seen the pictures from Drift Nirvana events, but I never knew there was this much custom work. It's good to see another 18 year old doing good. I hope to see you at some events this year.
Old 07-03-2009, 10:36 PM   #29
s13dan
s13dan's Avatar
s13dan will become famous soon enoughs13dan will become famous soon enoughs13dan will become famous soon enoughs13dan will become famous soon enough
wow.. Thats thing is a beast. hooray for scabin shit together..
I lol at the scavenging from the toolbox for the switch panel...
89 240sx hatch #933-the hot rod
91 240sx coupe #131,603-the daily
s13dan is offline   Reply With Quote
Old 07-03-2009, 10:51 PM   #30
driftdemon
driftdemon's Avatar
driftdemon is an unknown quantity at this point
sick s12 man
driftdemon is offline   Reply With Quote
build, drft, s12
