Old 09-17-2013, 05:11 PM   #31
2toneSilvia
2toneSilvia is an unknown quantity at this point
Happy to have contributed to your awesome parts collection!! looking forward to more
2toneSilvia is offline   Reply With Quote
Old 09-17-2013, 08:02 PM   #32
BossHogg
BossHogg's Avatar
BossHogg is just really niceBossHogg is just really niceBossHogg is just really niceBossHogg is just really niceBossHogg is just really niceBossHogg is just really niceBossHogg is just really niceBossHogg is just really nice
found a few more pics.
works bell splash rapfix II quick release
and the hub
here is a shot of the car up and running. The silvia front is on also. The motor isn't 100% done yet but it runs and can drive. Still need to do catch can. Not sure I i like the gold powder coat valve covers. I couldn't really decide what color to go with. I like black but thought it may be to much black in the bay. I went with gold as the brake calipers are gold.
i know I have forgot a lot of stuff lol. So I will just go ahead and give a rundown of everything. 90% complete as of now. All that is left is body work (this winter) and I will install all of my interior after the body work is done. Right now it's just stock with the defi heads up, defi gauges and tomei wheel and quick release. Also giving the motor an overhaul to let that gt35r breathe and have piece of mind on the bottom end lol. It runs on stock turbo for now. When I return home from Iowa I should have some more parts waiting for me. I'm thinking I will get a layoff next week sometime. This job is about over.
So I realize this thread is somewhat sloppy and kind of hard to get a sense of what the car will be. For all the stuff I missed with pics etc. Here goes the list. Some parts that have been shown in pics are not on the list because I will not be using them on this build. Remember I physically own all this stuff. I have been kind of holding out for when it gets painted etc. There are a few areas I have still not decided on either like if I will want a form of radio/speakers and If I want to do a back half cage or just harness bar etc. I plan on doing some track days with it but I want the street car theme also. I am leaning towards back half cage.
It is like a restoration/build up to me. I want it to be quality, clean, and still perform. Nothing to outlandish/bandwagony or gaudy. Like extreme negative camber that looks like your car is trying out for back to future 4, BN blister kits or rocket bunny etc. Can't stand that stuff lol. Anyways....I would say a good 90% is installed. Some stuff is waiting on other stuff just so things don't get ruined etc. Not to mention I'm indecisive.
1993 240sx coupe
Body:
S13 Silvia front end
Brick Headlights
S13 Silvia K's Aero front bumper
S13 Silvia K's Aero side skirts
S13 Silvia K's Aero rear valences
JUN fiberglass s13 silvia hood
JUN fiberglass grille
Aero Marker (veilside) mirrors
Tomei amber corner light covers
Tomei headlight intake
Shaved body line/antenna/side markers
Stitch welded strut towers
New OEM door pins/bushings
New OEM rear bumper
New OEM driver door window trim
Silvia trunk lock
Suspension/chasis:
Tein Type Flex coilovers
ARC front/rear sway bars
SPL tension rods
SPL tie rod ends
SPL aluminum subframe bushings
Nismo front lower control arms
Nismo rear lower control arms
Nismo silvia rear strut bar
Nismo Power Brace
300zx (Z32) tie rods
CUSCO rear upper camber arms
CUSCO traction rods
CUSCO rear toe adjustment rods
Okuyama Carbing one piece aluminum strut bar w/BMC stopper
Engine:
Series 1 RB25DET
Full Race twin scroll T4 turbo manifod
TiAL Full Race 44mm MV-R external wastegate x2
TiAL BV50 blow off valve
Garret GT3582R dual ball bearing T4 twinscroll turbo 1.06 AR turbine
ARC front mount intercooler
Raw Brokerage Pro-Flow intake mani(polished)
Raw Brokerage 80mm throttle body
Raw Brokerage black fuel rail
Kelford 272 degree 9.3mm lift cams
Injector Dynamics 1000cc injectors
Supertech springs,retainers, seats
Supertech +1mm stainless steel intake valves
Supertech +1mm inconel exhaust valves
Supertech stem seal kit
A'pex Power FC
A'pex GT spec reserve box
Blueridge motorsports pro series oil catch tank
Ross Tuffbond metal jacket harmonic balancer
ARP headstuds
nissan N-1 water pump
Walbro 255 LPH fuel pump
KTS full titanium 3” exhaust
Tomei rb26 piston oil cap
Tomei Timing belt
Tomei adjustable cam gears
Fuel Lab fuel pressure regulator
Mishimoto radiator and fans
OEM gasket kit
OEM idler/tensioner
Wheels
Super advan racing ver.2 metallic blue
17x8.5 +27
17x9.5 +35
Super advan racing SA3R Silver
17x9 +22
Advan RG
18x9.5 +12
Work VS-XX silver
17x8 +5
17x9+0
Blitz Type 03
17x9.5 +10
18x10.5 +20
Skyline R32 GTR wheels
16x8 +30
Brakes:
Front :
Greddy/Grex big brake upgrade
330mm 2 piece duralumin gold anodized slotted rotors
4-pot calipers in grex gold
Earls lines
rear:
R32 Skyline 2 pot calipers
Brembo rotors
Hawk pads
SPL SS lines
Drivetrain:
S5 5 lug conversion
OS Giken 1.5 way super lock LSD
OS Giken TS2BD twin plate clutch/flywheel
Nismo clutch pivot
Nismo clutch line
SPL aluminum differential bushings
New OEM differential seals
New OEM differential gasket
New OEM axle seals
New OEM axle bolts
New OEM power steering rack dust boot covers
custom drive shaft
Interior: (black)
Defi Advance BF boost gauge
Defi Advance BF oil pressure gauge
Defi Advance BF EGT gauge
Defi Advance link box
Defi VSD-X heads up display
Broadfield 60mm vent cluster
Broadfield custom steering column cover
JDM digital climate control
JDM ichikoh 180sx rearview mirror
Nismo Willans 2 inch 4 point harness- passenger side
Nismo 2 inch shoulder pads
Nismo Willans 3 inch 4 point harness (Super GT GT500 GTR)- driver side
Nismo 3 inch shoulder pads
Nismo Recaro SRII recliner seat x2
Nismo black butt plug shift knob
Nismo yellow “kill switch” fashion lighter
Nismo key
Nismo old school blue letter leather steering wheel
Nismo old school horn button
Nismo s13 silvia floor mat
Works Bell “splash” Boss short hub
Works Bell “splash” (rapfix II) quick release
Bride MO seat rails
New OEM ignition switch
New OEM headlight/turn signal lever
New OEM windshield wiper lever
New OEM arm rest lid
Stockinteriors.com carpet
Kimber TLE II .45 acp stainless version.
BossHogg is offline   Reply With Quote
Old 09-17-2013, 09:22 PM   #33
gambit420s
gambit420s is an unknown quantity at this point
Looks like a fun project, I like your progression.
gambit420s is offline   Reply With Quote
Old 09-17-2013, 09:37 PM   #34
BossHogg
BossHogg's Avatar
tomei headlight intake right?
Old 09-18-2013, 12:40 AM   #35
thedr1ftkid
thedr1ftkid is an unknown quantity at this point
Interior: (black)
Nismo key
Bride MO seat rails
this is win lol
thedr1ftkid is offline   Reply With Quote
Old 09-18-2013, 02:38 AM   #36
deadghost
deadghost's Avatar
deadghost is a jewel in the roughdeadghost is a jewel in the roughdeadghost is a jewel in the roughdeadghost is a jewel in the roughdeadghost is a jewel in the roughdeadghost is a jewel in the roughdeadghost is a jewel in the roughdeadghost is a jewel in the rough
1993 240sx coupe
Body:
Brick Headlights
New OEM rear bumper
Silvia trunk lock
Suspension/chasis:
SPL tension rods
SPL tie rod ends
Nismo Power Brace
CUSCO traction rods
Engine:
Series 1 RB25DET
Kelford 272 degree 9.2mm lift cams
A'pex Power FC
ARP headstuds
Tomei Timing belt
Aeromotive fuel pressure regulator
OEM gasket kit
OEM idler/tensioner
Wheels
17x8.5 +27
17x9.5 +35
17x9 +22
Advan RG
18x9.5 +12
Work VS-XX silver
17x8 +5
17x9+0
Blitz Type 03
17x9.5 +10
18x10.5 +20
16x8 +30
Brakes:
Front :
Earls lines
rear:
Brembo rotors
Hawk pads
SPL SS lines
Drivetrain:
S5 5 lug conversion
Nismo clutch pivot
Nismo clutch line
New OEM axle seals
New OEM axle bolts
custom drive shaft
Interior: (black)
Nismo key
Bride MO seat rails
I waited a while to use my meme
IG Holy_khal
deadghost is offline   Reply With Quote
Old 09-18-2013, 03:53 AM   #37
rbfunz
rbfunz is an unknown quantity at this point
Such a legit build lot of money invested! Hoe long did it take to get your rims from gtr garage order some through them also there service is awesome!
rbfunz is offline   Reply With Quote
Old 09-18-2013, 08:44 AM   #38
conrad_s13.5
conrad_s13.5's Avatar
conrad_s13.5 is making a name for him/her selfconrad_s13.5 is making a name for him/her self
Hey man,.. you ever need anyone to break this in and put some miles while you're out.......... I got you!
cONtRol FReAkS
conrad_s13.5 is offline   Reply With Quote
Old 09-18-2013, 12:59 PM   #39
CleanAndLegit
CleanAndLegit's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
Very nice build so far, I knew it would be something like this. Keep up the good work!
Whatever happened to that extra tomei headlight you offered me? I was wondering if you still had it since you never replied when you told me about it.
Anyway looking forward to the updates.
Old 09-18-2013, 06:36 PM   #40
BossHogg
BossHogg's Avatar
lol I feel honored. Thanks!
GTR garage is awesome. From actual Japan it took about 3 days. Overall probably a week to week and half. It will depend on how fast the seller of the auction packages and sends them to Kunio. I have been getting all of my japan packages within 3 days lately. I guess Chicago customs is getting used to my address lol. They used to hold my stuff for weeks sometimes.
No one will have a key lol. The steering wheel will be locked up. I'm hoping broadfield can hook me up with lazer eye scan, voice activated, fingerprinted, sperm sample security system. Maybe he will start a group buy lol. I forgot the mote with alligators.
Or maybe the Dave Chappelle security system. Spread your cheeks and lift your sac!
thanks
Originally Posted by thedr1ftkid View Post
this is win lol
Thanks!
I was just yankin your chain. I wish I had another to sell. I've only ever seen one in my life. I have a few parts like that.
Old 09-19-2013, 11:34 PM   #41
dsc4130
dsc4130's Avatar
dsc4130 is just really nicedsc4130 is just really nicedsc4130 is just really nicedsc4130 is just really nicedsc4130 is just really nicedsc4130 is just really nicedsc4130 is just really nicedsc4130 is just really nicedsc4130 is just really nice
I remember the day you picked up those version 2's. I was shocked when I walked in and saw them lol
I <3 jdmhookup
dsc4130 is offline   Reply With Quote
Old 09-22-2013, 04:41 PM   #42
BossHogg
BossHogg's Avatar
have we met before?
Old 09-23-2013, 05:30 PM   #43
BossHogg
BossHogg's Avatar
crappy. fixing pics, uploading to imgur. Got a few done, going to bed lol. Didn't realize how many pics i have. This will take a while.
Old 09-25-2013, 09:24 PM   #44
BossHogg
BossHogg's Avatar
Pics are fixed. Found a few more pics to.
aero marker mirrors
new OEM goods
After Kewilso3 posted pics of his ride. It just reminded me how much I want these wheels but can never really find them in good shape. I have tried to buy off quite a few people that owned them with no avail. I don't blame them for not selling. I like the gold ones. Usually find them painted or powder coated some ugly color or they are just beat up and missing center caps. So Kunio at GTR garage comes through for me again. I found a super super clean set on yahoo japan but the offsets were a bit meh. But they were decent 18x8.5 +38 and 18x9.5 +35. So I have been talking to wheel flip about getting some deeper offsets. They said I could make them 18x9 +28 and 18x9.5 +25. The wheel list got one more check off the ol list. Thank god.
Old 09-26-2013, 07:55 AM   #45
Mikester
Mikester's Avatar
Dude- We need to go for a cruise!
Old 09-26-2013, 03:45 PM   #46
maces13
maces13's Avatar
maces13 is an unknown quantity at this point
Holy shit your build is amazing bro, definitely legit any way you slice it. Keep up the sweet updates !
maces13 is offline   Reply With Quote
Old 09-26-2013, 07:05 PM   #47
BossHogg
BossHogg's Avatar
for sure! my schedule is just crazy. Not sure when I'll be home next and hopefully I will have the car painted/caged this winter. Car is down at the moment getting headwork/rebuild. Waiting on parts still. I'm just going to shoot for next year being the year it is basically done to a enjoyable complete stage. Since I think I will be gone the rest of this year. Still want to build the bottom end. Not sure if rb28/30 or just keeping it simple with basic rebuild. Ah well, to far into the future to worry about.
Thanks! lots of time and effort. When this is the only car you really care about it's easy to spend the money on it. The only other car I would do like this is an FD rx-7, but you can't afford that when your 16 lol. So 240 it was. I'll keep them coming. I still have parts that I haven't seen yet lol. One bad thing about working on the road. Pay is good, never home. So you have to make arrangements for things. So when I go home next, I'll have a few more pics.
Old 09-27-2013, 11:23 AM   #48
Levan. B
Levan. B's Avatar
Levan. B is an unknown quantity at this point
Sometimes I think I'm crazy when I realize what I've spent on my 90's sport compacts... Then I come into threads like this and I feel better about my poor decisions. Lol, Thank you.
Cool build dude. Lemme snag up something outta that plethora of parts you've got there
enjukuracing.com
Levan. B is offline   Reply With Quote
Old 09-27-2013, 12:02 PM   #49
WIKID S4TEEN
WIKID S4TEEN's Avatar
WIKID S4TEEN is making a name for him/her selfWIKID S4TEEN is making a name for him/her self
OP, your screen name fits you well. I would say, GL with build, but u don't need it, lol.
Thanks for sharing this awesome build.
Rock wha U jock and don't talk if U ain't got!!
WIKID S4TEEN is offline   Reply With Quote
Old 09-27-2013, 03:38 PM   #50
da_crew10
da_crew10's Avatar
da_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond repute
This!
Sell me those 03's I regret selling mine!
Dudes voice makes my arm feel punchy.
da_crew10 is offline   Reply With Quote
Old 09-29-2013, 02:04 PM   #51
BossHogg
BossHogg's Avatar
Yea the 90's were great. Nice styling of cars and musically. I don't even want to add up what I have spent. I can't even really put a price on it I don't think. Maybe just in parts. But it does not matter to me as this is my hobby. I kind of can't wait to build a new project. Something new and a little more high class of car from the beginning. The new Z car rumored has sparked a little interest. If not I will just save until I get a GTR. But this will be in 3-5 years I think. Early 30's. Have other things I would like to get started and setup before I do another car. But I know your feeling. Those thoughts go through my head from time to time. I think I do ok with mixing responsible purchase with toy purchases. I paid off 24k in loans over the past two years also lol. I often think what I "could" have done with that money instead. ppg dog box.
haha, I may sell a few parts here and there. I like to keep things and try to put them in other builds. It's a hobby and a collection. Hard to explain really, I'm a hoarder of car parts I guess.
Thanks, I appreciate it.
Originally Posted by da_crew10 View Post
This!
Lol wheels will be hard to pry from me. I'm very particular when it comes to wheels. I have thought about selling some. But then I'm like "why?". They're bought and paid for. The only thing they do is take up space. But nice wheels look good so they do serve a purpose lol. Some people like finely hand crafted statues, I like stacks of nice wheels haha.
Old 10-07-2013, 04:19 PM   #52
BossHogg
BossHogg's Avatar
got home today, got to see some goods and also had a nice package delivered.
Nismo rear strut bar
nismo red cigarette lighters
old school nismo wheel
old school nismo s13 silvia floor mat. The mat itself is in decent shape, just the little logo on the bottom is missing the black background coating.
Package from Raw Brokerage
Raw Brokerage fuel kit
Injector Dynamics 1,000cc injectors
Tomei intake/exhaust cam gears
Supertech bronze valve guides/valve stem seals
Supertech inconel +1mm exhaust valves
Supertech +1mm nitride coated intake valves
Supertech spring package
titanium retainers
seats
springs
OEM idler/tensioner
Ross Tuffbond
ARP head studs
The only thing not here is the Kelford cams. Probably waiting to be shipped from Australia.
Old 10-08-2013, 01:02 PM   #53
status_ryan
status_ryan is an unknown quantity at this point
Dear god almighty. This is nothing short of impressive. Making me jealous.. In for final product!!!!! Keep it up man!
status_ryan is offline   Reply With Quote
Old 10-08-2013, 02:06 PM   #54
xBtony
xBtony's Avatar
xBtony is an unknown quantity at this point
Wow! So many cool parts!
Originally Posted by frsh4 View Post
Ask google. That motherfucker knows everything.
xBtony is offline   Reply With Quote
Old 10-08-2013, 02:17 PM   #55
OBEEWON
OBEEWON's Avatar
Sheesh. Your wheel selection alone is magnificent.
Old 10-08-2013, 03:17 PM   #56
Mrjbrown07
Mrjbrown07 is an unknown quantity at this point
I may need to change my pants after reading all this. EPIC build man!!
Mrjbrown07 is offline   Reply With Quote
Old 10-08-2013, 08:15 PM   #57
va240dude
va240dude's Avatar
Trader Rating: (161)
va240dude is an unknown quantity at this point
Feedback Score: 161 reviews
Car looks great! Looking forward to more!
va240dude is offline   Reply With Quote
Old 10-09-2013, 04:59 AM   #58
Arteeste
Arteeste's Avatar
Arteeste is an unknown quantity at this point
^ What he said
Arteeste is offline   Reply With Quote
Old 10-09-2013, 08:37 PM   #59
Reece
Reece's Avatar
Reece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymore
So many awesome parts... Love it!
Originally Posted by Almighty So View Post
Don’t price bash me.
Reece is offline   Reply With Quote
Old 10-10-2013, 09:23 PM   #60
Bushido
Bushido's Avatar
living the dream. cool wheels bro
