Old 06-16-2020, 06:10 PM   #241
dwnshft2drft
dwnshft2drft's Avatar
Trader Rating: (28)
dwnshft2drft will become famous soon enoughdwnshft2drft will become famous soon enoughdwnshft2drft will become famous soon enough
Feedback Score: 28 reviews
I would think omori Japan would know about it.
dwnshft2drft is offline   Reply With Quote
Old 07-07-2020, 04:59 PM   #242
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Feedback Score: 18 reviews
Originally Posted by dwnshft2drft View Post
Right now its 4.08 diff, s14 cluster and, speedo. I?d say 2-3% faster maybe because I?m running larger diameter wheels sets.
Before I had the dakota wired with the abs diff sensor it was 20% faster. My oil change intervals went pretty quick lol
Let me know how that 3.69 works. I have the s15 diff waiting to install.
Got everything installed and it works! Added the 3.69 gear and speedo was reading 10% slow, showed 50 when I was really going 55 or 70 / 77 real speed, etc. Found an old thread about speedometer calibration, soldered some jumpers on the speedo itself and it's fully accurate. Even adjusted for my tire size. So using all stock parts, less things to possibly go wrong.
Old 07-14-2020, 07:39 PM   #243
dwnshft2drft
Trader Rating: (28)
Do you still have that old thread? Thanks
Old 07-15-2020, 03:55 AM   #244
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Just search for 240sx speedometer calibration and it'll come up. Main info is the % values for each pin. Look at what are set from factory, then figure out what combo works to get your desired change.
Here is one of the top results.
https://forums.nicoclub.com/s13-and-...p-t618567.html
So for example, pin 7 was only one soldered together. #7 = -12.4%
Difference going from 4.08 to 3.69 is +10%. So -12.4 + 10 = -2.4
Figure out what combo of pins gets you to -2.4 (so 0, 3, 4)
Desolder pin 7, and put a dab of solder on pins 0, 3, & 4.
In my case, I had extra math since I'm running 245/40R17 tires instead of the stock 205/55R16. Those are -0.8 smaller than stock. So to get mine correct: -12.4 - 0.8 + 10 = 3.2
There's 4 part numbers for S14 gauge clusters, so you need to base adjustments on whatever the starting point is on your cluster.
