02-16-2018, 03:29 PM | #1 |
Trader Rating: (29)
Feedback Score: 29 reviews
Enjuku Racing - ISR Performance G35/350z FUCA NEW PRODUCT
ISR Performance Front Upper Camber Arms Nissan 350Z / Infiniti G35 ISR Performance Front Upper Camber Arms Nissan 350z / Infiniti G35 ISR Performance front upper camber arm set is designed to provide the maximum range of adjustment on your Nissan 350z and Infiniti G35. Unlike other arms on the market that require you to remove the ball joint for adjustment these arms are easily adjusted using a 19mm wrench without removing any components. These arms include a high quality serviceable ball joint. What’s in the Box: 2x Front Camber arm Typical Range +0.5 to -5.5 degrees *This will NOT Fit 2007 Infiniti G35 Sedan** ** All ISR Performance Products are Designed for Off Road Use Only ** In Stock and Ready to Ship! $299.99
Office: 352-241-8399 / 1-888-SR20DET (772-0338) YouTube.com/c/EnjukuRacingParts http://www.enjukuracing.com [email protected] |
02-19-2018, 11:52 AM | #2 |
Trader Rating: (29)
Bump, In Stock!
