Old 01-26-2013, 10:28 AM   #1
purplove
purplove's Avatar
purplove is an unknown quantity at this point
CA CA18det white smoke, hard start, misfires
So I went with a ca swap I picked up from an importer this year. I redid most gaskets, all belts, and all the hoses. I wired or correctly(solder, heat shrink, wrapped with elec tape). It's been blowing white smoke since the first start and it smells strongly of fuel. It studders really hard on start up, mostly cold starts. Also, it misfired at idle and up to about 3.5k-4k. Oil smells like gas. It's only idled for a total of an 1.5 hours and a few drives around the block which is a very small distance.
Things I've done:
Compression test(150,149,149,150)
New fpr set to 28psi with vacuum.
Changed oil.
Changed spark plugs.
Checked resistance across injectors and coil packs
New o2 sensor
Mods:
Tomei fpr
Hks ssq bov VTA
Aftermarket manifold
Full 3" apexi exhaust
Water to air intercooler setup
CAI
Boost gauge
Waiting on my oil pressure gauge
Sr20 clutch&flywheel setup
Aluminum radiator with elec fan
Kade tb with ca tps
Weapon r catch can
Any help would be greatly appreciated!
purplove is offline   Reply With Quote
Old 01-26-2013, 10:41 AM   #2
blksylv
blksylv's Avatar
Trader Rating: (33)
blksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymore
Feedback Score: 33 reviews
stuck injector or a bad injector o ring
there is nothing wrong with enjoying the build. however, we sometimes have to remind ourselves that the build is only one part of the puzzle, and that ultimately - enjoying and driving the car is the number one priority.
blksylv is offline   Reply With Quote
Old 01-26-2013, 10:43 AM   #3
purplove
purplove's Avatar
I've replaced o rings already and with a stethoscope i can hear clicking. Wouldn't this tell me if it is stuck open? I don't smell gas near my engine bay.
Old 01-26-2013, 02:10 PM   #4
boyou2
boyou2 has a spectacular aura aboutboyou2 has a spectacular aura aboutboyou2 has a spectacular aura aboutboyou2 has a spectacular aura aboutboyou2 has a spectacular aura aboutboyou2 has a spectacular aura about
first, set your fuel pressure a 35psi without vacuum
second, check your mass return from your injectors, if it's there continuity between injectors and the chassis, your ECU has a problem (injectors are opening to the chassis mass only via the ECU)
if you can, use an OEM FPR.
how is plugged your OCT?
boyou2 is offline   Reply With Quote
Old 01-26-2013, 04:44 PM   #5
purplove
purplove's Avatar
My fuel pressure is set to 36 psi without vacuum which is correct according to the fsm.
My oem fpr showed 36 psi with vacuum which is why I switched over to the adjustable.
What is an OCT?
I will check for continuity tonight or tomorrow.
Thanks for the advice guys, anyone else feel like chiming in?
Old 01-26-2013, 09:57 PM   #6
rcdad123
rcdad123's Avatar
rcdad123 is an unknown quantity at this point
also, check your spark plugs, if one is darker than the other, that is the problem cylinder. if it is darker than the others, check the injector and ignition on that cylinder. if all of them are the same color which should be dark because its running really rich. check and make sure the wires you fixed dont touch other wires. and try not to keep the engine running in this condition or you will mess up the bearings and piston rings due to fuel diluted oil.
rcdad123 is offline   Reply With Quote
Old 01-29-2013, 03:19 PM   #7
purplove
purplove's Avatar
It been raining alot down here lately and my cars outside
Ill check the plugs, probably even scoop up some new ones.
I havent driven the car but twice around the block when I first got it started. It ran great besides the misfires and white smoke everywhere.
I got my oil pressure gauge back from megan racing. Oil pressure is steady at 46psi. Thanks for the help guys, Ill be reporting back shortly.
Old 01-29-2013, 04:04 PM   #8
ilovecoupes
ilovecoupes's Avatar
ilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to behold
Have you checked the timing? Make sure all the timing marks on the timing belt line up.
Also make sure your key on the exhaust cam for the CAS isn't broken.
You can also try swtiching out MAFs, a KA-e MAF will work.
Shoot To Thrill
ilovecoupes is online now   Reply With Quote
Old 01-29-2013, 07:43 PM   #9
gerardogomez0809
gerardogomez0809's Avatar
gerardogomez0809 is an unknown quantity at this point
Is the ka maf a plug and play or would it need wiring?
Sent from my iPad using Tapatalk
gerardogomez0809 is offline   Reply With Quote
Old 01-30-2013, 10:05 AM   #10
ilovecoupes
you'll have to re-wire it. CA Maf is 4 wire [ABCD], KA-e is 3 Wire[ABC].
Or you can hack up the male plug of the KA maf to accept the female CA end MAF plug.
Shoot To Thrill
Old 01-31-2013, 03:51 AM   #11
boyou2
it depends of the generation of the engine, some have 3wires (O² version)
OCT = Oil Catch Tank
