Old 08-03-2010, 08:35 PM   #1591
frizzle
In time-out for misbehaving.
Trader Rating: (45)
frizzle is on the path to ruinfrizzle is on the path to ruinfrizzle is on the path to ruin
Feedback Score: 45 reviews
Originally Posted by Broadfield View Post
Work Meister S1-3P's
Front: 18x9.5 +12 R-disk 245/35 -3 degrees camber w/ChargeSpeed 20mm fenders
Rear: 18x11 +30 O-disk 285/30 -2.5 degrees camber w/25mm pull. Hammered upper, inner wheel housing and notched lower control arm 1/4".
Very Clean!!!
frizzle is offline   Reply With Quote
Old 08-03-2010, 09:16 PM   #1592
godzillarb
godzillarb's Avatar
godzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to all
Originally Posted by 240KA View Post
not that your post wasn't informative, but can you add onto that a little more? now that we know nitto 315 DRs are worthless, can you tell us what you switched them with?
how much power were you making? wheel width and offset?
Originally Posted by Flicktitty View Post
Really? what kind of power are you making?
i run a BFG 225/55/15 Drag radial on a 410whp/360 tq 2JZ 240sx and the car hooks pretty damn well. can't imagine having tire spin on a tire THAT MUCH bigger.
Setup is 315/35 17x10 +12, solid subframe, tilt spacers, 2way lsd. RB26dett GT2540s on 20psi. I also have the battery, 15 gallon fuel cell, and 10lb n20 bottle in the trunk.
I think the problem is the 17s, not enough sidewall. If I get on it at all in first, second, or third, it just spins. Originally, I had Sumitomos on there, but they were just too hard and broke traction constantly. The Nittos are better, but still too hard to hook up. Maybe they'll work if you're under 400hp or have a heavier car?
The next setup will be some 15x10s, probably a 325/50 tire.
INTENSE POWER RIPPED ME OFF
godzillarb is offline   Reply With Quote
Old 08-03-2010, 09:22 PM   #1593
Bumnah
Bumnah's Avatar
Bumnah is an unknown quantity at this point
Send a message via AIM to Bumnah
255/40/17 NT-01s all the way around
17x9 +22 all the way around.
Rear is pulled/flared.
Fronts are roll/pulled. Needs more pull, lots more.
bumnah.com/trakpak
Bumnah is offline   Reply With Quote
Old 08-06-2010, 03:57 PM   #1594
FusionR240sx
FusionR240sx's Avatar
FusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond repute
Send a message via AIM to FusionR240sx
18x11 don't know offsets, cuz ccw doesn't give em out..
295/35
Originally Posted by Wreckless35 View Post
still be flush dropped on KYB AGX struts & s-tech springs
WUT?
FusionR240sx is offline   Reply With Quote
Old 08-06-2010, 05:15 PM   #1595
GripTerror
GripTerror is an unknown quantity at this point
i f'n love this thread.
best thread on zilvia period
GripTerror is offline   Reply With Quote
Old 08-06-2010, 06:21 PM   #1596
longfellow
longfellow's Avatar
longfellow is an unknown quantity at this point
I want both NT01's and White RPF1's for my car.
longfellow is offline   Reply With Quote
Old 08-08-2010, 06:16 PM   #1597
Black R
Black R's Avatar
Black R is an unknown quantity at this point
Broadfield, it's hard to tell from your pics; which has a more concave face - r disk or o disk?
Black R is offline   Reply With Quote
Old 08-08-2010, 06:35 PM   #1598
Broadfield
Broadfield's Avatar
Trader Rating: (163)
Broadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to all
Feedback Score: 163 reviews
The actual spoke design is basically the same. It's the back spacing of the hub where the difference is. As you can see the lug nut area is very deep on the R-disk. This pushes the spokes out to make room for bigger calipers. Thus giving you less dish. This is the only pic I have to compare the faces.
Follow Along For My Latest Work
My Portfolio
Please Share
Check Out My Builds
Broadfield is offline   Reply With Quote
Old 08-08-2010, 08:49 PM   #1599
Spoolpigeon
Spoolpigeon's Avatar
Spoolpigeon is making a name for him/her selfSpoolpigeon is making a name for him/her self
broadfield, your car is perfect! had i known you were gonna be at IA in nashville i would have made the 3 hour trip just to see your car. I did however see some pics from the event and your car and a grey coupe with rpf01s were my favorites. keep up the good work!
Steve-O
Spoolpigeon is offline   Reply With Quote
Old 08-08-2010, 10:10 PM   #1600
nopwrsldr180
nopwrsldr180's Avatar
nopwrsldr180 is an unknown quantity at this point
Broadfield, Wonderful attention to detail and tasteful modifications. I don't know if your car belongs here or in the tire stretch thread, frankly i don't care, it just looks classy and timeless.
I posted pics of my car in the fitment thread and was told i didn't belong there. So here she is in the "correct" thread.
SSR MS1
18X9 +19 245/35
18x10 +24 265/35
Never rubs on the street. Rubs some in the rear at the track in the rear during high G uphill turns (lots of suspension compression and body rolls enough to make camber move towards positive)
nopwrsldr180 is offline   Reply With Quote
Old 08-10-2010, 12:29 PM   #1601
Black R
Black R's Avatar
Thats the r-disk on the right, correct?
I wonder if it would fit over your front calipers - have you ever tried it just to see how it fits the calipers?
Old 08-10-2010, 02:48 PM   #1602
Broadfield
Broadfield's Avatar
I tried, it doesn't come close to fitting. The R-disk is on the left, O-disk on the right. The breakdown in order of most lip/least caliper clearance is as follows: O, A, L then R. 19" 3pc Meisters also have a T-disk for really big calipers.
My Portfolio
Please Share
Check Out My Builds
Old 08-12-2010, 07:42 AM   #1603
simmode1
simmode1's Avatar
simmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfection
Send a message via Yahoo to simmode1
SSR MS1
18X9 +19 245/35
18x10 +24 265/35
I'm in love...
simmode1 is offline   Reply With Quote
Old 08-12-2010, 06:35 PM   #1604
Driftin_240sx
Driftin_240sx's Avatar
Driftin_240sx is an unknown quantity at this point
Send a message via AIM to Driftin_240sx Send a message via Yahoo to Driftin_240sx
/\ What she said
Driftin_240sx is offline   Reply With Quote
Old 08-13-2010, 06:21 AM   #1605
SicBastard
SicBastard's Avatar
SicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the rough
285s on an s13 belongs in here all day.
BURN OUT IN YOUR FACE!
1998 S14 LS7/T56 swap in progress, build thread:
http://zilvia.net/f/tech-talk/147301...d-gto-pan.html
SicBastard is offline   Reply With Quote
Old 08-15-2010, 03:55 PM   #1606
R@ddy
Trader Rating: (32)
R@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymore
Feedback Score: 32 reviews
just got some 17x9 +22 blitz 01's, will 245/40/17 look good in the rear and 225/40/17 in the front? on stock fenders of course, just rolled.
R@ddy is offline   Reply With Quote
Old 08-15-2010, 04:25 PM   #1607
ilegal
ilegal's Avatar
ilegal is an unknown quantity at this point
Stock Fenders,
All Volk TE37 17x9 +22 , yokohama Neova 255/40/17
ilegal is offline   Reply With Quote
Old 08-15-2010, 04:35 PM   #1608
R@ddy
Trader Rating: (32)
is it a huge difference between s13 and s14?
Old 08-16-2010, 12:14 AM   #1609
ilegal
ilegal's Avatar
as mine 255/40/17 tires sometimes love to kick rear fenders little bit. but rolled fenders will be Okay ;D if you want more drop, you need tire stretch, like a 215/40/17 tires, for your 17x9.0 blitz wheels ant stock fenders.
never had s13 but i think where is no "HUGE" difference between s13 and s14 in wheel clearance between tire and fender.
Old 08-16-2010, 12:17 AM   #1610
199240sxcoupe
199240sxcoupe is an unknown quantity at this point
295/35
sorry to quote but what size is the lip?
199240sxcoupe is offline   Reply With Quote
Old 09-01-2010, 07:08 AM   #1611
michael200sx
michael200sx is an unknown quantity at this point
I can finally add my car as its nearly finished visually,
this thread was very helpful as inspiration
wheels are Meisters 18x8.5 front and 9.5 rear with 235 fronts and 285 rears, nothing real crazy but i'm happy with the stance.
michael200sx is offline   Reply With Quote
Old 09-01-2010, 07:27 AM   #1612
VNG704
VNG704's Avatar
VNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond repute
michael200sx, wheel offsets?
VNG704 is offline   Reply With Quote
Old 09-01-2010, 07:35 AM   #1613
michael200sx
rears are 9.5 +24
fronts unsure but required 20mm spacer,
pretty weak i know, but i wanted rubber and i'm happy with 285's
Old 09-01-2010, 07:51 AM   #1614
240sxScores
240sxScores's Avatar
240sxScores is making a name for him/her self240sxScores is making a name for him/her self
Send a message via AIM to 240sxScores
Looks like your tires are directional. And going backwards lol.
240sxScores is offline   Reply With Quote
Old 09-01-2010, 07:17 PM   #1615
michael200sx
ha ha nice pick up,
they have now been swapped
Old 09-01-2010, 07:25 PM   #1616
FusionR240sx
i wana say the rear is like 3.5-4" on those ccw's.
maybe like 1.5" front.
WUT?
Old 09-15-2010, 07:38 PM   #1617
robbie2883
robbie2883 is an unknown quantity at this point
finally got my new ones on. nothing super aggressive but should be nice and flush when done. nothing is done to the fenders yet though. just a litte roll/pull and i should be able to lower it a little more and end up pretty flush
specs are
varrstoen 18x9 +15 245/40 front
18x9.5 +22 275/35 rear
robbie2883 is offline   Reply With Quote
Old 09-18-2010, 12:17 PM   #1618
ej2civic
ej2civic is a jewel in the roughej2civic is a jewel in the roughej2civic is a jewel in the roughej2civic is a jewel in the roughej2civic is a jewel in the roughej2civic is a jewel in the roughej2civic is a jewel in the rough
Volk GT-N
F:17x8 +30 with 235/40
R:17x9 +24 with 255/40
fronts are rolled and pulled on...no needed for these wheels
Rears are rolled with a slight pull. mostly for the look probably could have gotten away with out the pull
I know the size is a little weak..I got a deal on the wheels that i couldn't pass up at the time. Eventually i plan on changing them again maybe go 18's maybe not....not sure yet
I like the way the rear sits. Front fenders are pulled pretty good to fit my slicks which is why these look sunk in a little.
ej2civic is offline   Reply With Quote
Old 09-19-2010, 06:03 PM   #1619
sydwyz95
sydwyz95 is an unknown quantity at this point
Need to get some better pics taken but ill post my setup up!
Volk TA
front: 19x9.5 +22 w/5mm spacer for now rolled slight pull 245/30/19 3 degrees camber
rear: 19x10.5 +22 rolled and healthy pull 305/25/19 2.5 degrees camber
still tryin to dial in ride height just put the 305s on up from 275s and need to go to a 8 or 10mm spacer up front..
sydwyz95 is offline   Reply With Quote
Old 09-19-2010, 09:40 PM   #1620
enigmadsm
enigmadsm is an unknown quantity at this point
Saw this today! Was shocked when you said 19's and 305s...Nice pics
enigmadsm is offline   Reply With Quote
