01-17-2018, 11:17 PM | #21572 | ||
GM2 (SW/AW)
I had this issue when going Z32, with spacers to make the wheels clear the calipers. I had enough room to just toss on a nice big drill bit and make some holes in the rims to clear the studs. I did have everything balanced after the fact, but before I did that I drove for 5 years on those re-drilled wheels. Not a bad idea if you ask me. Just don't get stupid with drilling the backs of your wheel centers out.
KA-T for life! Current for sale advertisement |
01-19-2018, 09:00 AM | #21575 | |
Trader Rating: (58)
Feedback Score: 58 reviews
With that said, is there a way to modify the mounts to fit something like a Dual Flex a lite slim fan setup, or even Altima twin fan setup? Unsure how close it is. Use one fan for main cooling and then have AC trigger the second for AC
01-20-2018, 07:39 AM | #21576 | |
01-21-2018, 09:46 PM | #21577 |
Quick question guys. I ordered an isis arms package and it came with 4 extra spacers. I think they are tension rod spacers? They're a little bit thicker than the ones that came on the arm. The arms bolted up to my car no problem. What are those extra spacers for? Thanks
01-21-2018, 10:16 PM | #21578 |
the "ears" on the subframe are different widths for one particular arm between s13 and s14. can't remember which.
if your arms bolted up to the subframe without a huge gap bewteen the spacers and ears, then you have the right spacers in your arms, and nothing to worry about. |
01-22-2018, 07:01 AM | #21579 |
Trader Rating: (58)
I've never played with it so it's hard to say
01-22-2018, 07:05 PM | #21580 | |
01-23-2018, 12:35 PM | #21581 |
Does anyone know if Ganador sells the LED portion of the mirrors separately as replacement parts? I’ve got a pair, and my passenger side looks like it was hit by something. It’s cracked and I’m assuming water got into it and fried the LEDs. Would love to have both functioning
01-23-2018, 05:57 PM | #21582 |
What is the Tallest diameter wheel/tire combo I can use on an S14 240sx
With all stock suspension more or less If it would really help I could change something. Control arm, shock type, its possible. with: -any OEM wheels (from ANY car) -Aftermarket wheels And to add another question, What is also the lightest wheel/tire while still being tallest or almost as tall as possible. I am interested in Tallest, lightest. But would accept just a nice tall tire that doesn't look that stupid. I realize I am asking alot here. |
01-24-2018, 04:45 AM | #21583 | |
A 245-40-18 is ~25.4". Moving to a 45 profile and going taller gives you about 26.7" 245-35-19 is about 25.8" At about 26" you run out of room under the spring perch(stock shocks and springs), going over will more than likely hit the coil over unless you go with a +5 - -5 offset Stock suspension, 245-40-18 with at least +12 - +5 offset, but you may hit when turning in front. On stock, 235-45-17 9" rim, +10 offset will clear everything Lightest wheel, hands down is Enkie RPF-1, or Buddy Club's if you can find them
01-25-2018, 05:04 PM | #21584 |
Hey guys I'm planning on painting my engine bay white while the motor is out of my Z. I'm looking for a clearcoat that will easily be cleaned if it gets dirty and is protective for the paint. Any suggestions?
I'm going to use the cheapo rustoleoum gloss white base coat btw. Sent from my SAMSUNG-SM-J727AZ using Tapatalk |
01-25-2018, 06:16 PM | #21585 | |
ITS LISA'S FAULT!!!
Trader Rating: (41)
Feedback Score: 41 reviews
01-25-2018, 06:41 PM | #21586 | |
01-25-2018, 08:05 PM | #21587 | |
01-25-2018, 08:18 PM | #21588 | |
you think i need for the whole bay? Sent from my SAMSUNG-SM-J727AZ using Tapatalk |
01-26-2018, 06:09 AM | #21589 |
01-27-2018, 02:24 PM | #21592 |
I painted my calipers last summer in a way that the whole caliper is black and the nissan logo is sanded to bare metal, then applied a lot of clear coat over the whole caliper.
But the car has been sitting on my yard throughout the whole winter and the damn logo has started to rust. (like very minor rust spots here and there) Now the question is that is it possible to leave the logo bare metal if I now sand it back and apply more clear coat? Or will it rust again? If not then I think I have to paint it. |
01-27-2018, 03:21 PM | #21593 | |
ITS LISA'S FAULT!!!
Trader Rating: (41)
you were supposed to clear over the logo |
01-27-2018, 03:33 PM | #21594 |
01-27-2018, 06:00 PM | #21595 |
HOFFMAN - is this what you're talking about?
http://zilvia.net/f/showthread.php?t=638275 is your rack leaking finally? :P Last edited by 240KA; 02-10-2018 at 09:38 PM.. |
01-27-2018, 06:12 PM | #21596 |
Trader Rating: (25)
Feedback Score: 25 reviews
Close, but I need the return line fitting. My feed line fitting still has never leaked. Put one on the return and it leaked. Put a copper washer on and it held for a little while but now it’s leaking again. There was someone selling them in the market place a little while back but I can’t find it
01-27-2018, 08:05 PM | #21597 |
02-02-2018, 04:37 PM | #21599 |
dumb question on seats
i recently bought a gutted s14 and i wanna reinstall a new interior. i was wondering what the differences are on kouki and zenki rear seats if there are any. would kouki rear seats fit in a zenki?? gracias
